Am try use FlexPMD on big project(about 1000 classes, ~6mb code), same configuration on small project(about 350classes, ~ 1.2mb code) work fine.
FlexPMD lastest - 1.1
Java - 6 ver 19
org.apache.ant_1.7.0.v200803061910
39 <target name="flexPmdWithDefaultRuleset">
40 <flexPmd
41 sourceDirectory="${src.dir}"
42 outputDirectory="${bin.dir}"/>
43 </target>
Buildfile: d:\ant\flexPMD.xml
flexPmdWithDefaultRuleset:
[flexPmd] 05.05.2010 12:48:56 com.adobe.ac.pmd.engines.AbstractFlexPmdEngine loadRuleset
[flexPmd] INFO: Ruleset: C:\Temp\default_flex3199696228101358228.xml
[flexPmd] INFO: Rules number in the ruleSet: 90
BUILD FAILED
d:\ant\flexPMD.xml:42: java.lang.StringIndexOutOfBoundsException: String index out of range: -1
Total time: 19 seconds
While this is not expected, FlexPMD is being used on much bigger applications than this one. It is not size-related.
This issue is likely to be related to a specific piece of code in your project.
Can you try to specify a sub source folder, and maybe isolate a class or a piece of code which makes it break?
Did you send the entire console content?
Thanks for your feedback.
Xavier
I have just downloaded and encountered this error from the most recent FlexPMD version (1.2).
I managed to systematically determine which ActionScript file and (more to the point) which line of code was causing this error for me. I am by no means an Flex/ActionScript/Flash guru so this may not be THE problem but merely one (of many?) which triggers this error.
My ActionScript file contained the line:
[Inspectable()]
Apparently an empty attribute list is a no-no for FlexPMD. Adding any text or even removing the '( )' caused FlexPMD to be happy again
[Instpectable] // no error
[Inspectable(blah)] // no error
[Inspectable()] // EHHHHHHHHHHHHHHNNNNN!!!! StringIndexOutOfBounds!
Hope that helps,
Tim
There seems to also be an issue with having certain xml as a class/instance property.
private static const CHECK_VERSION:XML = <![CDATA[function() { return { appVersion: navigator.appVersion, userAgent: navigator.userAgent, appName: navigator.appName };}]]>;
I had the above code in one of my classes and it caused the StringIndexOutOfBoundsException.
If I set the xml within the class, no exception. But if it was preset as a class/instance property it throws the exception.
