I'm looking
a way to import questions from a delimited text file (or excel spreadsheet)
into captivate.
All the questions are simple multiple choice, single answer, four selections per question.
I have hundreds - I'd hate to have to retype them all in one at a time.
Thanks in advance
-Joan
Hi there
I am unaware of any means to accomplish that. I've never seen it done.
Cheers... Rick
Helpful and Handy Links Captivate Wish Form/Bug Reporting Form |
Hello,
As Rick points out, certainly not an easy way for the moment. But that doesn't mean you have to 'retype' all.
Was thinking of this workaround:
A similar workflow could be used with a XML-file (but I'm more comfortable with the Word-version)
Lilybiri
Does anyone know if this is a feature in Captivate 5.
Other things I would really like to see in Captivate 5.
Importing and Exporting the graded quiz/test content out of captivate into another
application/ form. Such as xml, tab delimited, excel spreadsheet,
Adobe pdf, Word document or another format. Our current content
developement systems allows us to (when publishing) do this.
1> exclude questions from the Published content
(exclude section questions, or final test content)
2> produce different test versions from question banks
3> Produce a PDF paper test for when we want to train in a classroom setting
4> Select which questions we want to produce
5> Import questions from a pre-defined format. To note: when we do this the system also makes us define a unique interaction id so that the import will update existing questions.
I know this will NOT work for some of the more sophisticated questions, But for the simple Mulitple choice, true/false, fill in the blank. etc..
THIS WOULD BE A GREAT FEATURE..
It would also be NICE TO HAVE THE abiliy to PROFILE versions of the SAME Course WITH OUT REPRODUCING / DUPLICATING / REPEATING THE ENTIRE COURSE PRESENTATION.
Such as
"INSTRUCTOR TAUGHT TRAINING"
"WEB TRAINING"
"PAPER TEST A"
"PAPER TEST B"
ETC...
LASTLY: if we can not export the QUIZ content. Can an excel spreadsheet LIKE INTERFACE be used to edit certain aspects of the questions.
Such as the InteractionId which is sent to the LMS ('cmi.interactions.0.id'). My developer team says it is real difficult and time consuming
to track down interactionIds and then maintain them in a perfect way.
Doug Lubey of Louisiana
