MacBook Pro 4GB RAM, 2.53 Ghz Core2
I've installed CS5 on my Mac Pro desktop without any issues, however my laptop is another story. When After Effects launches it complains that it cannot write the Workspaces.xml file. Repairing permissions did not resolve the issue. I used the Uninstaller with the delete preferences option checked and reinstalled but no joy. Tried this twice without success.
If I dismiss the error message After Effects complains that QuickTime is not installed, it is installed QT Pro 7x and then reports that an output module is missing. Half the time it then crashes (have submitted crash report) the other half of the time it launches and will import QuickTime but no output modules of any kind are available. The Render Que is blank with no controls to create an output module.
I've filed a tech support report but no one will answer until Monday at the earliest. I'm posting here in hope that the solution is simple.
I am running 10.6.3 on a MacPro 2 x 2.26 GHz and I have been having the same errors.
I got past the firs tone by going into my user Library:Preferences:Adobe:After Effects and deleted the 10.0 folder and that cleared up the issue with the Workspaces.xml (even though there was not file like the one it was named in there), but I still have this QuickTime not installed issue, and it basically makes the program not work at all.
As soon as I launch After Effects, I am also getting a dynamiclinkmanager crash, but it does not stop After Effects from launching, but without the Quicktime support, I get an open program that won't read any quicktime files without giving me errors.
I have run permissions and DISKWARRIOR and have had no luck.
Yes, worked for me as well, but it is not an acceptable solution. I need it to work in my User. And this is a fairly new user as this computer is not 6 months old and I started fresh. Also don't want to uninstall all adobe software and start again, because I still need AE CS4 because I still have many non-64 bit plug ins, and I don't want to have to re-install the whole CS4 Design Premium Suite either.
I think I figured out the solution this morning, at least it worked for me. I posted it in this thread as well: http://forums.adobe.com/message/2780763#2780763
It's a conflict with some Adobe Preference files.
This morning I decided to try pulling out the entire Adobe Preferences folder, User:Preferences:Adobe and just put back Adobe:After Effects, and After Effects CS5 booted perfectly. It boots quickly and I don't even get the dynamiclinkmanager crash that I have been getting.
And I it seems to have created a new folder in my new Adobe folder, the Adobe QT32server:1.0:TraceDatabase.txt and the dynamiclinkmananger:2.0:memorybalancers5.xml was created this time as well. I then quit after effects, and put back all the other preference files into that folder, though not replacing any of the new versions that were created, and once again After Effect boots and works.
So that was the issue.
yep, tried that and still get the 'quicktime is not installed on this system'.
I have re-installed OSX10.6 from DVD and still nothing. I have also removed perian & flip4 and re-installed quicktime 7 but still get the message.
When logged in a s a different user I din't get the 'missing output component' dialog though.
Anyone had any success with this?
"And I it seems to have created a new folder in my new Adobe folder, the Adobe QT32server:1.0:TraceDatabase.txt and the dynamiclinkmananger:2.0:memorybalancers5.xml was created this time as well."
Could someone possibly post a link to download copies of these files? It may solve my problem.
Thank you
Sorry to hear that you are all having this problem.
There may be an issue with 10.6.3, where the OS changes permissions to be restricted on folders in /Library/Application Support. From what I have seen, it is only when you had 10.6, 10.6.1, or 10.6.2 and then updated to 10.6.3, but as of yet I have not been able to confirm the exact conditions.
What I would suggest is the following:
Hope this helps!
Thank You Carey, but this does not work for me.
It's read only (for everyone) already on my system in both directions. User/Library/Application Support/Adobe and HD/Library/Application Support/Adobe. Had not to make any change.
- I have Quicktime 7.6.6 installed in the Utilities Folder (Quicktime X is installed)
- I have deinstalled AE CS5 several times with the box "delete preferences" checked
- Restarted the system several times
- Repaired permissions with disk utility
- Tried the things with deleting the Adobe folder
AE CS4 runs fine.
AE CS5 has still the Quicktime error and the other one and starting it up takes like 5 minutes.
More suggestions?
Date/Time: 2010-05-06 10:03:32 +0200
OS Version: 10.6.3 (Build 10D573)
Architecture: x86_64
Report Version: 6
Command: After Effects
Path: /Applications/Adobe After Effects CS5/Adobe After Effects CS5.app/Contents/MacOS/After Effects
Version: 10.0 (10.0)
Parent: launchd [121]
PID: 1310
Event: hang
Duration: 2.85s (sampling started after 2 seconds)
Steps: 9 (100ms sampling interval)
Pageins: 0
Pageouts: 0
Process: After Effects [1310]
UID: 501
Process: AdobeCrashDaemon [1312]
Path: /Applications/Adobe After Effects CS5/Adobe After Effects CS5.app/Contents/Frameworks/AdobeCrashReporter.framework/Versions/A/R esources/AdobeCrashDaemon.app/Contents/MacOS/AdobeCrashDaemon
UID: 501
Process: AirPort Base Station Agent [220]
Path: /System/Library/CoreServices/AirPort Base Station Agent.app/Contents/MacOS/AirPort Base Station Agent
UID: 501
> should I be starting up in 64bit mode?
Are you referring to starting Mac OSX with the 64-bit kernel? If so, the answer is no. See this:
http://blogs.adobe.com/toddkopriva/2010/03/64-bit-kernels-and-after-ef fec.html
A little more information about what FIlipe said:
There are some components that use TCP (a network communication protocol that is also used on the Internet) to communicate. The 32-bit QuickTime server is one of those components. Some aggressive firewalls---which are set up to block certain TCP/IP traffic---block this TCP communication. So, you can tell the firewall to let these components communicate.
So, I had the same problem with AE and other problems with other Apps in the production bundle. I fixed the Quicktime issue by resetting the permissions on the "Authorization Preferences" as well as all the other CS5 Applications. However, now that AE opens and seems to work without a problem, it freezes when I exit and I need to force quit.![]()
I've had no luck. At all. I have the same problem that's reported here: when I start CS5, it warns me that QuickTime isn't installed. AE CS4 is still installed and working fine.
There's no firewall running. I've tried reinstalling three times. I've nuked the preferences folder. I've double-checked permissions.
I'm running OSX Server 10.5.8. I've upgraded a dozen computers to CS5 -- including one that's essentially identical to this one -- and this is the only one having trouble.
