xalexas
CS5 drag layers between tabs
May 12, 2010 1:46 AM
On this page http://www.photoshopuser.com/cs5/cs5-features I have read that Adobe finally have implemented "Drag a layer from Layers panel to another open document tab". Is this true, cause I can't make it work? I can do that in floated windows interface but in tabed it's not possible (as in CS4).
Can somebody from Adobe confirm this please?
    Community Member
    May 12, 2010 9:19 AM
    good question
    Community Member
    May 14, 2010 11:15 AM
    I think it is still broken. I cannot figure out how to do it in CS5, either. I have tried all wonder  of keyboard shortcuts but alas, nope. As far as I can tell in my first week of use, all of the things broken aboout the tabs in CS4 are still broken in CS5. What a shame.
    Community Member
    May 14, 2010 5:03 PM
    Not as easy, but just select the layers you want in the layers pallet, right click and “duplicate layers” to your chosen file…
    Community Member
    Or “tear off” the tab of the document you want to copy from…
    Community Member
    May 14, 2010 9:38 PM
    Duplicating or copying does not work for adjustment layers or layer styles.
    Community Member
    May 14, 2010 9:44 PM
    Tearing off the tab first is just a pain. Is there a way to just open all files in thier own window, and never consildate them? I think it used to be that way before the browser bozos insisted on this feature. thx!
    jigs
    Adobe Employee
    May 14, 2010 9:46 PM
    In preferences, turn off "open documents in tabs". (first thing I do after a new install)
    Community Member
    May 14, 2010 10:51 PM
    First thing I do in CS4 too.
    Community Member
    May 15, 2010 6:17 AM
    great tip, thx! It should be the default.
    Community Member
    May 17, 2010 12:55 PM
    Charles:
    Yes it does. If it doesn't work for you it's probably because your documents have a different colour mode than each other (CMYK to RGB for example).
    Community Member
    May 17, 2010 1:34 PM
    NIles:
    No it does not. In CS5 you can not drag from the Layer Panel to a tabbed document. It was supposed to be a feature, but for some reason it got pulled. You can drag a layer from the image area  to a tabbed document. You can drag from the Layer Panel to a floating document, but you can not drag from the Layer Panel to a tabbed doc.
    I have "Open Documents as Tabs" turned off in preferences for this and other reasons.
    Adobe Employee
    Jun 4, 2010 1:34 PM
    xalexas,
    This feature was part of the JDI ("Just Do It") initiative from last summer. The JDI was intended to add small highly desired features which could be implemented in a short period. This feature was implemented during that time. Late in the CS5 cycle, a bug was discovered which presented us with the option to either fix it or drop it. Since the fix had the possibility to destabilize the application we chose the safest route and dropped the feature. We know this has been a feature many of you have requested for a long time and we are very disappointed it was dropped.
    Sincerely,
    John
    Community Member
    Jul 25, 2010 2:46 PM
    The following procedure works for me in Windows:
    1. Select the layer(s) to be moved.
    2. Control-Click in the image window
    3. Drag to the destination tab
    4. Hold over tab until it lights up
    5. Continue to hold the left mouse and Control and drag into the image.
    6. A + will appear.
    7. Release the mouse button and then the Control Key.
    Community Member
    Jul 25, 2010 9:44 PM
    Hey thx for posting that! I tried on my mac, with mixed results. Multiple layers is almost impossible to drag accuratly (clicking on the image after selecting multiple layers seems to be the problem), and all in all it's hit and miss with no indication that the layer is ready to be dropped in the other tab (ie. + sign).
    Community Member
    Jul 25, 2010 9:54 PM
    It is important to hold the Control key while dragging.  Then hold the Move Tool arrow over the tab until it becomes selected.  Once this happens, continue holding the Control key and the left mouse button, and drag down to the image waiting until the + appears.  Then release the mouse button and finally the Control key.  I believe that you will find that it works well if the procedure is followed carefully.  Good Luck!
    Community Member
    Oct 7, 2010 5:54 AM
    Note that on the Mac it's the Command key, not the Control key. This works for me on my Mac with CS5.
    Community Member
    Jan 9, 2011 12:34 PM
    I had the same problem in dragging a layer to another tabbed document.I read other comments and tried my luck. After some trials I made the following
    observations.1, NO you don't really need to use Control or Command keys at all.(Make sure you are dragging a layer and NOT the background as you ca'n't
    move a locked background.)With Move tool drag the layer to the selected Tab and the dark grey Tab lights up  and turns white but do NOT release the mouse
    yet.At this point observe the contents of layer disappear leaving the light grey border around it visible. You will also notice that as soon as the Tab lights up the new document replaces the previous file in the image area. Now while still holding the mouse down bring it back into the new document and then ONLY THEN release your mouse. That's it! Seeing your layer disappearing when the Tab lights up you might think that you have lost the move action and that you have failed  THAT IS A MISTAKE! (I noticed the black arrow was replaced by move tool icon but no + sign on releasing the mouse). 2. You can use Control key but first press the mouse button and then press the Control.3,Command key also works.I have a mac and CS5.
    Community Member
    Jan 10, 2011 1:02 PM
    Chris Cox: In preferences, turn off "open documents in tabs". (first thing I do after a new install)
    You are not alone Chris, since everyone I know does the same.
    John Edward Hanson: Since the fix had the possibility to destabilize the application we chose the safest route and dropped the feature.
    After the CS4 and CS3 interfaces were put together, many of us were scratching out heads about some basic logic problems, and a flappy insubstantial feeling about the whole result. The fact that a change like this can actually destabilize the whole app, this is a further indication that something basic was wrong. Reading quite a lot between the lines, there were a few within the Adobe camp who clearly just hated the great and simple interface that already existed.
    Instead it ended up finding some big holes?
    Community Member
    Jan 28, 2011 9:05 AM
    I have never gotten this to work with CS4 or CS5, using any instructions or tips posted here or elsewhere. It simply doesn't work for me at all.
    I don't have a strong opinion about the tabbed interface either way (I can take it or leave it), but I was forced to turn it off since I drag layers between images all the time.
    Community Member
    Jan 28, 2011 9:18 AM
    Clearly, if an option for a  tabbed interface was going to be implemented, it should have NEVER been made the program default. The tabbed behavior should be the one you have to dig through the preferences to try. It seems to be another interface decision made by someone completely unfamiliar with how many professionals actually work. Of course, it's the first thing I turn off as well, but one should never have to do that in the first place - or read about how people can't drag between documents. The very fact that there are so many discussions about this very topic proves the point that common sense ain't so common.
Legend
  • Correct Answers - 10 points
  • Helpful Answers - 5 points
