Hi all, I am having a problem with my roll on / roll off code. I previously used a hit test code which ran into problems, and I am not using this code supplied to me from a member from this forum. Everything works but I still have the same problem which is when I quickly roll off one button to another, the preceeding button "sticks" at one of the on frames. If you move the mouse quickly over the nav the buttons animate on, but some stick....how can I force the animated link to play all the way back to frame 1, even if I go over a new button or leave the flash window / nav in xhtml/css.
Here is my code, I moved the event listeners to the bottom so you can see the main part of the code first:
stop();
function overF(e:MouseEvent){
var mc:MovieClip = MovieClip(e.currentTarget);
if(!mc.hasEventListener(Event.ENTER_FRAME)){
mc.removeEventListener(Event.ENTER_FRAME,prevF);
mc.play();
function outF(e:MouseEvent){
if(mc.currentFrame>1){
mc.prevFrame();
mc.addEventListener(Event.ENTER_FRAME,prevF);
function prevF(e:Event){
var mc:MovieClip = MovieClip(e.target);
mc.prevFrame();
} else {
b1.addEventListener(MouseEvent.ROLL_OVER, overF);
b1.addEventListener(MouseEvent.ROLL_OUT, outF);
b2.addEventListener(MouseEvent.ROLL_OVER, overF);
b2.addEventListener(MouseEvent.ROLL_OUT, outF);
b3.addEventListener(MouseEvent.ROLL_OVER, overF);
b3.addEventListener(MouseEvent.ROLL_OUT, outF);
b4.addEventListener(MouseEvent.ROLL_OVER, overF);
b4.addEventListener(MouseEvent.ROLL_OUT, outF);
b5.addEventListener(MouseEvent.ROLL_OVER, overF);
b5.addEventListener(MouseEvent.ROLL_OUT, outF);
b6.addEventListener(MouseEvent.ROLL_OVER, overF);
b6.addEventListener(MouseEvent.ROLL_OUT, outF);
b7.addEventListener(MouseEvent.ROLL_OVER, overF);
b7.addEventListener(MouseEvent.ROLL_OUT, outF);
b8.addEventListener(MouseEvent.ROLL_OVER, overF);
b8.addEventListener(MouseEvent.ROLL_OUT, outF);
b9.addEventListener(MouseEvent.ROLL_OVER, overF);
b9.addEventListener(MouseEvent.ROLL_OUT, outF);
b10.addEventListener(MouseEvent.ROLL_OVER, overF);
b10.addEventListener(MouseEvent.ROLL_OUT, outF);
b11.addEventListener(MouseEvent.ROLL_OVER, overF);
b11.addEventListener(MouseEvent.ROLL_OUT, outF);
b12.addEventListener(MouseEvent.ROLL_OVER, overF);
b12.addEventListener(MouseEvent.ROLL_OUT, outF);
b13.addEventListener(MouseEvent.ROLL_OVER, overF);
b13.addEventListener(MouseEvent.ROLL_OUT, outF);
b14.addEventListener(MouseEvent.ROLL_OVER, overF);
b14.addEventListener(MouseEvent.ROLL_OUT, outF);
b15.addEventListener(MouseEvent.ROLL_OVER, overF);
b15.addEventListener(MouseEvent.ROLL_OUT, outF);
b16.addEventListener(MouseEvent.ROLL_OVER, overF);
b16.addEventListener(MouseEvent.ROLL_OUT, outF);
b17.addEventListener(MouseEvent.ROLL_OVER, overF);
b17.addEventListener(MouseEvent.ROLL_OUT, outF);
Why you such complicate it? Try this:
function overF(e:MouseEvent):void
MovieClip(e.target).gotoAndStop(2); // assuming that in frame 2 is your roll over state
function outF(e:MouseEvent):void
MovieClip(e.target).gotoAndStop(1); // assuming that in frame 1 is your roll out state
To all other buttons just assign the same listeners.
thanks for the answer, but that wont work for an animated roll on and roll off button. I need th have an animation play on and off, when the user is over or off the button.
I see this all over the web, there isn't an industry standard way to create a roll on/roll off animation for links in Flash that isn't buggy?
anyone?
Than, for animated rollOver/Out effects do this:
Let for egzample the 1st frame of a button movie clip contains button's base state, put there stop(); command as well.
RollOver animation runs from 2nd to 10th frame (put stop(); in 10th frame). RollOut animation: frames 11 - 20 ( stop(); in 20th frame).
With a frames structure like this use the following rollOver/out handlers:
MovieClip(e.target).gotoAndPlay(2);
MovieClip(e.target).gotoAndPlay(11);
I did not check it in action but still try the following:
stop();
configureListeners();
function configureListeners():void {
var currentButton:MovieClip;
for (var i:int = 0; i < 18; i++ ) {
currentButton = MovieClip(this["b" + i]);
currentButton.addEventListener(MouseEvent.ROLL_OVER, overF);
currentButton.addEventListener(MouseEvent.ROLL_OUT, outF);
function overF(e:MouseEvent):void{
mc.removeEventListener(Event.ENTER_FRAME, playBackward);
mc.addEventListener(Event.ENTER_FRAME, playForeward);
function outF(e:MouseEvent):void{
mc.removeEventListener(Event.ENTER_FRAME, playForeward);
mc.addEventListener(Event.ENTER_FRAME, playBackward);
function playBackward(e:Event):void{
if (mc.currentFrame > 1) mc.prevFrame();
else mc.removeEventListener(Event.ENTER_FRAME, playBackward);
function playForeward(e:Event):void{
if (mc.currentFrame < mc.totalFrames) mc.nextFrame();
else mc.removeEventListener(Event.ENTER_FRAME, playForeward);
Message was edited by: Andrei1
Why don't you just turn the button into a movieclip and animate it in the movieclip.
Then you would not need all of the code, and the confusing b1, b2, ....
They ARE MovieClips...
