Change text color
Contributor ,
May 07, 2010 May 07, 2010
In Acrobat 8.1.7 I would like to change the text color.
71.1K
Contributor , May 07, 2010 May 07, 2010
I appreciate your suggestion but it didn't work for me.
Here's how I did it:
Clicked on TouchUp Text tool
Clicked on and selected text (Command A)
Control clicked to open TouchUp Properties popup menu
Clicked on the Text tab
Clicked on Fill color for No Color popup menu (don't know why it says "no color")
Selected a color.
Mentor ,
You can Change all text after the fact, by
  1. Clicking on Select arrow in memnubar the going to menu and choosing Edit menu > select all (or command A should work).
  2. Then right click and from popup menu choose properties.
  3. choose appearance (should allow you to change font color but not fonts used)
you can change individual words by
  1. clicking on Text edit button in menu bar shows a T in small caps.
  2. Then highlight word or desired words and right click and choose properties.
  3. Then choose Appearance. you can change color from there.
The ideal way though is my changing color in original Document first the create a new PDF. If the PDF has been made into a Form do the following:
after you have edit original docoment
  1. save as a slightly different name as a PDF.
  2. Open orignal PDF choose document from Main menu choose replace Pages
  3. Start from first page and choose replace all pages.
If nothing changed except text color then you form field will saty as they are.
Contributor ,
Selected a color.
Mentor ,
As long as you figured what to do is all that matters. You did much as I said except I was referring to use of the mouse to do the slecting of desire text. But the way did id okay as well.
Except that you told him the totally wrong tools to use...
Mentor ,
May 08, 2010 May 08, 2010
How so? click on text edit tool as shown.     ⬇
Then ......
Click Fill
If the Color you want is not there, the click Other Color and you get this......
This the Apple Color Picker choose any method at the very top of Picker it pick any color.
Exact steps I suggested ( just didn't put the illustrations)
You can click on the select Tool, use Select all from edit menu and then click on Properties and follow the same steps.
May 09, 2010 May 09, 2010
Erm. You said the select tool bot the text edit tool. That's all I'm saying.
Mentor ,
May 10, 2010 May 10, 2010
You can click on Select tool Acrobatpicture001.pngand then to edit menu and Select ALL and choose properties then you could change all the text color.
But you can choose the Text Edit Tool Acrobatpicture002.pngto change color on individual words or phrases.
And yes I guess I did  have a bad Proof reading time.
