Consuming WCF service with ColdFusion
May 30, 2010 7:01 PM
Hello,
We've been trying to consume a web service (.svc file) created in WCF (.NET 4.0) in ColdFusion for a few weeks now. It seems every time we get one problem worked out, another one pops up. One of our biggest problems is how to see what's in the DTO that .NET is sending to ColdFusion. It was working in .NET 3.5, but then they upgraded the server to .NET 4.0. Now one of the variables keeps causing an error. I'm guessing it's a variable type that CF doesn't support without doing something to convert it.
My question is, what's the best way to go about getting this coded? Are there good resources somewhere? We've been Googling, so we've seen many of the articles that come up that way. Is ColdFusion Builder better suited to this than Dreamweaver? Eclipse? Any guidance would be appreciated.
Thanks.
    Feb 26, 2012 3:24 PM   in reply to lrobey
    Did you get an answer to this? I'd also like to know. I'm struggling to find good resources. I'll have to blog about it myself when I understand it all.
    Mar 1, 2012 9:39 AM   in reply to lrobey
    If your web services support SOAP, you can use a visual tool like CrossCheck Network's SOAPSonar - it will allow you to browse the service, generate sample request/response messages to expose the DTO structure.  Since it exposes the raw SOAP message exchange, you can also see if your trouble is caused by things that are hard to troubleshoot through CF - like XML namespaces.
    CrossCheck Networks makes a personal version that is free for developers.
    Mar 2, 2012 8:48 AM   in reply to lrobey
    lrobey wrote:
    Hello,
    As far as producing or consuming web services is concerned, the choice of platform(.NET 4.0, .NET 3.5, ColdFusion) or of IDE(Dreamweaver, Eclipse, CF Builder) should not matter. After all, one of the main promises of web services is interoperability between different systems.
    Since the latest errors occurred after the upgrade to .NET 4.0, the fault is very likely with the service provider (.NET), and not with the service requester(ColdFusion). Make sure provider and requester communicate by means of an established protocol, like SOAP.
    Mar 2, 2012 9:41 AM   in reply to BKBK
    This, while technically correct, may be a little misleading.  Odds are there is some advanced (though standardized) web service behavior introduced by .NET 4 (most likely complex handling of XML namespaces) that ColdFusion's notoriously outdated implementation of web services (Java AXIS) has problems with.  Thankfully, in CF10 we have an update to that system, but in the meantime it may be easier to revert to passing raw XML SOAP messages (if your web service is SOAP based) as described in this article by Ben Nadel:
    http://www.bennadel.com/blog/1809-Making-SOAP-Web-Service-Requests-Wit h-ColdFusion-And-CFHTTP.htm
    Mar 3, 2012 12:00 AM   in reply to insuractive
    You misunderstand what I said. When I say "the fault is with the provider", I mean "the provider is the one whose fault it is that the hitherto working service fails". So I am not necessarily saying there is an error on the side of the provider, though that is possible.
    The key point is the etiquette between server(providing a service) and client(consuming it). The server has the obligation to inform all clients of changes to his service. Especially the kind of changes you mention.
    Take the web, for example. If your website onesidedly assumes that visitors have the latest versions of the latest browsers, then it will end up frustrating a lot of people.
