Hi there:
I'm having the same problems and its frustrating me to pieces. I'm on a really tight deadline and am a fairly new Priemiere user. I tried importing the project into After Effects. I do get an error, but everything seems to load in. The timelines are not AVI's so how does AE read them and how did you encode from there? I don't know how to use AFter Effects yet.
I cannot believe this. I waited until there had been patches etc.. Adobe e seminars raved about the product. Used the Clean uninstall tool to completetly remove all other Adobe products, not just CS3. Then did a clean installation. All looks well. Worked for 4 days on my project. Loving it!!! Try to export - not really an unreasonable objective, I would have thought and Media Encoder will not export. What the hell is this?!?
Now I read in this forum that Adobe have known about this problem for some time and not done anything about it, apparently. ![]()
Hello:
I have figured out a work around that is not particularily technical, but
its working for me. My project is one and a half hours long. Its intended to be
authored. So I have many bins full of different media, tons of titles and
14 timelines. Now the timelines and the renders are the issue I'm finding.
If your project is big, try this. Adobe felt I could have corrupted project files,
but I've discovered but they are not.
Exit CS4 and create another project folder. THen go to open your main
project. Resave it into the new project with a different name so you always
have a copy (Make sure you have a copy of the original too). If you don't
have the ability to delete a number of timelines from your project folder,
then I would suggest cut your project up. Yes, cut it up in parts that you
can knit back together in Encore. Also make sure that your preview folders
do not collectively exceed 85GYGs. If they do, delete some and only render
out the section you want to export. Now try going to the encoder. It works
for me so far.
Repeat this for the remainder of your project.
We should not have to do this, but what option do we have. I have 6 weeks
into my project and 6 more to go. Good luck and let me know how it goes.
CZorn
^^ Im having the same problem on my MacPro and im NOT using any Native Instruments VSTs and mine is doing the same thing.... once i try to export adobe premiere cs4 project and Media Encoder opens up, the error message i get is :
- Source File: /Users/..../Library/Caches/TemporaryItems/TEST.prproj
- Output File: /Users/..../Desktop/Sequence 01.mov
- Preset Used: 1280x7200 PhotoJPEG @ 23.976
- Video:
- Audio:
- Bitrate:
- Encoding Time: 00:46:16
Sat Nov 8 01:16:24 2008 : Encoding Failed
then a error box "(!) The native instruments folder has not been found ... when i click OK it doesnt do anything and when i try closing Media Encorder CS4, i have to force quit because its not responding.. but the error Native Instruments is still there and wont go away.
PLEASE HELP, ive been trying for 3 days moving plug ins etc... and reinstalling and nothing works.. i dont have cs3 and
Welcome to the forum.
Besides the cited Native Instruments, what about Soundflower? Baring those two programs, there are tons of VST's, especially the "instruments," that cause issues with loading. Have you tried launching several times? Depending on the # of offending VST's, it could take a dozen re-boots, before the blacklist is fully populated.
Good luck,
Hunt
I work on PC and have a Premiere CS4 project which has dynamically linked AE compositions in its timeline, with voiceovers on the audio track. When I export, AME will launch and will export when I click start queue. When I play the export file, whatever the format the audio plays all the way through but only a small selection of composition footage will play, the majority of the video is just a dark screen. Very frustrating. I used CS3 up to a few weeks ago, but my new job requires me to use Production Premium CS4, and I'm not impressed with it.
This would probably be a great topic to post anew, as the people replying might get confused on exactly where this fits into such an old thread, with many other problems.
When you do, I'd also post as much info, as is possible, to keep the questions to a minimum, and give people material to work with. They will get right to your problem much more quickly. This ARTICLE will give you some tips on the types of info that would be so very useful.
Now, maybe one of our tireless MOD's can split this out to a separate thread, but you might want to add a bit more detail.
Good luck,
Hunt
this is sooooo frustrating... i have a clean copy of Premiere CS4 and never installed CS3 on my Macbook pro and it wont allow me to encode my videos. Everytime i export the media from premiere to media encoder, it keeps giving me the (!) error
- Source File: C:Users.....AppDataLocalTempSuperman Spoof 1.3.prproj
- Output File: C:UsersanthonyDocumentsAdobePremiere Pro3.0Sequence 01.wmv
- Preset Used: Custom
- Video:
- Audio:
- Bitrate:
- Encoding Time: 07:47:43
10/25/2008 2:40:26 AM : Encoding Failed
Could not read from the source. Please check if it has moved or been deleted.
- Source File: C:Users......AppDataLocalTempCopy of Superman Spoof 1.3.prproj
- Output File: C:Users.......DocumentsAdobePremiere Pro3.0Sequence 01.mp4
- Preset Used: Apple iPod Video Large
- Video:
- Audio:
- Bitrate:
- Encoding Time: 07:51:40
10/25/2008 2:44:24 AM : Encoding Failed
- Source File: C:Users.......AppDataLocalTempCopy of Superman Spoof 1.3_1.prproj
- Output File: C:Users........DocumentsAdobePremiere Pro3.0Sequence 01.mp4
- Video:
- Audio:
- Bitrate:
- Encoding Time: 07:52:09
10/25/2008 2:44:52 AM : Encoding Failed
- Source File: C:Users.......AppDataLocalTempCopy of Superman Spoof 1.3_2.prproj
- Output File: C:Users........DocumentsAdobePremiere Pro3.0Superman 1.3.mp4
- Video:
- Audio:
- Bitrate:
- Encoding Time: 07:54:46
10/25/2008 2:47:30 AM : Encoding Failed
Then another error [ The native instruments folder has not been found do you want to..." and a OK button.]
But when i click OK it doesnt go away.. im not using nor have native instruments installed anymore since i deleted them all in my system
HELP PLS!!
You seem to have the best knowledge of the issues with exporting projects from Adobe Premiere C4 and being forced into using Adobe C4 Media Encoder.
If you truly have found a solution, please let me know via email or forum.
I have a 7 min video project, editing in Premiere C4... and everytime I try to export into .avi for any format, Media Encoder sits there.
I have tried preferences, everything I can think of. Again, I stuck with video that does work with encore, but I need much larger file
video project formats, even flv for the internet...IN SHORT HELP.... FYI.. It does work most of the time if I add a complete video file,
then encode, it works MOST OF THE TIME.
thanks so much.
ernie.sigmon@ssvideoconcepts.com
828-778-4854
Copyright © 2012 Adobe Systems Incorporated. All rights reserved.
Use of this website signifies your agreement to the Terms of Use and Online Privacy Policy (updated 07-14-2009).
