When loading PPro CS5 - my splash screen gets stuck on "Loading ExporterQuickTimeHost" -- for, really, about five minutes. This is not an exaggeration. I've timed it multiple times. The shortest was four and a half minutes, the worst about seven minutes.
After Effects does the same thing -- stuck on "Loading MediaCore." About the same time delays.
Photoshop and InDesign load without issue.
My system is a three month old Intel i7 with 8 gigs of DDR3 ram along wth an unsupported NVIDIA graphics card with more CUDA cores than the lowest supported card. Meaning, this isn't some ancient awful system.
Any thoughts or ideas?
Thanks.
Please run my Premiere Pro Benchmark PPBM4 (yes I know it was designred for CS4) but since Harm has run it sucessfully on CS5 it will tell us how well you machine/OS is tuned and/or configured.
It's your firewall blocking connexions for the file named dynamiclinkmanager.exe who is located on C:\Program Files\Adobe\Adobe Premiere Pro CS5\32.
Add a rule to allow dynamiclinkmanager.exe at least on your local system.
Ooops I forgot the other file named Adobe QT32 Server.exe on the same folder
Phil
My thanks. All Adobe functions have all permissions with my firewall. I also checked the specific applications you cited and they have local and web permissions.
I'm grateful for any further thoughts you, or anyone, may have. It would be wonderful if I could avoid the whole uninstalle/re-install everything thing.
My thanks for your note. This is a three month old Dell Studio Intel i7 system with nice everything. Additionally, the only issue with Premiere is the start up thing -- after that it performs fine. So, I think it's pretty clear it's not system capability thing, but rather some kind of software conflict somewhere -- that I had hoped someone else had encountered and resolved.
Again, my thanks for your note.
If you follow this link and then continue to the second included link, there are a number of data requested, like Process Explorer and DXDIAG: Some suggestions...
If you post those as screenshots and attachment, we can have a look at what may be wrong.
Same problem here.
AfterEffects pops up message "No QuickTime installed" after mentioned delay.
And I have QT 7.6.6 Pro installed and fully working.
Premiere stops loading at ExporterQuickTimeHost.prm, or something like that. Then continues after several minutes... Then stops at QuickTime importer. Then continues after several minutes. Then when you are in Premiere you can not import or export MOV. ![]()
I'm using Windows7 Ultimate.
Any ideas?
QT 7.6.3 & 7.6.4 had issues with Adobe programs, just as 7.5.3 & 7.5.4 did. I had heard that 7.6.6 was a good version, but have to admit that for me, 7.5.5 was the "last known good." Wonder if 7.6.6 is following in the footsteps of its recent predecessors? Maybe try with a copy of 7.5.5.
Good luck,
Hunt
A couple questions - do you have any 3rd party (non-Apple) codecs installed? If so, what are they?
If not, do you have a firewall or antivirus app installed and if so, which one(s) do you have?
Any other pre-CS5 apps running at the time? (say, previous version of Premiere or AE).
There is interprocess communication that occurs between the applications (AE, PPro, AME) with dynamiclinkmanager.exe, as well as between the quicktime application itself (Adobe QT32 Server.exe), which needs to interact via tcpip. It's also possible that there is a quicktime codec installed which is getting invovled, knowing which part is being grumpy would be really great.
-EricS
Clean installation of Win7 x64.
Using NOD32.
Using Comodo firewall.
No other Apple apps.
No 3rd party codecs.
No other Adobe apps running.
BUT when I diable Firewall it works with no problem.
BUT I need Firewall.
What App or IP address I need to unblock in firewall to get CS5 and firewall running together?
EDIT: It seems I need to unblock Premiere and QT server.
You may experience something similar when launching Adobe Media Encoder as well. Another application which will use a similar mechanism for communicating is PProHeadless.exe (also found in the Premiere application folder). It sounds like you're up and running now without the slowdowns though, glad to hear it!
-EricS
Along those lines, I am on a DSL connection, though behind a hardware firewall, between the connection and the workstation, and NOT within the workstation. In 15 years, I have never had one breech. Maybe I have just been fortunate, but also have zero Internet presence, while editing, and my guard (software) is down.
Just an observation,
Hunt
yeah it's these: Adobe QT32 Server.exe thing.
for hours and hours i installed/uninstalled CS5 suite on a computer without internet connexion. then i installed it on a laptop with connexion and watched my firewall. premiere.exe, Adobe QT32 Server.exe and dynamiclinkmanager wanted network-access. i allowed it Adobe QT32 Server.exe and premiere started without any delay!!!
adobe what's this? i always need internet to use premiere, after FX, encore because of quicktime?! where can i fix this?!
Those components are separate (necessary) processes that are part of the Adobe suite. Adobe QT32 Server, in particular, is required for anything Quicktime related - since Apple hasn't upgraded Quicktime to 64 bit, we were forced to put Quicktime support routines in a 32 bit process. Meanwhile, Premiere runs in a 64 bit native process.
In order for these processes to communicate with each other, they rely on TCP IP internally, communicating through 'localhost', which is your local machine. I don't know why your firewall insists on blocking that port - as far as I'm concerned, it shouldn't. Your firewall should be concerned about blocking incoming connections from outside ports, not what's going on locally in your machine.
Wil Renczes wrote:
...I don't know why your firewall insists on blocking that port - as far as I'm concerned, it shouldn't. Your firewall should be concerned about blocking incoming connections from outside ports, not what's going on locally in your machine.
hey wil,
no, on the computer without internet connexion there is no firewall. so nothing is blocked. i noticed it on the "internet-computer" that comments any network activity over tcp/ip.
in the meantime i activated tcp/ip on the other computer, connected a lan-cable but nothing changed. it took about 5 minutes to start up premiere (encore, afterFX).
my question: what more windows services are needed? could there be any conflict, when cs5 is not installed at the windows system partition, but on my program partition? is there any .log written when i start premiere?
definitive there is problem with loading "C:\Program Files\Adobe\Adobe Premiere Pro CS5\Plug-ins\Common\ImporterQuickTime.prm". i watched the Plugin Loading.log of premiere, encore, afterFX. what's up there?
Over six minutes for Premiere and After Effects to load this morning. All Adobe
applications have full permissions in my internet security programs.
This is outrageous. I've just paid a small fortune for programs that loads slower than "Return To Castle Wolfenstein" on my Apple IIc.
Is there a way to disable "ExporterQuickTimeHost" in Premiere? Any other solutions come to mind for After Effects? (I haven't yet messed with Encore) Are there specific ports that I can do something about to fix this situation?
Did you obtain the information that Harm asked for in post #6? If not, please do so. If so, please post it to help us help you.
Until you accomplish all of that, I have one thing for you to check. I'm guessing blind here, but it's a reasonable guess: Do you have any real-time or full-time anitvirus scanners running? If so, disable any scan-on-access type of setting and try launching again.
If that fails, then Harm's link is the way to proceed from here.
-Jeff
All:
I just installed the trial version of CS5 Production Premium.
When I try to start PProCS5, the splash screen appears; then nothing. No indicator that anything is loading.
After reading the post I opened the firewall for Quicktime and Dynamic Link; still nothing.
I am in locked down environment as far as antivirus is concerned (on-access scanning is enabled by sysadmin, unable to change setting)
Running Windows 7 Enterprise
Dell XPS
i7 965 3.20 Ghz
6 GB RAM
Dual GTX 285 cards
Any clues other than those already in the post.
We have a number of machines in this configuration running in a University graphics lab and were going to install CS5 this summer; but if I can't get Premiere to run; we'll stick with CS4
Norm
Norm,
You say that the Splash Screen appears, but there is no indication that anything is loading. Are you looking at the little line of text that indicates each library and module? It is tiny, and can go by quickly, so that most people miss it.
OTOH, if there is not such, then it would seem that the hang is initial, and not along the loading path of the elements in the program.
Is the video and audio driver updated?
Is QuickTime Player updated?
Just thinking there, but good luck,
Hunt
I'm getting a slow start-up too.. I uninstalled Production Premium CS4, installed CS5, and Premiere Pro takes a lot longer to open a Project - maybe a few seconds more to prompt for a Project, but 4 or 5 times longer to open a selected Project. Most of the time after selecting Project is a blank screen. I'm not technical but am interested if someone finds a reason thanks.
sja111 wrote:
I've just uninstalled Production Premium CS4 and installed CS5 (same PC). CS4 Premiere Pro took about 8 seconds to prompt for a Project and about 6 seconds to open it. CS5 iks taking
less than 10 more seconds another 5 or 6 seconds to open 5 seconds to load Premiere Pro have aon a Wind7 x64
PC
GRATULATIONS!
got the same (or likely the same) results an my laptop - but not on my PC (win7, 64-bit).
Bill Gehrke wrote:
Please follow Harm's suggestion in post number 6 and show us what you have running before you try starting to run Premiere.
in fact: I really don't know what kind of informations you mean. in post 6 there's nothin' to find...
important for me is: i had a running CS4 and now a hanging CS5. that's it.
@Bill Gehrke : I've tried starting with SLI enabled and disabled; no difference.
@Bill Hunt: You're correct that the hang is on initialization....there is no tiny text showing modules loading. All other Production Premium components I've tried start fine (AE, PS, AI ... Encore is disabled in the trial version). All QT, video, audio drivers are up-to-date. Win7 has all patches installed.
I have CS4 Master Collection. Could that cause a problem? The only case in which I thought CS4 might be in conflict is with Photoshop 64-bit. CS4 Premiere seems to be working fine.
As I mentioned my machine, with the exception of Visio, Lotus Notes, and AutoCad, is configured identically to 8 machines in a graphics lab. I'm the fortunate tester for CS5.
Also...task manager shows dynamiclinkmanager.exe loaded using approximately 5500K memory; CS5 showing about 43,000K; CPU usage is 13 (which I'm sure must mean something is wrong ![]()
TIA for your help so far.
Norm
OK here is a simpler way to find out what you have running. Do a CTRL-ALT-DEL and select your Task Manger and select the Processes Tab. Here is what you will see, except you probably will have more than twice as many processes running. An untuned Win 7 installation can easily have 70 processes or more.. Be sure to have show all processes checked and stretch the window so we can see all of them. Do this after booting up and without running any other software or Adobe software.
dear bill, i thank you very much for your help. but i can't see, how it helps me, when i find out my runnin' processes. i think it's a problem of permissions on folders or in the registry or something like that. for example:
in one of these endless installing/uninstalling procedures i decided to delete every adobe folder on my disks. although i used the flashplayerplugin_uninstall utility (with admin rights) i still found the folder "macromed" in the "sysWOW64" folder. it was undeleted and i first had to take ownership before i was able to delete.
my solution: i will install a "fresh" windows and pray...
Good luck,
Hunt
FINALLY IT RUNS!
my solution was to install quicktime 7.6.6. thx to all the guys here!
I have a similar start up problem with Adobe Premier CS5 - which freezes on startup at the point of trying to load Exporterquicktimehost.prm
I am using Windows 7 Ultimate (x64) on a Toshiba X506 laptop. I do not have Quicktime installed (although it has been in the past)
My firewall is Agnitus Outpost Pro. When I suspend the Firewall, Adobe Premiere loads with absolutely no problems.
I have specifically "allowed" full access to files dynamiclinkmanager.exe and Adobe QT32 Server.exe. This did not solve the problem.
Obviously some other Adobe Premiere-related application is being blocked by my firewall, but after some experimenting, I have not been able to discover which aplication it might be. I am a bit of a novice, so any suggestions/assistance would be very much appreciated.
Regards
geoffwm
Hey geoffwm, have you found the solution for your problem yet? if not here is my solution.
After i've been reading the event viewer on outpost pro and i've found out that you need to Allow All Activity for
premiere.exe and after effect.exe
dynamiclinkmanager.exe ===> 1 for premiere and 1 for after effect
Adobe QT32 Server.exe ====> 1 for premiere and 1 for after effect
for premiere and after effect to work. It worked for me and i hope it will solve your problem as well.
I have set UAC back on, but then had to change the shortcut that runs some of the programs to "run as administrator". The programs that were affected were Premiere, Encore, After Effects, and one or two others. The account that I use has full administrator privileges.
I am running Windows 7 Professional 64 bit.
I would agree that it is a bug, but I don't know what it is about my installation that caused this to happen. I spent 3 hours with Adobe Tech Support and as usual they had no clue.
I finally figured out the answer myself.
Somebody has to do something about those people in India. The first person
I spoke too had bad English skills and seemed like a trainee. My time with her
was a waste. The second person I spoke to seemed knowledgeable, but did not fix the problem. He was grasping at straws when he asked me to change the wallpaper and disconnect the other 2 machines on my LAN.
This is a very expensive piece of software and the level of installation support is unacceptable.
I have sent in a bug report. Does anybody read them?
Steve,
Adobe takes both the Bug Reports and the Feature Requests seriously. For the Bug Reports, the more detail that one can furnish, the easier it is to replicate the issue in the lab. Usually, unless more info is needed, there will likely be no direct contact, but work is being done.
As for T/S, Adobe has promised to make improvements. Going way back, Adobe T/S was almost the paradigm in the software industry. I had few issues, but those few were handled professionally, quickly and correctly. Over time, things changed, and apparently not for the better. I have not needed to use T/S in many years, but do read the horror stories. It does seem as though the people in the call center are not actual users of the products, and have a rather limited "script." This is from the myriad reports and NOT from first-hand experience.
As a change of the magnitude that I imagine, it would take some time and effort, all I can offer is "be patient, and let's hope that Adobe is planning on changing things in a positive way." I'd love to hear that Adobe T/S (and C/S) was back to the way it was in the "good old days." Until then, I feel that this forum (and the one for PS, AI, et al) are the better places to get T/S. We are also blessed to have an Adobe technical presence here, as that was not always the case. [Many of us spread rose petals at the feet of Jeremy, Dennis and Wil... ] ![]()
Good luck,
Hunt
http://blogs.adobe.com/acom/2009/09/repairing_adobes_customer_serv.htm l
This link is to a letter sent out Sept 9 of last year. I am going to call Lambert Walsh when this weekend is over.
It is almost 9 months since the letter and I have seen no change.
Bill:
And by the way why are 2 old guys like us still messing around with this stuff? That picture of me in my profile is from a long time ago.
Steve,
That was the statement, to which I was referring. In the major corporate world, 9 mos. is the blink of an eye, especially when one has a large investment to try and recoup. Unfortunately stockholders might not be users with issues. I know that is not comforting to us users, but is an unfortunate fact of life nowadays.
I just hope that they can get things back on track - before I need to use T/S again... ![]()
Hunt
Yes, I read them every day, and I'm not even the intended recipient.
We are well aware of the experiences users have had with support. I already commented somewhere that I cannot elaborate any further.
That says it.
Please comment to him as you see fit.
Please.
I don't have access to those case numbers, but if you have logged a bug via the site, I'm sure I've seen it.
I am not affiliated at all with tech support, except that we have the same employer.
si conehead wrote:
My incident number with tech support is 181615319 if you are able to look at it.
I am pleased to say that I have categorically solved this problem (at least on my system).
It is indeed to do with the various components needing access to the local subnet.
My situation was as follows:
OS: Win7 Pro 64bit.
Firewall: Comodo Internet security 3.12
Premiere Pro CS5
Launching Premiere resulted in lengthy (5+ minutes) hang with splash dialogue showing the stall was on "Loading ExporterQuickTimeHost". This also happened with Adobe Media Encoder.
After reading this forum I looked in my firewall block/allow list for dynamiclinkmanager.exe and Adobe QT32 Server.exe but couldn't find them.
I had, however, blocked Premiere from accessing the internet (I don't need it to, so that's my default security policy) only it wasn't actually asking for access to the internet (I realise now) it was merely asking for access to the local subnet.
When I installed an update to Comodo Firewall, (4.1 - though this is'nt actually relevant) I realised what the problem had been as the security policies got wiped (forgot to back them up) and needed to be re-learned from scratch.
As I launched Premiere, Comodo popped up a dialogue saying that Premiere wanted access to the local subnet (I read it this time!) and I clicked 'Allow'.
Premiere's splash screen got to "Loading ExporterQuickTimeHost" and THEN dialogues popped up for Adobe QT32 Server.exe and dynamiclinkmanager.exe - both asking for the same local subnet access.
This had never happened before, because blocking Premiere itself from subnet access stopped these from also asking.
And 2 WHOLE SECONDS LATER ..... Premeier desktop was there awaiting my instructions!
I believe I may have uttered a "woo" and a "yay" at this point.
I trust you, dear reader and fellow sufferer, will also have the same joyous experience. ![]()
"I had, however, blocked Premiere from accessing the internet (I don't need it to, so that's my default security policy) only it wasn't actually asking for access to the internet (I realise now) it was merely asking for access to the local subnet."
You do not need the patches that are released?
Copyright © 2012 Adobe Systems Incorporated. All rights reserved.
Use of this website signifies your agreement to the Terms of Use and Online Privacy Policy (updated 07-14-2009).
