Is Photoshop Elements 5 compatible with Windows 7?
May 10, 2010 May 10, 2010
I would like to install PSE5 on my new PC computer using Windows 7. Is it possible?
Message title was edited by: Brett N
39.1K
LEGEND , May 10, 2010 May 10, 2010
If after installing the 5.0.2 update (required) you have problems (most people don't), try running PSE in XP compatibility mode:
http://www.johnrellis.com/psedbtool/photoshop-elements-faq.htm#_Run_in_Vista
Guest
The version which is officially stated as being compatible with Windows 7 is PSE 8. Earlier versions may install fine on Win 7 but they arent certified because those were in the market before Win7.
For specific issues, if any with PSE5, may be other users on the forum can add more..
ankush
OK. Thanks a lot.
Many users report PSE5.0.2 working properly under Windows 7
Aug 16, 2011 Aug 16, 2011
I am running Win7 Premier (64bit) and trying to use PSE 5.02. When I try to start the program I get "Cannot load fastcore routines, file not found" any ideas or help would be appreciated. Thanks
There are things in this thread that seemed to fix the problem on Vista, so maybe it'll work for you on Win 7:
http://forums.adobe.com/message/2086719
The solutions suggest that some of what PSE needs to run is inaccessible, either because permissions have denied access or that the path to look for them in has changed.
Thank you. I'll let you know if it works
Adobe Employee ,
Nov 12, 2012 Nov 12, 2012
Contributor ,
Depending on your version of Windows 7, you may be able to use M$'s "Virtual PC" and Install "XP Mode". This requires Windows 7 Professional, (or better). It cannot be used with Win 7 starter or Win 7 Home Premium. This is a virtual machine solution, and when implemented, you have a full version of Windows XP Pro 32 bit, running in the virtual machine environment.
Guest
Some of the problems that you might encounter while using PSE5 and Win7 are that the e-mail client compatibility issues.
Oct 19, 2014 Oct 19, 2014
I viewed this technology an it stats that it will work on all versions of windows 7. Do you have personnel knowledge that other versions of Win7 will not work?  Respectfully submitted always.
