Hi Guys,
various bits of documentation refer to being able to put a users email address into the watermark as part of a policy.
However the only options appear to be:
Is there a special variable that I can use in the Custom Text?
I could use the email address as the UserID, but this isn't ideal...
I'm trying not to have to use the WorkBench or any custom code (it's really not my area).
Soon'ish
Craig
Solved! Go to Solution.
Total Likes
As far as I know, you are limited to what is available in theRights Management UI when creating Watermarks. I don't believe it is possible to set what the "Custom Text" is via a variable or dynamically.
Regards
Steve
Total Likes
Regards
Steve
Total Likes
Correct, you can't insert a user's email address into the watermark as a variable.
You can show the user's full name, or his login. Have you happened to map either of those fields to the full email address in User Manager? That would be a workaround I guess.
Thanks Steve and Jonathan. I've stuck with the User Name plus Current Date. Hopefully email address will become available in the future (haven't checked out ES4's options yet).
Total Likes
