A few days ago lens correction profiles showed up for my D300 with both 16-85VR and 55-200VR lenses. Brick wall testing indicates they seem to have nailed distortion/CA/vignetting, at least for focal length extremes.
So how do we know where these profiles originated, if for no other reason than to give credit?
Richard Southworth
Excuse me for butting in. I have thousands of 16-85mm/D300 photos, and I wondered how to obtain the 3rd party profiles.
I can't find any way of getting them in ACR, and when I 'search online' in PS, it find the profile, but doesn't seem to add it to ACRs list.
I've tried finding a lens correction downloads area on the Adobe website, but failed. What am I missing?
I just worked out that there's a fly-out menu in PS Lens Correction filter's Lens Profiles list, which enables you to save an online profile locally, after you've searched for and found one.
It then appears in ACR, but not, as I'd expect under Default nor Auto. You have to select Custom. Is this correct?
No, make sure the Lens Profile info is correct, Setup set to Default, and Enable Lens Profile Corrections checked. Also make sure all other settings are as you desire for default image. Then click on the flyout menu and select "Save New Camera Raw Defaults". Additional lenses require the "Save New Lens Profile Defaults" under Setup. Or something like that, going from memory. It's a bit tortuous, and I believe instructions are written down somewhere at Adobe.
Richard Southworth
Added by edit - make a preset with only Lens Corrections, to use on older already edited images.
Thanks, I'll have to experiment with that.
Just spotted another problem as a result: was unsure about the quality of the Nikon AF-S 24-70mm f/2.8G lens profile, as I have to do a bit of chromatic aberration correction to do afterwards (which sort of defeats the object). Realised that the profile was made with the D3x (according to the file name), which is a full-frame camera. Mine is the D300, a 1.5x crop camera.
So, is the correction I get on the 24-70mm lens wrong? Do I need another profile done with the right sensor size?
Why is Camera Raw selecting the lens if the profile was made on a different format camera?
The Adobe-supplied profiles are created with a reference camera. In
the Nikkor 24-70 case, that is a D3X. The profile can be used on other
cameras, including ones with smaller sensors. At present we do not
correct all forms of chromatic aberration. The profiles only deal with
lateral CA.
Eric
lateral CA.
Eric
That doesn't make sense to me. Surely a smaller sensor will produce a significantly different set of distortion and vignette readings, and also the lateral chromatic aberration will be reduced. I am assuming that the ACR correction is made over the whole (cropped) frame, or is the correction applied to a virtual (full) frame 1.5 times larger than the image?
The chromatic aberration I am seeing with the D300/24-70mm combination is lateral, and I am compensating by using the sliders in the manual tab.
Which is why I depend on DXO corrections. They marry their corrections to the camera. If you don't believe that, compare the lens correction for say the Nikon D80 against the D90. These same lenses will operate on both cameras yet the lens modules for the D90 have less available.
The only place I might consider using the Adobe corrections is for lenses DXO does not cover, like the Tamron 28 to 75.
I cannot understand why Adobe is doing such a casual job on this where software and and data far better suited for the job already exists. Is it "Not invented here" syndrome?
Message was edited by: Hudechrome
A question has been asked so lets give Eric a chance to anwer it without going off into the weeds. As I originally stated I have found the lens correction capability very usable for three of my lenses, two pro-sumer and one fast glass, with the exception of a problem identified in a separate thread.
Richard Southworth
It's certainly correct to a degree - my beginning post expressed satisfaction for my usage and asked a simple question as to the origin of the profile. I did not intend for the thread to be used for flogging Adobe because it's not the equal of DXO. I've used DXO and they certainly do an admirable job of correction; however, I find ACR to be an ever improving one stop solution for 95% of my imaging needs.
Richard Southworth
If you profile a lens, you'll want to profile it on the largest sensor you will be using it on. If you then use it on a smaller sensor, the lens profile will still make the corrections even though the amount of corrections needed for the three corrections will be different–milder because the sensor corners of the reduced size sensor will be closer to the center.
When Adobe made their profiles, they profiled lenses that could be used on full frame and reduced size sensors with full frame cameras. There are some lenses that can only be used on reduced size sensors and those lenses were profiled on the sensor size they were made for.
Okay, thanks Jeff. So I take it that you're saying that ACR 6.1 does allow for the smaller crop frame on Nikon DX cameras when it employs a profile made on a full-frame camera? In other words, the camera used to make the profile isn't that important?
Hudechrome wrote:
I would at least check it.
How would I check it? Do you mean brick wall tests, etc?
It occurred to me that the CA compensation I was having to use for the 24-70mm may be due to a mismatched profile, because (if you think about it) a profile for a bigger sensor would usually have more CA correction, as it's worse at the edges. However, I'm assured by Jeff that this has been taken into account, so it must just be an inaccuracy in the profile.
I have downloaded a user-contributed profile for the D300/16-85mm combination. This is a mid-priced zoom with worse lateral CA than the other (pro) lens, but the profile seems to work much better, at least in terms of CA correction. That's what started me thinking there was something wrong.
I wasresponding to Jeff's comment concerning DX vs full frame performance. One of the reviews on slrgear actually had a surprise with a full frame lens when checked on DX.. Generally, I would expect as Jeff did, but I never take test and measurement for granted. It sometimes come back to bite you in the nether region! ![]()
Yammer, what I meant was that when ACR applies a profile created on a larger sensor (e.g., D700) to an image that was captured by a smaller sensor (e.g., D300), the difference in sensor size (e.g., the crop factor ratio, if you prefer) is accounted for during the rendering. For example, ACR "knows" that a D300 sensor has a ~1.5 crop factor compared to a D700 which has a crop factor of ~1, so the vignette, distortion, and lateral CA that occurs at 21 mm from the center of the image is irrelevant to a D300 (since the D300's sensor is smaller than that). In other words, ACR is taking care of the behind-the-scenes adjustment based on the sensor size differences. It is not blindly applying a D700 profile to a D300 image and pretending they are the same.
I can think of one really good reason why a lens profile should be camera-specific for the best possible results:
Not every sensor responds the same to light coming in from various angles. Microlenses, for example, are different from sensor to sensor.
So the vignetting profile for one camera might be a general improvement on another, but it may not produce specifically accurate results on that other camera.
You cannot oversimplify the problem and achieve perfection.
-Noel
A couple of questions related here
1 Is there a list of profiles somewhere that I can find. Somewhere/somehow the Nikon 50 1.4 wasn't profiled nor has the new Nikon 24mm 1.4 been profiled and both could use some work. Is this something adobe will stay on or will this be a once a year update?
2 Will it be possible to add hassleblad or mamiya mf profiles to this?
1. If you have ACR 6.1 installed, you can browse the available set of lens profiles using the Make/Model/Profile popup menus in the Lens Corrections pane (Profile tab). For example, set Make to Nikon, and you can browse the available set of lens models currently supported (via the Model popup). If you're intending to apply lens corrections when processing raw images, make sure you have a raw image open before you try looking at this popup.
You should expect that Adobe will not sit still on the currently available set of lens profiles included in this release.
2. It is possible. In the meantime, you can also create profiles yourself using the Adobe Lens Profile Creator (free download).
You can do this from the Photoshop filter but not from camera raw. In the PS lens coorrection filter there is a Search Online button at the bottom. It's pop-up tip reads: "Search Adobe server for lens profiles that match the source image." I'd guess this Adobe server will be a repository for user-created lens profiles.
This is so typical adobe. Give you such a great tool and then cripple it. It absolutely needs to be in acr except you can't load other profiles except adobe's in PS5. You can only use adobes profiles in raw acr and LR. And the lenses they are missing aren't exactly obscure, Canon 50 1.2 and the Nikon 50 mm 1.4!
Come on, have an online database where we can ad and download them all and rate them........This is so important going forward.
Also, has anyone seen any medium format back profiles???
Did you BOTHER to do a search in the Photoshop CS5 Lens correction filter? If you had, you should have found a profile for the Canon 50mm F/1.2 lens that I created. As for the Nikon 50mm 1.4, I couldn't care less...
Ya know, it would be USEFUL if you spent a moment and had a half a clue before making a post where basically, you shoot yourself in the foot. I DID spend the time to make a good profile and upload it to the profile site. If you can't find it, I suspect it says more about you than the profile site, ya know?
OK I see were I can "hunt" for profiles inside CS5. One of my cameras is a Canon G-11 I see a profile in ACR 6.1 for the G10 but not for a G11 in CS5 there is no profiles for any of the G series cameras. So the list of cameras/lens between the two programs are not synchronised. So here is the question is there a way to add profiles to ACR 6.1? At the moment there is only one of the lens I own in either ACR 6.1 or CS5. In CS5 there is no listing for any of my cameras models. It looks like lens correction will someday be a great tool but right now it's only useful if you hit the lottery and your lens is listed. I will attempt sometime to do my own profiles but from a quick look at the process, it's not a quick or easy thing.
John Passaneau
Actually I figured out the issue and it says a lot about me and adobe. Since adobe spend so much time wanting information from me I have installed little snitch to stop their intrusions and it was keeping me from accessing the files so I did find it.
You do have a lot of knowledge and expertise Jeff it's just to bad its wrapped in such an awful personality. Between here and LL you are one of the most gruff humans alive. Why patrol the boards leaving such awful feedback if you hate it so?
Actually, I spend more time helping people which I enjoy. I do however tend to respond poorly to people who jump on Adobe without reason such as your comment "This is so typical adobe. Give you such a great tool and then cripple it." Which lead me to answer the way I answered...ironic that it was something YOU had done that made finding the profiles you wanted impossible...you'll note the other posts in this thread BEFORE you came around WERE informational in nature...so, not only do you have your own actions to blame for not finding the profiles, you also can also thank yourself for bringing out the best in me. Hope you find the 50mm F1.2 profile useful now that you've figured out how to use the tool to find it.
