Vignetting problems with the 16-85VR profile
May 28, 2010 7:22 PM
I recently downloaded the 16-85VR and 55-200VR profiles for use with my D300.  I initially tested them on a brick wall at the focal length extremes, and all worked well.  However further testing with the 16-85VR profile at intermediate values (I used 35 and 50) demonstrated vignetting over-correction; with the vignette slider at the default of 100 the image edges and corners were much too bright.  Bringing the slider down to approximately 20 gave acceptable results.  The geometric and CA corrections appeared ok at all focal lengths.  There were no observed problems with the 55-200VR profile.
I would ask whomever created the 16-85VR profile to re-check at the intermediate values and see if they can reproduce my results.  Again, it appeared to me only the vignetting correction was faulty.  The problem occurred both in ACR 6.1 and in Photoshop CS5.  I have attached a screenshot showing the problem.  The original .nef can be downloaded from http://rgbaustin.com/S10_5685.zip.
Richard Southworth
    May 28, 2010 7:38 PM   in reply to RASouthworth
    Just to be sure, you have all the manual corrections off, right?
    May 29, 2010 9:17 AM   in reply to RASouthworth
    Wait - where did you get this profile?  It doesn't say "Adobe" on your screen shot and I don't see it as an Adobe-supplied profile.
    EDIT:  Sorry, I'm a little slow.  I didn't see, "I would ask whomever created the 16-85VR profile to re-check at the intermediate values and see if they can reproduce my results" the first time through.
    I think this type of situation is pretty easy to create if you aren't somewhat careful with your lighting when you take the shots.
    May 29, 2010 2:15 PM   in reply to RASouthworth
    There's definitely something off about the profile. I can use it in Photoshop CS5's Lens Correction and if I right click I can see the various F/stops and zooms and focus distance used. But, it's clearly doing an over correction with vignetting.
    When I try to use the profile in Camera Raw, the vignetting is really screwed up...the profile name is also garbage. So, this is a profile that needs to be fixed or removed...
    May 30, 2010 4:38 PM   in reply to RASouthworth
    Maybe the original profile was created by someone with a lens filter on, which thus enhanced vignetting?
    May 31, 2010 7:46 PM   in reply to phototrek
    There is a possibility that the image sets used to create the profile did not place the patches of the chart close enough to the corners of the frame. If that is true, then that could result in overcorrection of vignetting at wider apertures.
    (At shorter focal lengths, the vignette falloff can be steeper in the corners, so it's important to get patches close to the corners. There is also a known limitation in ALPC regarding vignette overcorrection and this is an area for improvement.)
    May 31, 2010 11:24 PM   in reply to RASouthworth
    RASouthworth wrote:
    A member of the ACR forum was able to use the 16-85VR profile successfully on one of my images, with the vignette slider at default.  So perhaps there is some sort of configuration interaction.  Hope Adobe gets it sorted out soon, very nice function to have in ACR.
    That was me. Yesterday, I worked on a 6-shot pano with a 16-85mm and noticed that the vignette correction had indeed over compensated, and needed the effect reducing to 60. So, I can confirm that the profile does sometimes get it wrong for me too.
    However, that doesn't explain how the same raw file can be over-compensated on one computer and not on another. That IS very strange.
    Jun 1, 2010 1:36 AM   in reply to Yammer P
    I shouldn't be, if you have a shot with the same focal length, focus position and aperture. But can you be sure the two shots on different computers had identical settings?
    Not obviously 100% sure, but I think we both reset to camera raw defaults before applying lens correction.
    Jun 1, 2010 3:03 AM   in reply to Yammer P
    ... but I think we both reset to camera raw defaults before applying lens correction.
    I mean in-camera settings (focal length, focus position and aperture), not Camera Raw settings.
    It's the same photo; same raw file.
    Jun 18, 2010 5:12 AM   in reply to Yammer P
    Downloaded the CS5 trial just to get access to the profiles. Saved the one for the Nikon 16-85 for my use in LR3.
    Works well, but I have the same vignetting problems - so I've set the vignetting slider almost to 0.
    I started profiling the lens / D300 myself but ran into too many problems, I would need at least one day to make it perfect. So I'm hoping for a better version from Adobe (I would even pay for it).
    Regards, Detlef
    Jun 18, 2010 10:04 PM   in reply to MadManChan2000
    >There is a possibility that the image sets used to create the profile did not place the patches of the chart close enough to the corners of the frame. If >that is true, then that could result in overcorrection of vignetting at wider apertures.
    >(At shorter focal lengths, the vignette falloff can be steeper in the corners, so it's important to get patches close to the corners. There is also a known >limitation in ALPC regarding vignette overcorrection and this is an area for improvement.)
    Yes. In order to get consistent good quality lens profiles, it is critical to position the patches of the chart as close to the edges to the image frame as possible (while still without having the patches being clipped by the image frame) and keep a consistent lighting between the 9 image shots.
    Jun 21, 2010 6:41 PM   in reply to RASouthworth
    I noticed that this profile works fine in Adobe Camera Raw, but has way too much vignatting correction if you choose lens filter in
    CS5. Looks like a bug in Lens Correction. Try to save profile locally and use in Camera Raw.
    Jun 21, 2010 6:55 PM   in reply to Oleg_Z
    If what you said is true, then it is a totally different issue now. The best place to do vignette correction is in the raw color space, period. With raw, one still have access to the raw sensor color data. The vignette correction here is exact. With the LC filter in PS CS5, we have to guess the sensor reponse curve (gamma), the correction is approximate.
    Jun 21, 2010 8:59 PM   in reply to simonsaith
    The same image processed in Camera Raw. Looks good to me
    Jun 30, 2010 4:44 PM   in reply to RASouthworth
    Yes, I've been using that one too. It's quite a lot different in terms of distortion and vignetting - not as extreme.
    Jun 30, 2010 11:33 PM   in reply to Yammer P
    ...although I should mention that it still seems to over compensate for vignette a bit.
    Jul 6, 2010 8:42 AM   in reply to RASouthworth
    How do you apply a D90 profile to a RAW file with embedded information that it was captured by a D300? The D90 file is in my downloaded profiles folder, but in LR3s develop modul  I'm only able to see the D300 profiles (developing a D300 picture).
    Jul 6, 2010 8:56 AM   in reply to Kaffeesegler
    I'n not using Lightroom, I'm using Camera Raw with my D300. It's possible that Lightroom is camera-specific in offering profiles. If there's no way around this, you may be able to edit the xml using a text editor, or a multi-editor, like RJ Texted, and replace all occurences of D90 with D300.
    Jul 6, 2010 9:13 AM   in reply to Kaffeesegler
    CR/LR will show you all raw-based lens profiles when you are processing raw images (not just the ones created by your camera model, like the D300).Is the D90 profile you're trying to use created from JPEG or from raw?
