hi,
I am trying to build a sample project which is created in my separate project orhter than sample sxample given by adobe. I created my project in the root directory (c:/97004525/MyProject) and created same directory structure as
C:\97004525\MyProject
-- build.xml
-- applications /SampleTile.xml
--- catalogs
-- descriptor.xml
-- Resources
-- Tiles / SampleTile.swf
and files as build.xml :
<project name="Deploy projects to myserver" default="deploy">
<taskdef resource="mosaic.tasks" classpath="../../bin/mosaicTasks.jar" />
<property name="protocol" value="http" />
<property name="server" value="localhost" />
<property name="port" value="8080" />
<target name="deploy" depends="deploy-catalogs, deploy-applications" />
<target name="deploy-catalogs">
<delete file="sample_catalog.zip" />
<zip destfile="sample_catalog.zip">
<zipfileset dir="catalogs" />
</zip>
<mosaic-catalog action="import" name="sample_catalog"
property="response"
server="${server}"
port="${port}"
username="designer"
password="password" />
<echo message="${response}" />
</target>
<target name="deploy-applications">
<mosaic-application action="import"
name="SampleTile"
file="applications/SampleTile.xml"
property="response"
server="${server}"
port="${port}"
username="designer"
</target>
</project>
SampleTile.xml as :
<?xml version="1.0" encoding="UTF-8"?>
<app:Application name="Basic" label="Basic" xmlns:view="http://ns.adobe.com/Mosaic/View/1.0/" xmlns:catalog="http://ns.adobe.com/Mosaic/Catalog/1.0/" xmlns:tile="http://ns.adobe.com/Mosaic/Tile/1.0/" xmlns:crx="http://ns.adobe.com/Mosaic/CRXTypes/1.0/" xmlns:app="http://ns.adobe.com/Mosaic/Application/1.0/">
<crx:Metadata>
<crx:Description>SampleTile Application</crx:Description>
</crx:Metadata>
<app:Shell name="SampleTile" label="Sample Tile">
<catalog:CatalogReference name="myproject" uri="sample_catalog"/>
<view:ViewManager width="100%" height="100%">
<view:View label="View 1" width="100%" height="100%">
<view:Panel label="Panel 1" width="100%" height="100%">
<view:Layout name="FlowLayout"/>
<tile:TileReference catalog="myproject" name="RetrieveData" label="RetrieveData"/>
</view:Panel>
</view:View>
<view:Layout name="TabNavigatorLayout"/>
</view:ViewManager>
</app:Shell>
</app:Application>
descriptor.xml as
<?xml version="1.0" encoding="UTF-8" standalone="yes"?>
<catalog:Catalog name="sample_catalog"
label="Sample Catalog"
xmlns:shell="http://ns.adobe.com/Mosaic/Shell/1.0/"
xmlns:crx="http://ns.adobe.com/Mosaic/CRXTypes/1.0/">
<crx:Metadata>
<crx:Description>Sample Catalog</crx:Description>
</crx:Metadata>
<catalog:Categories>
<catalog:Category name="Component"/>
<catalog:Category name="Utility"/>
</catalog:Categories>
<tile:TileClassList>
<tile:TileClass initialHeight="400" initialWidth="680" label="Sample Tile" name="SampleTile" catalog="sampleCatalog" fitContent="true">
<crx:Metadata>
<crx:Description>Sample Tile</crx:Description>
<crx:Category>Component</crx:Category>
<crx:Tag>component</crx:Tag>
<crx:Tag>menu</crx:Tag>
</crx:Metadata>
<tile:Content loadAs="default" contentType="application/x-shockwave-flash" uri="/mosaic/catalogs/sample_catalog/tiles/SampleTile/content"/>
</tile:TileClassList>
</catalog:Catalog>
While building I am getting my builds failed as
C:\97004525\MyProject>ant
Buildfile: build.xml
[taskdef] Could not load definitions from resource mosaic.tasks. It could not
be found.
deploy-catalogs:
[delete] Deleting: C:\97004525\MyProject\sample_catalog.zip
[zip] Building zip: C:\97004525\MyProject\sample_catalog.zip
BUILD FAILED
C:\97004525\MyProject\build.xml:20: Problem: failed to create task or type mosai
c-catalog
Cause: The name is undefined.
Action: Check the spelling.
Action: Check that any custom tasks/types have been declared.
Action: Check that any <presetdef>/<macrodef> declarations have taken place.
I don't see any mosaictask.jar in lib folder also don ot gave any wrong name. please help me to come out from this stuck.
Thanks.
I changed path for the mosaictasks.jar to the local root where it reside. it made build successfully
But now I am not able to see the page while I am calling app as http://localhost:8080/mosaic/#/applications/SampleTile .
is this correct path I am giving?
I did not use AIR. But i remember it was instaled while I was installing Flash Builder 4.
But It seems my build is just showing BUILS SUCCESSFUL. But actually it has error in that . Please check below log and tell me error solutions.
deploy-catalogs:
[echo] <?xml version="1.0" encoding="UTF-8" standalone="yes"?>
[echo] <crx:Response timestamp="2010-05-05T15:38:28.118-04:00" method="POST
" result="failure" request="/mosaic/catalogs/sample_catalog" xmlns:crx="http://n
[echo] <crx:Error code="CAT_E40017">
[echo] <crx:Message>Error validating catalog {}.</crx:Message>
[echo] <crx:Key position="0">sample_catalog</crx:Key>
[echo] <crx:StackTrace>com.adobe.livecycle.mosaic.common.MosaicServ
erException: Error validating catalog [sample_catalog].
[echo] at com.adobe.livecycle.mosaic.service.schema.CRXConsumeRequestHe
lper.consumeCatalogDescriptor(CRXConsumeRequestHelper.java:627)
[echo] at com.adobe.livecycle.mosaic.service.rest.catalogservice.Catalo
gServiceImportResourceRestHandler$CatalogServiceAppModelImportFilter.t erminate(C
atalogServiceImportResourceRestHandler.java:150)
[echo] at com.adobe.livecycle.mosaic.appmodel.impl.AppModelFacade.impor
tArchive(AppModelFacade.java:132)
gServiceImportResourceRestHandler.handleRequest(CatalogServiceImportRe sourceRest
Handler.java:84)
[echo] at com.adobe.livecycle.rest.RestRequestRouter.routeRequest(RestR
equestRouter.java:19)
[echo] at com.adobe.livecycle.rest.RestServlet.doAction(RestServlet.jav
a:46)
[echo] at com.adobe.livecycle.rest.RestServlet.doPost(RestServlet.java:
37)
[echo] at javax.servlet.http.HttpServlet.service(HttpServlet.java:637)
[echo] at javax.servlet.http.HttpServlet.service(HttpServlet.java:717)
[echo] at org.apache.catalina.core.ApplicationFilterChain.internalDoFil
ter(ApplicationFilterChain.java:290)
[echo] ... 41 more
[echo] Caused by: com.adobe.livecycle.mosaic.crxm.CRXMException: Parse erro
r consuming Mosaic XML.
[echo] at com.adobe.livecycle.mosaic.crxm.Executive.consume(Executive.j
ava:164)
lper.consumeCatalogDescriptor(CRXConsumeRequestHelper.java:624)
Handler.java:84)
a:46)
37)
[echo] ... 42 more
[echo] Caused by: javax.xml.bind.UnmarshalException
[echo] - with linked exception:
[echo] [org.xml.sax.SAXParseException: The end-tag for element type "tile:T
ileClass" must end with a '>' delimiter.]
[echo] at javax.xml.bind.helpers.AbstractUnmarshallerImpl.createUnmarsh
alException(AbstractUnmarshallerImpl.java:315)
[echo] at com.sun.xml.bind.v2.runtime.unmarshaller.UnmarshallerImpl.cre
ateUnmarshalException(UnmarshallerImpl.java:506)
[echo] at com.sun.xml.bind.v2.runtime.unmarshaller.UnmarshallerImpl.unm
arshal0(UnmarshallerImpl.java:215)
arshal(UnmarshallerImpl.java:184)
[echo] at javax.xml.bind.helpers.AbstractUnmarshallerImpl.unmarshal(Abs
tractUnmarshallerImpl.java:137)
tractUnmarshallerImpl.java:184)
ava:152)
[echo] ... 48 more
[echo] Caused by: org.xml.sax.SAXParseException: The end-tag for element ty
pe "tile:TileClass" must end with a '>' delimiter.
[echo] at org.apache.xerces.parsers.AbstractSAXParser.parse(Unknown Sou
rce)
[echo] at org.apache.xerces.jaxp.SAXParserImpl$JAXPSAXParser.parse(Unkn
own Source)
arshal0(UnmarshallerImpl.java:211)
ava:152)
[echo] ... 48 more
[echo] </crx:StackTrace>
[echo] </crx:Error>
[echo] </crx:Response>
deploy-applications:
[echo] <crx:Response timestamp="2010-05-05T15:38:28.165-04:00" method="POST
" result="success" request="/mosaic/applications/SampleTile" xmlns:crx="http://n
s.adobe.com/Mosaic/CRXTypes/1.0/"/>
deploy:
BUILD SUCCESSFUL
Total time: 0 seconds
There is a typo in the catalog xml associated with the <tile:TileReference> element for your tile. If you have a validating XML editor such as XMLSpy you can view the XML and get a highlight on the error.
To get a build failure in this case, set the failonerror=true flag in the build.xml that is calling the mosaic-catalog task.
Don
