yaroze
Choppy video on blazing fast connection
May 27, 2010 1:24 PM
Hi, we just set up FMS and basically what's happening is im using the standard run-of-the mill FLVplayback component and I try to run a video (an MP4) file which is streamed through FMS. The video plays, but intermittently chops.
Next test:
Akamai SMIL file with sthe same player plays totally smoothe, no problems.
Next test:
Put new video on FMS server (video chops intermittently) - we  then go right next to the server, with literally a 300K second download speed. Still chops.
Next test:
Try different media, same thing.
So essentially the FMS server CANNOT stream any videos properly. Its not a bandwidth issue, and it makes no sense.
I try different video players, tried changing the bufferTime properties, same thing. The FMS server is running at 0% cpu and is a fast machien.
Any ideas? FMS settings I can do to get optimal performance?
Austin
    May 27, 2010 1:37 PM   in reply to yaroze
    what bitrate is the video encoded at.......where did you get the .flv? we need to rule out that your video is not  the problem send it to me as attachment and i will play it on my server.
    May 27, 2010 1:50 PM   in reply to yaroze
    what are the video window size on both sites? I'm guessing this isn't the problem so there is a setting in the xml configuration file called cache and you should set this i'll bring up my config folder and be more specific in my next post.
    May 27, 2010 2:08 PM   in reply to calmchessplayer
    try increaseing this parameter in server.xml <MaxKeyframeCacheSize>0</MaxKeyframeCacheSize>....change it to
    30
    May 27, 2010 2:24 PM   in reply to yaroze
    well first of all your video playback componet has a  huge area try to
    change it to 320 x 240 also
    try using rtmpt intstead of rtmp
    May 27, 2010 2:30 PM   in reply to yaroze
    zip the stutter flv file. I want to try to play it on my server.
    May 27, 2010 3:24 PM   in reply to yaroze
    I don't have enough exsperience with mp4 to help you i can't get it to play with my player
    only .flv.......sorry and I wish you luck.
    May 27, 2010 3:31 PM   in reply to yaroze
    What O/S are you using ? maybe you have a bad install of FMS can you install the developer edition on a test desktop computer and see if you have the same problem....if you do then you will know its the default  FMS configuration if not then you can almost garuntee Operating Systerm or FMS install is culprit.
