jdemylle
Error with .mpp file generation on 7.2
May 5, 2010 6:20 AM
Dear,
We are facing an issue with PDF generation with 7.2.
For .xls , .doc, .ppt no problem but it doesn't work for .MPP
When I check log files on the server I have those errors:
I don't understand what's wrong.
Thanks a lot for your help.
2010-05-05 14:58:12,761 INFO  [com.adobe.native2pdf.internal.AESEngineBean] AES_1001: Begin processing job ddf90c-86bbbe-c553c5-c1528d-f0b35b-84c0bf
2010-05-05 14:58:12,870 INFO  [com.adobe.service.ProcessResource] BMC505: Service ProjectConverterService: Starting native process with command line "C:\\Adobe\\LiveCycle\\jboss\\server\\all\\svcnative\\ProjectConverterService\\bin\\dll\\pdfgen.exe" PDF-PRd3bd10003 -beginExecutable "C:\\Adobe\\LiveCycle\\jboss\\j2re1.4.2_04_compiler\\bin\\javaw.exe" -endExecutable -Xmx20m -cp "C:/Adobe/LiveCycle/jboss/server/all/svcnative/ProjectConverterService/bin/aaes-idl-bmc.jar;C:/Adobe/LiveCycle/jboss/server/all/svcnative/ProjectConverterService/bin/aaes-jaxb.jar;C:/Adobe/LiveCycle/jboss/server/all/svcnative/ProjectConverterService/bin/adobe-bslj.jar;C:/Adobe/LiveCycle/jboss/server/all/svcnative/ProjectConverterService/bin/appmon.jar;C:/Adobe/LiveCycle/jboss/server/all/svcnative/ProjectConverterService/bin/commonbmc.jar;C:/Adobe/LiveCycle/jboss/server/all/svcnative/ProjectConverterService/bin/jaxb-api.jar;C:/Adobe/LiveCycle/jboss/server/all/svcnative/ProjectConverterService/bin/jaxb-impl.jar;C:/Adobe/LiveCycle/jboss/server/all/svcnative/ProjectConverterService/bin/jaxb-libs.jar;C:/Adobe/LiveCycle/jboss/server/all/svcnative/ProjectConverterService/bin/jniw2.9.5_pdfmapi1.0.jar;C:/Adobe/LiveCycle/jboss/server/all/svcnative/ProjectConverterService/bin/jniw2.9.5_project4.4.jar;C:/Adobe/LiveCycle/jboss/server/all/svcnative/ProjectConverterService/bin/jniwrap-2.9.6.241.jar;C:/Adobe/LiveCycle/jboss/server/all/svcnative/ProjectConverterService/bin/namespace.jar;C:/Adobe/LiveCycle/jboss/server/all/svcnative/ProjectConverterService/bin/ProjectConverterServer.jar;C:/Adobe/LiveCycle/jboss/server/all/svcnative/ProjectConverterService/bin/winpack.jar;C:/Adobe/LiveCycle/jboss/server/all/svcnative/ServicesNatives2/jars/adobe-bslj.jar;C:/Adobe/LiveCycle/jboss/server/all/svcnative/ServicesNatives2/jars/jacorb.jar" com.adobe.native2pdf.bmc.ProjectConverterServer -IOR IOR:000000000000002249444C3A636F6D2F61646F62652F736572766963652F4D616E616765723A312E3000000000000002000000000000006C000102000000000F3137312E32362E3233362E32343300000DC80000000000144A426F73732F42522D31392F0100000000000000000000020000000000000008000000004A414300000000010000001C00000000000100010000000105010001000101090000000105010001000000010000002C0000000000000001000000010000001C00000000000100010000000105010001000101090000000105010001   -AppServer jboss
2010-05-05 14:58:12,886 INFO  [STDOUT] Command line '"C:\Adobe\LiveCycle\jboss\j2re1.4.2_04_compiler\bin\javaw.exe"'
2010-05-05 14:58:13,714 INFO  [STDOUT] myOwnProcesses found 2
2010-05-05 14:58:13,807 INFO  [STDOUT] com.adobe.native2pdf.bmc.ConvertProject starting run()
2010-05-05 14:58:14,057 INFO  [STDOUT] com.adobe.native2pdf.bmc.ConvertProject calling execute
2010-05-05 14:58:14,073 INFO  [STDOUT] Processing document 'C:\Documents and Settings\BIF549\Local Settings\Temp\pdfg-BIF549\dd\f90c-86bbbe-c553c5-c1528d-f0b35b-84c0bf\Project1.mpp'
2010-05-05 14:58:14,682 INFO  [STDOUT] COM PID appears to be 8036
2010-05-05 14:58:14,729 INFO  [STDOUT] Running Project on Windows (32-bit) NT 5.2
2010-05-05 14:58:14,729 INFO  [STDOUT] AlertReturn is true
2010-05-05 14:58:15,369 INFO  [STDOUT] ConversionInterface returned status 0
2010-05-05 14:58:15,369 INFO  [STDOUT] Got default parameter bits 400017
2010-05-05 14:58:15,369 INFO  [STDOUT] Read-Back ConversionInterface returned status 0, bits 4
2010-05-05 14:58:15,369 INFO  [STDOUT] JobOptions from file pdfg Standard 3586
2010-05-05 14:59:55,636 WARN  [jacorb.giop] Abnormal connection termination. Lost 1 outstanding replie(s)!
2010-05-05 14:59:55,699 INFO  [STDOUT] Forcibly shutting down process 8036
2010-05-05 14:59:55,699 WARN  [com.adobe.service.ProcessResource] BMC024: Service ProjectConverterService: Process ProcessResource(name=pdfgen.exe,pid=0) terminated abnormally with error code {3}
2010-05-05 14:59:56,620 ERROR [jacorb] java.net.ConnectException: Connection refused: connect
     at java.net.PlainSocketImpl.socketConnect(Native Method)
     at java.net.PlainSocketImpl.doConnect(Unknown Source)
     at java.net.PlainSocketImpl.connectToAddress(Unknown Source)
     at java.net.PlainSocketImpl.connect(Unknown Source)
     at java.net.Socket.connect(Unknown Source)
     at java.net.Socket.<init>(Unknown Source)
     at org.jacorb.orb.factory.DefaultSocketFactory.createSocket(Unknown Source)
     at org.jacorb.orb.iiop.ClientIIOPConnection.createSocket(Unknown Source)
     at org.jacorb.orb.iiop.ClientIIOPConnection.connect(Unknown Source)
     at org.jacorb.orb.giop.GIOPConnection.write(Unknown Source)
     at org.jacorb.orb.CDROutputStream.write(Unknown Source)
     at org.jacorb.orb.giop.ServiceContextTransportingOutputStream.write_to(Unknown Source)
     at org.jacorb.orb.giop.GIOPConnection.sendMessage(Unknown Source)
     at org.jacorb.orb.giop.GIOPConnection.sendRequest(Unknown Source)
     at org.jacorb.orb.giop.ClientConnection.sendRequest(Unknown Source)
     at org.jacorb.orb.Delegate.invoke_internal(Unknown Source)
     at org.jacorb.orb.Delegate.invoke(Unknown Source)
     at org.omg.CORBA.portable.ObjectImpl._invoke(Unknown Source)
     at com.adobe.native2pdf.bmc._ConverterAgentStub.cleanUp(_ConverterAgentStub.java:54)
     at com.adobe.native2pdf.internal.AESEngineBean.createPDFInternal(AESEngineBean.java:715)
     at com.adobe.native2pdf.internal.AESEngineBean.createPDF(AESEngineBean.java:208)
     at sun.reflect.GeneratedMethodAccessor326.invoke(Unknown Source)
     at sun.reflect.DelegatingMethodAccessorImpl.invoke(Unknown Source)
     at java.lang.reflect.Method.invoke(Unknown Source)
     at org.jboss.ejb.StatelessSessionContainer$ContainerInterceptor.invoke(StatelessSessionContainer.java:683)
     at org.jboss.resource.connectionmanager.CachedConnectionInterceptor.invoke(CachedConnectionInterceptor.java:185)
     at org.jboss.ejb.plugins.StatelessSessionInstanceInterceptor.invoke(StatelessSessionInstanceInterceptor.java:72)
     at org.jboss.ejb.plugins.AbstractTxInterceptor.invokeNext(AbstractTxInterceptor.java:84)
     at org.jboss.ejb.plugins.TxInterceptorCMT.runWithTransactions(TxInterceptorCMT.java:315)
     at org.jboss.ejb.plugins.TxInterceptorCMT.invoke(TxInterceptorCMT.java:148)
     at org.jboss.ejb.plugins.SecurityInterceptor.invoke(SecurityInterceptor.java:120)
     at org.jboss.ejb.plugins.LogInterceptor.invoke(LogInterceptor.java:191)
     at org.jboss.ejb.plugins.ProxyFactoryFinderInterceptor.invoke(ProxyFactoryFinderInterceptor.java:122)
     at org.jboss.ejb.StatelessSessionContainer.internalInvoke(StatelessSessionContainer.java:331)
     at org.jboss.ejb.Container.invoke(Container.java:723)
     at org.jboss.ejb.plugins.local.BaseLocalProxyFactory.invoke(BaseLocalProxyFactory.java:359)
     at org.jboss.ejb.plugins.local.StatelessSessionProxy.invoke(StatelessSessionProxy.java:83)
     at $Proxy149.createPDF(Unknown Source)
     at com.adobe.native2pdf.internal.DequeueBean.handleJob(DequeueBean.java:382)
     at com.adobe.native2pdf.internal.DequeueBean.onMessage(DequeueBean.java:257)
     at sun.reflect.GeneratedMethodAccessor324.invoke(Unknown Source)
     at org.jboss.ejb.MessageDrivenContainer$ContainerInterceptor.invoke(MessageDrivenContainer.java:458)
     at org.jboss.ejb.plugins.MessageDrivenInstanceInterceptor.invoke(MessageDrivenInstanceInterceptor.java:62)
     at org.jboss.ejb.plugins.TxInterceptorCMT.runWithTransactions(TxInterceptorCMT.java:282)
     at org.jboss.ejb.plugins.RunAsSecurityInterceptor.invoke(RunAsSecurityInterceptor.java:90)
     at org.jboss.ejb.MessageDrivenContainer.internalInvoke(MessageDrivenContainer.java:372)
     at org.jboss.ejb.plugins.jms.JMSContainerInvoker.invoke(JMSContainerInvoker.java:914)
     at org.jboss.ejb.plugins.jms.JMSContainerInvoker$MessageListenerImpl.onMessage(JMSContainerInvoker.java:1208)
     at org.jboss.jms.asf.StdServerSession.onMessage(StdServerSession.java:276)
     at org.jboss.mq.SpyMessageConsumer.sessionConsumerProcessMessage(SpyMessageConsumer.java:871)
     at org.jboss.mq.SpyMessageConsumer.addMessage(SpyMessageConsumer.java:159)
     at org.jboss.mq.SpySession.run(SpySession.java:347)
     at org.jboss.jms.asf.StdServerSession.run0(StdServerSession.java:200)
     at org.jboss.jms.asf.StdServerSession.run(StdServerSession.java:180)
     at EDU.oswego.cs.dl.util.concurrent.PooledExecutor$Worker.run(PooledExecutor.java:748)
     at java.lang.Thread.run(Unknown Source)
2010-05-05 14:59:58,229 ERROR [jacorb] java.net.ConnectException: Connection refused: connect
2010-05-05 15:00:21,624 ERROR [com.adobe.native2pdf.internal.DequeueBean] Server Exception null; CausedByException is:
     Unable to commit, tx=TransactionImpl:XidImpl [FormatId=257, GlobalId=xs001811//12013, BranchQual=] status=STATUS_NO_TRANSACTION; - nested throwable: (javax.transaction.xa.XAException); - nested throwable: (org.jboss.tm.JBossRollbackException: Unable to commit, tx=TransactionImpl:XidImpl [FormatId=257, GlobalId=xs001811//12013, BranchQual=] status=STATUS_NO_TRANSACTION; - nested throwable: (javax.transaction.xa.XAException))
2010-05-05 15:00:21,624 INFO  [com.adobe.native2pdf.internal.DequeueBean] Message queued again into job queue
2010-05-05 15:00:21,624 INFO  [com.adobe.native2pdf.internal.AESEngineBean] AES_1001: Begin processing job ddf90c-86bbbe-c553c5-c1528d-f0b35b-84c0bf
2010-05-05 15:00:21,702 INFO  [com.adobe.service.ProcessResource] BMC505: Service ProjectConverterService: Starting native process with command line "C:\\Adobe\\LiveCycle\\jboss\\server\\all\\svcnative\\ProjectConverterService\\bin\\dll\\pdfgen.exe" PDF-PRd3bd10003 -beginExecutable "C:\\Adobe\\LiveCycle\\jboss\\j2re1.4.2_04_compiler\\bin\\javaw.exe" -endExecutable -Xmx20m -cp "C:/Adobe/LiveCycle/jboss/server/all/svcnative/ProjectConverterService/bin/aaes-idl-bmc.jar;C:/Adobe/LiveCycle/jboss/server/all/svcnative/ProjectConverterService/bin/aaes-jaxb.jar;C:/Adobe/LiveCycle/jboss/server/all/svcnative/ProjectConverterService/bin/adobe-bslj.jar;C:/Adobe/LiveCycle/jboss/server/all/svcnative/ProjectConverterService/bin/appmon.jar;C:/Adobe/LiveCycle/jboss/server/all/svcnative/ProjectConverterService/bin/commonbmc.jar;C:/Adobe/LiveCycle/jboss/server/all/svcnative/ProjectConverterService/bin/jaxb-api.jar;C:/Adobe/LiveCycle/jboss/server/all/svcnative/ProjectConverterService/bin/jaxb-impl.jar;C:/Adobe/LiveCycle/jboss/server/all/svcnative/ProjectConverterService/bin/jaxb-libs.jar;C:/Adobe/LiveCycle/jboss/server/all/svcnative/ProjectConverterService/bin/jniw2.9.5_pdfmapi1.0.jar;C:/Adobe/LiveCycle/jboss/server/all/svcnative/ProjectConverterService/bin/jniw2.9.5_project4.4.jar;C:/Adobe/LiveCycle/jboss/server/all/svcnative/ProjectConverterService/bin/jniwrap-2.9.6.241.jar;C:/Adobe/LiveCycle/jboss/server/all/svcnative/ProjectConverterService/bin/namespace.jar;C:/Adobe/LiveCycle/jboss/server/all/svcnative/ProjectConverterService/bin/ProjectConverterServer.jar;C:/Adobe/LiveCycle/jboss/server/all/svcnative/ProjectConverterService/bin/winpack.jar;C:/Adobe/LiveCycle/jboss/server/all/svcnative/ServicesNatives2/jars/adobe-bslj.jar;C:/Adobe/LiveCycle/jboss/server/all/svcnative/ServicesNatives2/jars/jacorb.jar" com.adobe.native2pdf.bmc.ProjectConverterServer -IOR IOR:000000000000002249444C3A636F6D2F61646F62652F736572766963652F4D616E616765723A312E3000000000000002000000000000006C000102000000000F3137312E32362E3233362E32343300000DC80000000000144A426F73732F42522D32302F0100000000000000000000020000000000000008000000004A414300000000010000001C00000000000100010000000105010001000101090000000105010001000000010000002C0000000000000001000000010000001C00000000000100010000000105010001000101090000000105010001   -AppServer jboss
2010-05-05 15:00:21,702 INFO  [STDOUT] Command line '"C:\Adobe\LiveCycle\jboss\j2re1.4.2_04_compiler\bin\javaw.exe"'
2010-05-05 15:00:22,546 INFO  [STDOUT] myOwnProcesses found 2
2010-05-05 15:00:22,624 INFO  [STDOUT] com.adobe.native2pdf.bmc.ConvertProject starting run()
2010-05-05 15:00:22,889 INFO  [STDOUT] com.adobe.native2pdf.bmc.ConvertProject calling execute
2010-05-05 15:00:22,889 INFO  [STDOUT] Processing document 'C:\Documents and Settings\BIF549\Local Settings\Temp\pdfg-BIF549\dd\f90c-86bbbe-c553c5-c1528d-f0b35b-84c0bf\Project1.mpp'
2010-05-05 15:00:23,420 INFO  [STDOUT] COM PID appears to be 1584
2010-05-05 15:00:23,467 INFO  [STDOUT] Running Project on Windows (32-bit) NT 5.2
2010-05-05 15:00:23,467 INFO  [STDOUT] AlertReturn is true
2010-05-05 15:00:24,108 INFO  [STDOUT] ConversionInterface returned status 0
2010-05-05 15:00:24,108 INFO  [STDOUT] Got default parameter bits 400017
2010-05-05 15:00:24,108 INFO  [STDOUT] Read-Back ConversionInterface returned status 0, bits 4
2010-05-05 15:00:24,108 INFO  [STDOUT] JobOptions from file pdfg Standard 3587
