Julien DESREUMAUX
Bug with DateField component with FlashBuilder4
May 22, 2010 4:58 PM
Hi ,
I see a bug with the date display with the DateField component into flex 4.0.
When I select the date of the 25th of May 2010 for example, it displays 2505052010.
So, the month string is repeated twice for all the date.
Do you have the same bug?
Thanks.
    Community Member
    May 23, 2010 7:07 AM
    hi,
    Are you changing the format string for the date field, with the standard date field it displays with a "/" seperator, the fact you have no seperator would indicate that you are changing the display formatter(or is this an internationalization thing).
    David.
    Community Member
    May 23, 2010 8:09 AM
    hi,
    try using a later version of the SDK, I use the 4.1 sdk and I am not seeing that problem.
    http://opensource.adobe.com/wiki/display/flexsdk/Download+Flex+4
    David
    Community Member
    May 27, 2010 7:38 AM
    I suppose that you use French locale along with your Flex application, right?
    Community Member
    Jun 2, 2010 6:47 AM
    Right, you've hit Adobe Flex SDK bug reported by me 9 month ago
    https://bugs.adobe.com/jira/browse/SDK-23104 Please go and vote to get it fixed in Flex 4.5
    ps
    For all readers of this topic, users of nb_NO, sv_SE, it_IT, nl_NL locales are also affected by this issue.
    The default value of "dateFormat" for specified  in SharedResources.properties file for those locales set is not  yet supported by mx:DateField as reported in http://bugs.adobe.com/jira/browse/SDK-23075
