I just upgaded Adobe Acrobat to the current version, 9.3.2 organization-wide about a week ago. Since then, a handful of people (4 users out of 40) are having an issue where they cannot save PDF documents to a network drive. They get the following error:
"The disk you were saving to or the disk used for temporary files is full. Free some space on this disk and try again, or save to a different disk."
However, they can save the file locally and drag it over to the desired network share.
Can anyone tell me what this is about? I've searched online but haven't found anything useful. It doesn't make sense that most computers are able to save to a network share and others aren't - any help is appreciated!
I'm sorry, it is Adobe Reader, not Acrobat, so this is the correct forum.
It can't be a permissions issue, as the users this is happening to have full control on the network share they are trying to save PDFS to.
The computers are Windows XP and the network drive is a data drive on Windows 2000 Server. The users have full permissions to write to the drive, and can copy/move/drag-and-drop the PDF saved from their desktop. As for permissions on the PDF itself, I had them send me the PDFS and I am able to save directly to the network drive without issues, as are most other people in the office.
Is there a setting within Adobe Reader that needs to be enabled/disabled to correct this? I tried comparing everything I can think of, but I can't find any differences.
Thanks again for the help!
I have just had a user report this identical problem?
- Users local drive has plenty of freespace.
- Users network drives have plenty of free space.
- User can save locally and then manually copy the file to the network share.
I havn't troubleshooted this yet but the first thing I am going to test is the problem described here ----> http://z1-x.blogspot.com/2008/06/adobe-acrobat-file-name-limit-too-lon g.html
I'm hope this has been fixed in newer versions of Adobe. Though I won't hold my breath as its still an issue in Microsoft office and shadow copy (although the problem occurs at 255 characters I think).
I found that link in my research on this problem and figured it was the culprit - but when I saved to the same exact file structure and path on my local machine (or several other test machines) it can save just fine.
I really am stumped as to why this is happening on only a select number of machines. I've compared all the options in Adobe Reader Preferences, but everything seems to be the same. No idea what else to try! Especially frustrating since Adobe doesn't offer support on this product..
I was also having this issue and tried to recreate the folder structure locally. It wasn't recurring locally...until I added in a folder representing server path. Make sure you're accounting for all characters that are in the actual file path, not just file/folder names, when you're doing this. I had the users who were having this problem start abbreviating file names that they were using on their server shares and this resolved the issue for them.
SOLUTION (that worked for me)
I had the same problem that PDFs couldnt be saved on a network drive for some users, but others were fine. Not only that but they COULD drag and drop other files onto the network shares so I knew it wasnt a permission issuse.
I found out that I had disk quotas turned on, although the server had plenty of space the users were only allowed certain amount of data each (1GB) and some particular users were hitting there limited (just so happens the pdf files were much larger then the other files they were transfering to the network drive other wise the same error would of happened not just PDFs).
1. Log on to the Windows Small Business Server 2003 box as a member of the Administrators or Domain Admins group.
2. Open the Server Management console from the Start menu or using a desktop icon.
3. Expand the Advanced Management entry in the left pane.
4. Expand Computer Management.
5. Expand Storage.
6. Select Disk Management
7. Right-click the disk volume for which you wish to set user quotas and click Properties.
8. Highlight the Quota tab
http://articles.techrepublic.com.com/5100-10878_11-6117811.html
Hope this helps anyone.
Matt
This seems to be a bug related to protected mode, at least in Adobe Reader X. Unchecking "Enable Protected Mode at startup" in the General tab fixed this for my users.
Solution was found here: http://www.pcguide.com/vb/showpost.php?s=e6a2833bf89a00e88c52b01713cc7 34f&p=461932&postcount=21
I just wanted to add that the solution proposed by mvshaney worked for me as well - thank you!
I was having the same error message when saving an already open PDF from within Firefox. I was not trying to save to a networked drive, just to my local hard disk. I had tried reinstalling the plug-in, the whole of Adober Reader and all the suggested support from Firefox to no avail.
But in Adobe Reader X, Edit>Preferences> unclick enable protected mode at start-up followed by complete restart of both Reader and Firefox, solved the problem completely.
Recently ran into this issue at work- only half the pc's with reader did not have the "enable protected mode at startup" box checked. However when we checked the box, closed adobe completely - reopened, unchecked the box, closed adobe comletely and reopened it worked fine! I've done this on 12 pc's so far, give it a try it your protected mode isn't checked.
This solution worked for me, thank you so much mvshaney for posting it.
Adobe: This is a DISGRACE! This post is 2 years old and your new software still has the same bug!
