Saving project as JPEG loses adjustment layers
May 19, 2010 11:05 AM
I like to work with adjustment layers in Photoshop, that way I can always go back to the original image.  The only problem is that when I save a photo out as a JPEG it seems to discard all of the adjustment layers.  If I add saturation, adjust brightness/contrast, etc. with adjustment layers, it doesn't show up when saving as JPEG.  I've tried merging all layers before saving and that didn't work, and I've tried saving with all of the different JPEG options (Baseline Standard, Optimized, and Progressive) and that didn't help either.
The only thing I have found that works is saving the file as a TIFF first and then opening the TIFF and saving that out as a JPEG.  What I'm I missing?
    May 19, 2010 11:15 AM   in reply to Webshark2000
    jpeg is not a format that recognizes or preserves layers. So, you need to save as a psd if you want layers as well as a smaller file size (compared to tiff).
    May 19, 2010 11:30 AM   in reply to Webshark2000
    Sorry, I misunderstood. What version of ps are you using?
    May 19, 2010 11:31 AM   in reply to Webshark2000
    Nothing you can do about it, the JPEG file format doesn't support layers.
    May 19, 2010 11:32 AM   in reply to Webshark2000
    What happens when you flatten the image in PS? Does it look good, or the way the JPG does?
    May 19, 2010 11:38 AM   in reply to Webshark2000
    Make a radical adjustment like adding a Hue/Saturation adj layer and pull the saturation all the way to -100 (or whatever).
    Save as a jpeg and see if the adj. holds (should be a grayscale).
    Also, are you saving using Save for Web or the Save As? Whichever it is, try the other.
    Just shooting in the dark here...
    May 19, 2010 11:41 AM   in reply to Webshark2000
    Photoshop acting weird? try resetting the preferences: http://forums.adobe.com/thread/375776?tstart=0
