Has anyone else seen this and found a solution?
Installed CS5 Standard, OS 10.6.3, MacBook Pro 4,1
When first installed, I could not change prefs - as discussed in thread:
http://forums.adobe.com/thread/628368?tstart=0
I manually changed permissions. CS 5 will now launch and operate. When choosing "Quit" CS5 closes all windows normally, however the menu bar does remains and the spinning beachball displays. After about 20 seconds Mac OS reports that Photoshop quit unexpectedly. A minute later Adobe's crash reporter appears.
I've uninstalled and re-installed.
Stephen
Send in the crash report with details (what did during the session, what troubleshooting you might have done, etc.).
I'm looking at all the crash reports.
Hi Chris,
Yes, I've sent in the report - Adobe Crash Reporter.
Here's the chronology:
- installed Photoshop CS5, no errors reported
- could not enable GPU or change prefs. When quitting, CS5 reported:
"Could not save Preferences because the file is locked or you do not have the necessary access privileges. Use the ‘Get Info’ command in the Finder to unlock the file or change permissions on the file or enclosing folders."
Manually added/changes permissions as per the "Locked" thread on this forum
CS5 would now allow GPU and changing prefs, however upon choosing "Quit" it hangs with the spinning beach ball then OS reports "unexpectedly quit".
That's where I am now.
Update: installing CS5 on a Mac Pro running OS 10.6.2 (not the 10.6.3 which is having the problem) - CS 5 installs correctly and works properly without any modification.
Thanks again!
Without seeing your exact report, I'm going to guess that it's a crash in ServiceManager because of bad permissions on a different folder. (we've got several crashes because of that)
Thanks Chris
I've changed permissions on the following folders (added myself as owner, read and write privs)
Application Folder:
Adobe Bridge CS5 (folder)
Adobe Device Central CS5 (folder)
Adobe Extension Manager CS5 (folder)
Adobe Photoshop CS5 (folder)
User/Library/Preferences folder:
Adobe (folder)
Adobe Photoshop CS5 Settings (folder)
User/Library/Application Support Folder:
Adobe (folder)
Am I missing any folders that require corrected permissions?
(with thanks to ggrieble for the list in the "locked" thread)
Also check /Library/ApplicationSupport
I'm still trying to get details from the ServiceManager team as they investigate the crash reports.
I had the same issues, changed the permissions as mentioned here:
Application Folder:
Adobe (folder)
Adobe (folder)
Still had crashes on Illustrator...
Solution: Change the permissions in the ~/Library/Application Support/Adobe/CS5ServiceManager as well.
I don't know why, but you must change the permissions separatly, it does not work setting the permissions on the CS5ServiceManager and set them directly to all subfolders
THIS old cowboy needs some pointers to information on PERMISSIONS and other changes suggested here that could expect to be necessary if this were a Microsoft product. You know, crashes with no good reason on a PC where it shouldn't be used.
Where do I find and how do I use the various technical nostrums suggested? Permissions and the other places we're being sent with no help? CS5 Service Manager? What's that? Where is the badly needed information on installation problems?
I'm running CS4 Design Premium and have now loaded -- from purchased Adobe discs! -- CS5 Design Premium on my 17" MacBookPro using 10.5.8 because of the problems with Snow Leopard.
All was running fine on CS4 so while this gets sorted out, I guess it will be necessary to go back to CS4 so I can get some work done to pay for this lost time.
Bill Eger
I had all these same problems. Spent HOURS on the phone with Adobe tech support today, and I am very upset that they did not inform me that this is a known issue! They had me uninstalling and installing numerous times. I repaired all permissions system-wide, changed all relevant Adobe permissions, and then I was able to save a preset. But the program still crashed on quit. It ran fine via an alternate user.
So I checked here, and what DID work for me, thanks to the notes posted, was to uninstall, log in as a test user, reinstall via test user (I still changed permissions again to read/write for everyone); log out of test; log in as main user. It works!
I wish I had known to do this this morning; it would have saved me the whole day. At one point, I was on hold more than 40 minutes -- after talking with someone and waiting to be transferred to a "Photoshop specialist." I finally hung up in desperation. Eventually the tech person told me it is an "Apple problem, not an Adobe problem."
Chris, my Incident # is 181590512. If you send me an email, I will gladly send you a crash report.
Thanks to whoever came up with the above solution!
I seem to have the same problems with permissions. I activated the root accounrt and installed from there, but I have permission problems and crashes on exit unless I also run from the root account. My regular account also has admin permissions.
New install, running 10.6.3 on a MacBook Pro. Here is my crash log:
Process: Adobe Photoshop CS5 [3484]
Path: /Applications/Adobe Photoshop CS5/Adobe Photoshop CS5.app/Contents/MacOS/Adobe Photoshop CS5
Identifier: com.adobe.Photoshop
Version: 12.0 (12.0x20100407.r.1103) (12.0)
Code Type: X86-64 (Native)
Parent Process: launchd [3042]
Date/Time: 2010-05-14 17:56:40.439 -0700
OS Version: Mac OS X 10.6.3 (10D573)
Report Version: 6
Interval Since Last Report: 252742 sec
Crashes Since Last Report: 13
Per-App Interval Since Last Report: 7827 sec
Per-App Crashes Since Last Report: 7
Anonymous UUID: 8A7919A9-74FE-4C5C-AFC2-897EFF689A72
Exception Type: EXC_CRASH (SIGABRT)
Exception Codes: 0x0000000000000000, 0x0000000000000000
Crashed Thread: 5
Application Specific Information:
abort() called
Thread 0: Dispatch queue: com.apple.main-thread
0 libSystem.B.dylib 0x00007fff84acc316 __semwait_signal + 10
1 libSystem.B.dylib 0x00007fff84ad0131 _pthread_cond_wait + 1286
2 ServiceManager-Launcher.dylib 0x0000000119b2e735 Invoke + 57527
3 ServiceManager-Launcher.dylib 0x0000000119b2d85b Invoke + 53725
4 ServiceManager-Launcher.dylib 0x0000000119b2741a Invoke + 28060
5 ServiceManager-Launcher.dylib 0x0000000119b2d635 Invoke + 53175
6 ServiceManager-Launcher.dylib 0x0000000119b1eca4 Login + 9698
7 ServiceManager-Launcher.dylib 0x0000000119b1ece2 Login + 9760
8 ServiceManager-Launcher.dylib 0x0000000119b21e0f Invoke + 6033
9 ServiceManager-Launcher.dylib 0x0000000119b1cb19 Login + 1111
10 ServiceManager-Launcher.dylib 0x0000000119b1c73c Login + 122
11 libSystem.B.dylib 0x00007fff84aa3c58 __cxa_finalize + 203
12 libSystem.B.dylib 0x00007fff84aa3b70 exit + 18
13 com.adobe.Photoshop 0x0000000100002eab 0x100000000 + 11947
Thread 1: Dispatch queue: com.apple.libdispatch-manager
0 libSystem.B.dylib 0x00007fff84aaa4ea kevent + 10
1 libSystem.B.dylib 0x00007fff84aac3bd _dispatch_mgr_invoke + 154
2 libSystem.B.dylib 0x00007fff84aac094 _dispatch_queue_invoke + 185
3 libSystem.B.dylib 0x00007fff84aabbbe _dispatch_worker_thread2 + 252
4 libSystem.B.dylib 0x00007fff84aab4e8 _pthread_wqthread + 353
5 libSystem.B.dylib 0x00007fff84aab385 start_wqthread + 13
Thread 2:
2 com.adobe.amt.services 0x000000010907cc53 AMTConditionLock::LockWhenCondition(int) + 37
3 com.adobe.amt.services 0x0000000109075cce _AMTThreadedPCDService::PCDThreadWorker(_AMTThreadedPCDService*) + 92
4 com.adobe.amt.services 0x000000010907ccbe AMTThread::Worker(void*) + 28
5 libSystem.B.dylib 0x00007fff84aca8b6 _pthread_start + 331
6 libSystem.B.dylib 0x00007fff84aca769 thread_start + 13
Thread 3:
0 libSystem.B.dylib 0x00007fff84a9175a mach_msg_trap + 10
1 libSystem.B.dylib 0x00007fff84a91dcd mach_msg + 59
2 com.apple.CoreFoundation 0x00007fff827c6452 __CFRunLoopRun + 1698
3 com.apple.CoreFoundation 0x00007fff827c58df CFRunLoopRunSpecific + 575
4 com.apple.CoreMediaIOServices 0x00007fff86a3f637 MIO::DAL::RunLoop::OwnThread(void*) + 147
5 com.apple.CoreMediaIOServices 0x00007fff86a41202 CAPThread::Entry(CAPThread*) + 140
6 libSystem.B.dylib 0x00007fff84aca8b6 _pthread_start + 331
7 libSystem.B.dylib 0x00007fff84aca769 thread_start + 13
Thread 4:
0 libSystem.B.dylib 0x00007fff84a917a2 semaphore_wait_signal_trap + 10
1 libSystem.B.dylib 0x00007fff84a96ced pthread_mutex_lock + 469
2 ServiceManager-Launcher.dylib 0x0000000119b2d811 Invoke + 53651
3 ServiceManager-Launcher.dylib 0x0000000119b277c6 Invoke + 29000
4 ServiceManager-Launcher.dylib 0x0000000119b277e3 Invoke + 29029
5 ServiceManager-Launcher.dylib 0x0000000119b275a0 Invoke + 28450
6 ServiceManager-Launcher.dylib 0x0000000119b2a49f Invoke + 40481
7 ServiceManager-Launcher.dylib 0x0000000119b1f137 Login + 10869
8 ServiceManager-Launcher.dylib 0x0000000119b1ccc4 Login + 1538
9 ServiceManager-Launcher.dylib 0x0000000119b1e265 Login + 7075
10 ServiceManager-Launcher.dylib 0x0000000119b2b2a8 Invoke + 44074
11 ServiceManager-Launcher.dylib 0x0000000119b2d6c1 Invoke + 53315
12 libSystem.B.dylib 0x00007fff84aca8b6 _pthread_start + 331
13 libSystem.B.dylib 0x00007fff84aca769 thread_start + 13
Thread 5 Crashed:
0 libSystem.B.dylib 0x00007fff84b608c9 usleep$NOCANCEL + 0
1 libSystem.B.dylib 0x00007fff84b7feb8 abort + 93
2 libstdc++.6.dylib 0x00007fff889e65d2 __tcf_0 + 0
3 libstdc++.6.dylib 0x00007fff889e4ae1 __cxxabiv1::__terminate(void (*)()) + 11
4 libstdc++.6.dylib 0x00007fff889e4b16 __cxxabiv1::__unexpected(void (*)()) + 0
5 libstdc++.6.dylib 0x00007fff889e4fd6 std::bad_cast::what() const + 0
6 ServiceManager-Launcher.dylib 0x0000000119b24f15 Invoke + 18583
7 ServiceManager-Launcher.dylib 0x0000000119b24e15 Invoke + 18327
8 ServiceManager-Launcher.dylib 0x0000000119b2c8fd Invoke + 49791
9 ServiceManager-Launcher.dylib 0x0000000119b2cd23 Invoke + 50853
10 ServiceManager-Launcher.dylib 0x0000000119b2c974 Invoke + 49910
11 ServiceManager-Launcher.dylib 0x0000000119b2dfde Invoke + 55648
12 ServiceManager-Launcher.dylib 0x0000000119b2e06e Invoke + 55792
13 ServiceManager-Launcher.dylib 0x0000000119b2a8f7 Invoke + 41593
14 ServiceManager-Launcher.dylib 0x0000000119b2aac2 Invoke + 42052
15 ServiceManager-Launcher.dylib 0x0000000119b2aaf4 Invoke + 42102
16 ServiceManager-Launcher.dylib 0x0000000119b2ab49 Invoke + 42187
17 ServiceManager-Launcher.dylib 0x0000000119b2ad71 Invoke + 42739
18 ServiceManager-Launcher.dylib 0x0000000119b1cdaf Login + 1773
19 ServiceManager-Launcher.dylib 0x0000000119b1b953 GetUserInfo2 + 257
20 com.adobe.PlugPlug 0x00000001068582b6 csxs::servicemgr::api::ServiceManager::DoGetUserInfo(char const*, csxs::servicemgr::api::AMTProductCycleInfo) + 74
21 com.adobe.PlugPlug 0x0000000106859264 csxs::servicemgr::api::ServiceManager::GetUserInfo(std::string&) + 30
22 com.adobe.PlugPlug 0x000000010685adb0 csxs::services::csi::AsyncGetUserInfo::DoRun() + 122
23 com.adobe.PlugPlug 0x00000001068598b7 csxs::services::csi::AsyncCall::Run() + 51
24 com.adobe.PlugPlug 0x000000010686d5ae vcfoundation::thread::AbstractThread::Run() + 54
25 com.adobe.PlugPlug 0x000000010686fb6d vcfoundation::thread::Thread::ThreadProc(void*) + 9
26 libSystem.B.dylib 0x00007fff84aca8b6 _pthread_start + 331
27 libSystem.B.dylib 0x00007fff84aca769 thread_start + 13
Thread 6:
0 libSystem.B.dylib 0x00007fff84ad5286 select$DARWIN_EXTSN + 10
1 com.apple.CoreFoundation 0x00007fff827e7ef2 __CFSocketManager + 818
Thread 7:
0 libSystem.B.dylib 0x00007fff84aab30a __workq_kernreturn + 10
1 libSystem.B.dylib 0x00007fff84aab71c _pthread_wqthread + 917
2 libSystem.B.dylib 0x00007fff84aab385 start_wqthread + 13
Thread 8:
Thread 5 crashed with X86 Thread State (64-bit):
rax: 0x0000000000000000 rbx: 0x0000000000000000 rcx: 0x00007fff84adf886 rdx: 0x0000000000000000
rdi: 0x0000000000002710 rsi: 0x0000000000000006 rbp: 0x000000011e81b6a0 rsp: 0x000000011e81b688
r8: 0x00007fff70a7ba00 r9: 0x000000011e81b932 r10: 0x00007fff84adb8ca r11: 0x0000000000000206
r12: 0x000000011e81b932 r13: 0x0000000000000067 r14: 0x0000000000000000 r15: 0x0000000000000021
rip: 0x00007fff84b608c9 rfl: 0x0000000000010206 cr2: 0x00000001069cc800
Binary Images:
0x100000000 - 0x1026b5fff +com.adobe.Photoshop 12.0 (12.0x20100407.r.1103) (12.0) <B69D89E5-01DD-C220-48B1-E129D0574536> /Applications/Adobe Photoshop CS5/Adobe Photoshop CS5.app/Contents/MacOS/Adobe Photoshop CS5
0x103295000 - 0x10330dfef +com.adobe.adobe_caps adobe_caps 3.0.116.0 (3.0.116.0) <4A355686-1451-B19A-0C55-DFE49FD2539E> /Applications/Adobe Photoshop CS5/Adobe Photoshop CS5.app/Contents/Frameworks/adobe_caps.framework/Versions/A/adobe_caps
0x103323000 - 0x10332afff org.twain.dsm 1.9.4 (1.9.4) <D32C2B79-7DE8-1609-6BD4-FB55215BD75B> /System/Library/Frameworks/TWAIN.framework/Versions/A/TWAIN
0x103332000 - 0x103342ff8 +com.adobe.ahclientframework 1.5.0.30 (1.5.0.30) <5D6FFC4E-7B81-3E8C-F0D4-66A3FA94A837> /Applications/Adobe Photoshop CS5/Adobe Photoshop CS5.app/Contents/Frameworks/ahclient.framework/Versions/A/ahclient
0x10334d000 - 0x103353ff7 com.apple.agl 3.0.12 (AGL-3.0.12) <C8CBED46-DB62-3D5C-70BE-B6FD407223A8> /System/Library/Frameworks/AGL.framework/Versions/A/AGL
0x10335a000 - 0x103560fef +com.adobe.linguistic.LinguisticManager 5.0.0 (11696) <499B4E7A-08BB-80FC-C220-D57D45CA424F> /Applications/Adobe Photoshop CS5/Adobe Photoshop CS5.app/Contents/Frameworks/AdobeLinguistic.framework/Versions/3/AdobeLinguistic
0x1035f3000 - 0x1037a1fef +com.adobe.owl AdobeOwl version 3.0.91 (3.0.91) <C36CA603-EFFB-2EED-6CEE-0B532CE052D2> /Applications/Adobe Photoshop CS5/Adobe Photoshop CS5.app/Contents/Frameworks/AdobeOwl.framework/Versions/A/AdobeOwl
0x103843000 - 0x103c73fef +AdobeMPS ??? (???) <FA334142-5343-8808-7760-4318EB62AD51> /Applications/Adobe Photoshop CS5/Adobe Photoshop CS5.app/Contents/Frameworks/AdobeMPS.framework/Versions/A/AdobeMPS
0x103dcd000 - 0x1040f8ff7 +AdobeAGM ??? (???) <52E17D56-6E7A-A635-82ED-5DE1F3E5045D> /Applications/Adobe Photoshop CS5/Adobe Photoshop CS5.app/Contents/Frameworks/AdobeAGM.framework/Versions/A/AdobeAGM
0x1041c5000 - 0x1044edfe7 +AdobeCoolType ??? (???) <9E03F47A-06A3-F1F4-AC4C-76F12FACC294> /Applications/Adobe Photoshop CS5/Adobe Photoshop CS5.app/Contents/Frameworks/AdobeCoolType.framework/Versions/A/AdobeCoolType
0x104585000 - 0x1045a6ff7 +AdobeBIBUtils ??? (???) <F7150688-2C15-0F0C-AF24-93ED82FC321A> /Applications/Adobe Photoshop CS5/Adobe Photoshop CS5.app/Contents/Frameworks/AdobeBIBUtils.framework/Versions/A/AdobeBIBUtils
0x1045b3000 - 0x1045deff6 +AdobeAXE8SharedExpat ??? (???) <7E809606-BF97-DB3A-E465-156446E56D00> /Applications/Adobe Photoshop CS5/Adobe Photoshop CS5.app/Contents/Frameworks/AdobeAXE8SharedExpat.framework/Versions/A/AdobeAXE8SharedExpat
0x1045f0000 - 0x104734fef +WRServices ??? (???) <76354373-F0BD-0BAF-6FC0-B96DBB371755> /Applications/Adobe Photoshop CS5/Adobe Photoshop CS5.app/Contents/Frameworks/WRServices.framework/Versions/A/WRServices
0x10477b000 - 0x1047e0fff +aif_core ??? (???) <12FA670E-05A8-1FCB-A7A2-AAE68728EA30> /Applications/Adobe Photoshop CS5/Adobe Photoshop CS5.app/Contents/Frameworks/aif_core.framework/Versions/A/aif_core
0x1047fc000 - 0x104812fff +data_flow ??? (???) <9C5D39A6-D2A2-9B6A-8B64-D1B59396C112> /Applications/Adobe Photoshop CS5/Adobe Photoshop CS5.app/Contents/Frameworks/data_flow.framework/Versions/A/data_flow
0x10482a000 - 0x1048c0fff +image_flow ??? (???) <B72AA922-0D68-D57E-96B1-2E009B0AD4AE> /Applications/Adobe Photoshop CS5/Adobe Photoshop CS5.app/Contents/Frameworks/image_flow.framework/Versions/A/image_flow
0x104937000 - 0x104955fff +image_runtime ??? (???) <32786637-C9BF-4CB6-2DF9-5D99220E00BE> /Applications/Adobe Photoshop CS5/Adobe Photoshop CS5.app/Contents/Frameworks/image_runtime.framework/Versions/A/image_runtime
0x104972000 - 0x104ba1fff +aif_ogl ??? (???) <615E7DF6-09B1-857A-74AC-E224A636BEE1> /Applications/Adobe Photoshop CS5/Adobe Photoshop CS5.app/Contents/Frameworks/aif_ogl.framework/Versions/A/aif_ogl
0x104c80000 - 0x104d13fff +AdobeOwlCanvas ??? (???) <EC667F6D-0BB6-03EA-41E8-624425B2BF4B> /Applications/Adobe Photoshop CS5/Adobe Photoshop CS5.app/Contents/Frameworks/AdobeOwlCanvas.framework/Versions/A/AdobeOwlCanvas
0x104d33000 - 0x10507cfef +com.adobe.dvaui.framework dvaui version 5.0.0 (5.0.0.0) <023E0760-0223-AB5D-758C-2C5A052F6AF4> /Applications/Adobe Photoshop CS5/Adobe Photoshop CS5.app/Contents/Frameworks/dvaui.framework/Versions/A/dvaui
0x10520c000 - 0x10538efe7 +com.adobe.dvacore.framework dvacore version 5.0.0 (5.0.0.0) <42077295-9026-D519-C057-35E07029D97B> /Applications/Adobe Photoshop CS5/Adobe Photoshop CS5.app/Contents/Frameworks/dvacore.framework/Versions/A/dvacore
0x105430000 - 0x1057a8fff +com.adobe.dvaadameve.framework dvaadameve version 5.0.0 (5.0.0.0) <0E95A0DF-038A-CFF2-EC7B-BDB905CDF5C5> /Applications/Adobe Photoshop CS5/Adobe Photoshop CS5.app/Contents/Frameworks/dvaadameve.framework/Versions/A/dvaadameve
0x1058f2000 - 0x105a06fff +AdobeACE ??? (???) <E359887D-1E7F-5E62-CB8D-37CE4DBFB4D8> /Applications/Adobe Photoshop CS5/Adobe Photoshop CS5.app/Contents/Frameworks/AdobeACE.framework/Versions/A/AdobeACE
0x105a2b000 - 0x105a47fff +AdobeBIB ??? (???) <7A792F27-42CC-2DCA-D5DF-88A2CE6C2626> /Applications/Adobe Photoshop CS5/Adobe Photoshop CS5.app/Contents/Frameworks/AdobeBIB.framework/Versions/A/AdobeBIB
0x105a51000 - 0x105abbff7 +com.adobe.amtlib amtlib 3.0.0.64 (3.0.0.64) <6B2F73C2-10AB-08B3-4AB0-A31C83D1E5E0> /Applications/Adobe Photoshop CS5/Adobe Photoshop CS5.app/Contents/Frameworks/amtlib.framework/Versions/A/amtlib
0x105aee000 - 0x105bc1ffb +AdobeJP2K ??? (???) <465D1693-BE79-590E-E1AA-BAA8061B4746> /Applications/Adobe Photoshop CS5/Adobe Photoshop CS5.app/Contents/Frameworks/AdobeJP2K.framework/Versions/A/AdobeJP2K
0x105be1000 - 0x105be5ff8 +com.adobe.ape.shim adbeape version 3.1.65.7508 (3.1.65.7508) <0C380604-C686-C2E4-0535-C1FAB230187E> /Applications/Adobe Photoshop CS5/Adobe Photoshop CS5.app/Contents/Frameworks/adbeape.framework/Versions/A/adbeape
0x105be9000 - 0x105c60fff +FileInfo ??? (???) <6D5235B9-0EB6-17CA-6457-A2507A87EA8F> /Applications/Adobe Photoshop CS5/Adobe Photoshop CS5.app/Contents/Frameworks/FileInfo.framework/Versions/A/FileInfo
0x105c81000 - 0x105cdfffd +AdobeXMP ??? (???) <561026BB-C6EA-29CE-4790-CABCB81E8884> /Applications/Adobe Photoshop CS5/Adobe Photoshop CS5.app/Contents/Frameworks/AdobeXMP.framework/Versions/A/AdobeXMP
0x105ced000 - 0x106188fff +com.nvidia.cg 2.2.0006 (???) /Applications/Adobe Photoshop CS5/Adobe Photoshop CS5.app/Contents/Frameworks/Cg.framework/Cg
0x10670e000 - 0x106764feb +com.adobe.headlights.LogSessionFramework ??? (2.0.1.011) <03B80698-2C3B-A232-F15F-8F08F8963A19> /Applications/Adobe Photoshop CS5/Adobe Photoshop CS5.app/Contents/Frameworks/LogSession.framework/Versions/A/LogSession
0x1067a9000 - 0x1067ceffe +adobepdfsettings ??? (???) <56E7F033-6032-2EC2-250E-43F1EBD123B1> /Applications/Adobe Photoshop CS5/Adobe Photoshop CS5.app/Contents/Frameworks/adobepdfsettings.framework/Versions/A/adobepdfsettings
0x106808000 - 0x10680dffd +com.adobe.AdobeCrashReporter 3.0 (3.0.20100302) <DFFB9A08-8369-D65F-161F-7C61D562E307> /Applications/Adobe Photoshop CS5/Adobe Photoshop CS5.app/Contents/Frameworks/AdobeCrashReporter.framework/Versions/A/AdobeCrashReporter
0x106812000 - 0x1069adfff +com.adobe.PlugPlug 2.0.0.746 (2.0.0.746) <CB23C5AA-0E4B-182B-CB88-57DD32893F92> /Applications/Adobe Photoshop CS5/Adobe Photoshop CS5.app/Contents/Frameworks/PlugPlug.framework/Versions/A/PlugPlug
0x106a55000 - 0x106a6efeb +libtbb.dylib ??? (???) /Applications/Adobe Photoshop CS5/Adobe Photoshop CS5.app/Contents/Frameworks/libtbb.dylib
0x106a7f000 - 0x106a85feb +libtbbmalloc.dylib ??? (???) /Applications/Adobe Photoshop CS5/Adobe Photoshop CS5.app/Contents/Frameworks/libtbbmalloc.dylib
0x106a8c000 - 0x106a8cff7 libmx.A.dylib 315.0.0 (compatibility 1.0.0) <B146C134-CE18-EC95-12F8-E5C2BCB43A6B> /usr/lib/libmx.A.dylib
0x106a8f000 - 0x106a97ff3 +com.adobe.boost_threads.framework boost_threads version 5.0.0 (5.0.0.0) <6858DF5A-F020-22A7-B945-14EC277724D4> /Applications/Adobe Photoshop CS5/Adobe Photoshop CS5.app/Contents/Frameworks/boost_threads.framework/Versions/A/boost_threads
0x106a9e000 - 0x106b84fe7 libcrypto.0.9.7.dylib 0.9.7 (compatibility 0.9.7) <26FC56A6-EFD6-22FA-E1F1-4E1BA61C85BB> /usr/lib/libcrypto.0.9.7.dylib
0x106f52000 - 0x106f54fef com.apple.textencoding.unicode 2.3 (2.3) <B254327D-2C4A-3296-5812-6F74C7FFECD9> /System/Library/TextEncodings/Unicode Encodings.bundle/Contents/MacOS/Unicode Encodings
0x106ff1000 - 0x106ff2fff libCyrillicConverter.dylib 49.0.0 (compatibility 1.0.0) <763A4C25-2E76-3F9B-BBC4-4A022F0360E0> /System/Library/CoreServices/Encodings/libCyrillicConverter.dylib
0x109059000 - 0x1090c9ff6 +com.adobe.amt.services AMTServices 3.0.0.64 (BuildVersion: 3.0; BuildDate: Mon Jan 26 2010 21:49:00) (3.0.0.64) <52FF1F9B-9991-ECE2-C7E3-09DA1B368CBE> /Applications/Adobe Photoshop CS5/Adobe Photoshop CS5.app/Contents/Frameworks/amtservices.framework/Versions/a/amtservices
0x1118e1000 - 0x1118f8fe7 libJapaneseConverter.dylib 49.0.0 (compatibility 1.0.0) <92A88D03-FABF-24D6-992A-19B023390FA1> /System/Library/CoreServices/Encodings/libJapaneseConverter.dylib
0x1118fc000 - 0x11191dfef libKoreanConverter.dylib 49.0.0 (compatibility 1.0.0) <835A6BD9-EA17-57B7-17D6-08DC53EBA240> /System/Library/CoreServices/Encodings/libKoreanConverter.dylib
0x111921000 - 0x111930fe7 libSimplifiedChineseConverter.dylib 49.0.0 (compatibility 1.0.0) <727A0DD2-6866-5E0D-2AA5-43F5035D7130> /System/Library/CoreServices/Encodings/libSimplifiedChineseConverter.dylib
0x111934000 - 0x111946fff libTraditionalChineseConverter.dylib 49.0.0 (compatibility 1.0.0) <F86B5994-BD36-2B87-2C4A-523668E29192> /System/Library/CoreServices/Encodings/libTraditionalChineseConverter.dylib
0x11194a000 - 0x111952fff +com.adobe.asneu.framework asneu version 1.7.0.1 (1.7.0.1) <3D59CB21-F5C7-4232-AB00-DFEB04206024> /Applications/Adobe Photoshop CS5/Adobe Photoshop CS5.app/Contents/Frameworks/asneu.framework/Versions/a/asneu
0x1119e5000 - 0x1119ecfff +Enable Async IO ??? (???) <9C98DC9E-5974-FE5D-75C3-16BC4738DCC8> /Applications/Adobe Photoshop CS5/Plug-Ins/Extensions/Enable Async IO.plugin/Contents/MacOS/Enable Async IO
0x11336f000 - 0x113378fff +FastCore ??? (???) <F1D1C94D-4FE1-F969-6FC2-8D81837CA5E1> /Applications/Adobe Photoshop CS5/Plug-Ins/Extensions/FastCore.plugin/Contents/MacOS/FastCore
0x113385000 - 0x1133e8ff3 +MMXCore ??? (???) <2DB6FA8E-4373-9823-C4F5-A9F5F8F80717> /Applications/Adobe Photoshop CS5/Plug-Ins/Extensions/MMXCore.plugin/Contents/MacOS/MMXCore
0x11346e000 - 0x1134d9ff0 +MultiProcessor Support ??? (???) <1334B570-C713-3767-225F-3C1CBA1BF37C> /Applications/Adobe Photoshop CS5/Plug-Ins/Extensions/MultiProcessor Support.plugin/Contents/MacOS/MultiProcessor Support
0x115a4b000 - 0x115a67ff7 +MeasurementCore ??? (???) <0E3BE9B3-FF3D-78A6-38EC-5CB0828B80EB> /Applications/Adobe Photoshop CS5/Plug-Ins/Measurements/MeasurementCore.plugin/Contents/MacOS/MeasurementCore
0x115ac7000 - 0x115ae7ffb +com.adobe.ape adbeapecore version 3.1.65.7508 (3.1.65.7508) <284C86BE-ACD8-31DD-E58D-544F581BC93B> /Library/Application Support/Adobe/APE/3.1/adbeapecore.framework/adbeapecore
0x115f00000 - 0x11615cfef +com.adobe.PSAutomate 12.0 (12.0) <35AEF3A8-2E64-71D1-39ED-A34760CAAC29> /Applications/Adobe Photoshop CS5/Plug-Ins/Extensions/ScriptingSupport.plugin/Contents/MacOS/ScriptingSupport
0x116372000 - 0x116416ffb +com.adobe.AdobeExtendScript ExtendScript 4.1.23 (4.1.23.7573) <332E7D8D-BF42-3177-9BC5-033942DE35E0> /Applications/Adobe Photoshop CS5/Adobe Photoshop CS5.app/Contents/Frameworks/AdobeExtendScript.framework/Versions/A/AdobeExtendScript
0x116478000 - 0x116518fef +com.adobe.AdobeScCore ScCore 4.1.23 (4.1.23.7573) <53DD7281-5B59-7FF5-DB57-C9FD60E524C7> /Applications/Adobe Photoshop CS5/Adobe Photoshop CS5.app/Contents/Frameworks/AdobeScCore.framework/Versions/A/AdobeScCore
0x1165cf000 - 0x1165d3fff com.apple.audio.AudioIPCPlugIn 1.1.2 (1.1.2) <4E3DABFF-191F-7E57-2A78-12E34D68FAC4> /System/Library/Extensions/AudioIPCDriver.kext/Contents/Resources/AudioIPCPlugIn.bundle/Contents/MacOS/AudioIPCPlugIn
0x11676a000 - 0x116770fff com.apple.audio.AppleHDAHALPlugIn 1.8.4 (1.8.4fc3) <106DABA7-C630-C839-50CE-60D5992E6091> /System/Library/Extensions/AppleHDA.kext/Contents/PlugIns/AppleHDAHALPlugIn.bundle/Contents/MacOS/AppleHDAHALPlugIn
0x116775000 - 0x1167b3ff7 com.apple.DP.ScreenInputDevice 13.0 (13.0) <22174597-D163-7A20-C82A-C00C2CA19640> /System/Library/PrivateFrameworks/CoreMediaIOServices.framework/Resources/AppleScreenInputDevice.plugin/Contents/MacOS/AppleScreenInputDevice
0x116f00000 - 0x117d47fcf +com.adobe.adobeswfl ??? (2.0.0.7489) <DBD38111-48D6-C031-EF50-D034C94ED38B> /Library/Application Support/Adobe/APE/3.1/adbeapecore.framework/Resources/AdobeSWFL.bundle/Contents/MacOS/AdobeSWFL
0x119244000 - 0x11926efef com.apple.mio.DAL.VDC_4 130.0 (1035) <605498BB-69D1-09C2-2720-FC7FBE9C289E> /System/Library/PrivateFrameworks/CoreMediaIOServices.framework/Resources/VDC.plugin/Contents/MacOS/VDC
0x119ac2000 - 0x119afffeb +com.adobe.AAM.AdobeUpdaterNotificationFramework UpdaterNotifications 1.0.0.64 (1.0.0.64) <CD8BD7C7-0F66-29B6-C158-A6EF8DF69996> /Applications/Adobe Photoshop CS5/Adobe Photoshop CS5.app/Contents/Frameworks/updaternotifications.framework/Versions/a/UpdaterNotifications
0x119b1a000 - 0x119b42fef +ServiceManager-Launcher.dylib ??? (???) <4608E5E7-7F22-A4FF-527C-E97EA339FCCC> /Library/Application Support/Adobe/CS5ServiceManager/lib/ServiceManager-Launcher.dylib
0x119e00000 - 0x11a598feb +com.adobe.CameraRaw 6.0 (6.0.0d205) <35A90E86-FBFE-D694-CAA7-C9471E98611A> /Library/Application Support/Adobe/Plug-Ins/CS5/File Formats/Camera Raw.plugin/Contents/MacOS/Camera Raw
0x11de13000 - 0x11de2dfff +com.adobe.pip ??? (5.0.0.2021) <47380937-5088-41F7-50FA-ADAC9B15C783> /Applications/Adobe Photoshop CS5/Adobe Photoshop CS5.app/Contents/Frameworks/AdobePIP.framework/AdobePIP
0x11de9a000 - 0x11e027fe7 GLEngine ??? (???) <85971DA9-5140-A226-7898-21B2D6C6F7FE> /System/Library/Frameworks/OpenGL.framework/Resources/GLEngine.bundle/GLEngine
0x11e058000 - 0x11e47aff7 libclh.dylib 3.1.1 C (3.1.1) <08830748-80A3-2928-BDC9-D5512BE2715C> /System/Library/Extensions/GeForceGLDriver.bundle/Contents/MacOS/libclh.dylib
0x11e4a8000 - 0x11e4cefe7 GLRendererFloat ??? (???) <684EBDC4-63B4-BC55-60EF-0F6A7D666551> /System/Library/Frameworks/OpenGL.framework/Resources/GLRendererFloat.bundle/GLRendererFloat
0x11ffe3000 - 0x11ffe6fef libLatinSuppConverter.dylib 49.0.0 (compatibility 1.0.0) <C13E084D-DF38-B1BC-9772-7B03428E7969> /System/Library/CoreServices/Encodings/libLatinSuppConverter.dylib
0x121a9f000 - 0x121e16fec +com.adobe.standard.multiplugin 12.0 (12.0) <6A10EB0E-BAED-6911-C012-323995F1514D> /Applications/Adobe Photoshop CS5/Plug-Ins/Filters/Standard Multiplugin.plugin/Contents/MacOS/Standard Multiplugin
0x12295b000 - 0x12297dff7 com.apple.URLMount.CIFSPlugin 4.0.0 (4.0.0) <7EC413B1-DEA3-A503-3628-F3B719E18839> /System/Library/Filesystems/NetFSPlugins/smb.bundle/Contents/MacOS/smb
0x122b0f000 - 0x123127fef +com.adobe.S4W 12.0 (12.0) <0F19BE78-94B0-7039-12C1-7ED3B8021369> /Applications/Adobe Photoshop CS5/Plug-Ins/Import-Export/Save for Web.plugin/Contents/MacOS/Save for Web
0x200000000 - 0x2006c3fe7 com.apple.GeForceGLDriver 1.6.10 (6.1.0) <8946B71C-EA96-5AFA-B8B6-E9029EAF56CD> /System/Library/Extensions/GeForceGLDriver.bundle/Contents/MacOS/GeForceGLDriver
0x7fff5fc00000 - 0x7fff5fc3bdef dyld 132.1 (???) <B633F790-4DDB-53CD-7ACF-2A3682BCEA9F> /usr/lib/dyld
0x7fff80020000 - 0x7fff80020ff7 com.apple.vecLib 3.6 (vecLib 3.6) <08D3D45D-908B-B86A-00BA-0F978D2702A7> /System/Library/Frameworks/vecLib.framework/Versions/A/vecLib
0x7fff80021000 - 0x7fff80065ff7 com.apple.ImageCaptureCore 1.0.1 (1.0.1) <788A9BF0-691B-FE10-7385-AF4A7A786478> /System/Library/Frameworks/ImageCaptureCore.framework/Versions/A/ImageCaptureCore
0x7fff8008a000 - 0x7fff801a3fef libGLProgrammability.dylib ??? (???) <9D2B1DA3-C581-73F8-A2E4-01C4CE1C3B32> /System/Library/Frameworks/OpenGL.framework/Versions/A/Libraries/libGLProgrammability.dylib
0x7fff801a4000 - 0x7fff80259fe7 com.apple.ink.framework 1.3.3 (107) <FFC46EE0-3544-A459-2AB9-94778A75E3D4> /System/Library/Frameworks/Carbon.framework/Versions/A/Frameworks/Ink.framework/Versions/A/Ink
0x7fff802a7000 - 0x7fff80337fff com.apple.SearchKit 1.3.0 (1.3.0) <4175DC31-1506-228A-08FD-C704AC9DF642> /System/Library/Frameworks/CoreServices.framework/Versions/A/Frameworks/SearchKit.framework/Versions/A/SearchKit
0x7fff8036e000 - 0x7fff8039efef com.apple.shortcut 1.1 (1.1) <A99C9D8E-290B-B1E4-FEA5-CC5F2FB9C18D> /System/Library/PrivateFrameworks/Shortcut.framework/Versions/A/Shortcut
0x7fff803aa000 - 0x7fff803f9fef libTIFF.dylib ??? (???) <D6BED22B-A092-EC70-6E1D-0B52FA6FBBDE> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/ImageIO.framework/Versions/A/Resources/libTIFF.dylib
0x7fff803fa000 - 0x7fff803fbfff liblangid.dylib ??? (???) <EA4D1607-2BD5-2EE2-2A3B-632EEE5A444D> /usr/lib/liblangid.dylib
0x7fff80409000 - 0x7fff80444fff com.apple.AE 496.4 (496.4) <CBEDB6A1-FD85-F842-4EB8-CC289FAE0F24> /System/Library/Frameworks/CoreServices.framework/Versions/A/Frameworks/AE.framework/Versions/A/AE
0x7fff8044e000 - 0x7fff80471fff com.apple.opencl 12.1 (12.1) <AB00CB6B-5BBD-C819-007A-08C0B110AB93> /System/Library/Frameworks/OpenCL.framework/Versions/A/OpenCL
0x7fff80472000 - 0x7fff80512fff com.apple.LaunchServices 362.1 (362.1) <2740103A-6C71-D99F-8C6F-FA264546AD8F> /System/Library/Frameworks/CoreServices.framework/Versions/A/Frameworks/LaunchServices.framework/Versions/A/LaunchServices
0x7fff80513000 - 0x7fff80516ff7 libCoreVMClient.dylib ??? (???) <9A0E75A9-7964-CAF9-DEB7-11A073530F64> /System/Library/Frameworks/OpenGL.framework/Versions/A/Libraries/libCoreVMClient.dylib
0x7fff80517000 - 0x7fff80575ff7 com.apple.framework.IOKit 2.0 (???) <516EB9AF-4723-FC17-984B-918115E53459> /System/Library/Frameworks/IOKit.framework/Versions/A/IOKit
0x7fff80576000 - 0x7fff80581ff7 com.apple.speech.recognition.framework 3.11.1 (3.11.1) <F0DDF27E-DB55-07CE-E548-C62095BE8167> /System/Library/Frameworks/Carbon.framework/Versions/A/Frameworks/SpeechRecognition.framework/Versions/A/SpeechRecognition
0x7fff80582000 - 0x7fff805d7fef com.apple.framework.familycontrols 2.0.1 (2010) <E6E1C44A-6513-92DF-F71E-C157C485024C> /System/Library/PrivateFrameworks/FamilyControls.framework/Versions/A/FamilyControls
0x7fff805d8000 - 0x7fff805eefff com.apple.ImageCapture 6.0 (6.0) <5B5AF8FB-C12A-B51F-94FC-3EC4698E818E> /System/Library/Frameworks/Carbon.framework/Versions/A/Frameworks/ImageCapture.framework/Versions/A/ImageCapture
0x7fff805ef000 - 0x7fff8061aff7 libxslt.1.dylib 3.24.0 (compatibility 3.0.0) <87A0B228-B24A-C426-C3FB-B40D7258DD49> /usr/lib/libxslt.1.dylib
0x7fff8061b000 - 0x7fff8062fff7 com.apple.speech.synthesis.framework 3.10.35 (3.10.35) <621B7415-A0B9-07A7-F313-36BEEDD7B132> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/SpeechSynthesis.framework/Versions/A/SpeechSynthesis
0x7fff80630000 - 0x7fff80677fef com.apple.QuickLookFramework 2.2 (327.4) <4E1658D4-F268-2A82-C095-1D01E9EAD05F> /System/Library/Frameworks/QuickLook.framework/Versions/A/QuickLook
0x7fff80678000 - 0x7fff80678ff7 com.apple.Carbon 150 (152) <8D8CF535-90BE-691C-EC1B-63FBE2162C9B> /System/Library/Frameworks/Carbon.framework/Versions/A/Carbon
0x7fff80679000 - 0x7fff8067aff7 com.apple.TrustEvaluationAgent 1.1 (1) <51867586-1C71-AE37-EAAD-535A58DD3550> /System/Library/PrivateFrameworks/TrustEvaluationAgent.framework/Versions/A/TrustEvaluationAgent
0x7fff8067b000 - 0x7fff80761fe7 com.apple.DesktopServices 1.5.5 (1.5.5) <EFCBA7C3-A6CE-9550-FE19-73BB3D046549> /System/Library/PrivateFrameworks/DesktopServicesPriv.framework/Versions/A/DesktopServicesPriv
0x7fff807bf000 - 0x7fff807c6fff com.apple.OpenDirectory 10.6 (10.6) <72A65D76-7831-D31E-F1B3-9E48BF26A98B> /System/Library/Frameworks/OpenDirectory.framework/Versions/A/OpenDirectory
0x7fff807c7000 - 0x7fff807cdff7 com.apple.DiskArbitration 2.3 (2.3) <857F6E43-1EF4-7D53-351B-10DE0A8F992A> /System/Library/Frameworks/DiskArbitration.framework/Versions/A/DiskArbitration
0x7fff807ce000 - 0x7fff807d6fff com.apple.DisplayServicesFW 2.2.2 (251) <3E7C0CF8-117D-9C7F-577C-C199901DFF37> /System/Library/PrivateFrameworks/DisplayServices.framework/Versions/A/DisplayServices
0x7fff807d7000 - 0x7fff80818fef com.apple.QD 3.35 (???) <78C9A560-E6F7-DC4F-F85E-E63CF8A98F0B> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/QD.framework/Versions/A/QD
0x7fff80819000 - 0x7fff808d6ff7 com.apple.CoreServices.OSServices 357 (357) <7CFA1963-B639-BE99-12F1-220DF214AB50> /System/Library/Frameworks/CoreServices.framework/Versions/A/Frameworks/OSServices.framework/Versions/A/OSServices
0x7fff808d7000 - 0x7fff80920fef libGLU.dylib ??? (???) <FEDE662B-46B2-26D8-3E57-84E4C15A4FB2> /System/Library/Frameworks/OpenGL.framework/Versions/A/Libraries/libGLU.dylib
0x7fff8097d000 - 0x7fff8097dff7 com.apple.Cocoa 6.6 (???) <68B0BE46-6E24-C96F-B341-054CF9E8F3B6> /System/Library/Frameworks/Cocoa.framework/Versions/A/Cocoa
0x7fff8097e000 - 0x7fff80a3efe7 libFontParser.dylib ??? (???) <2C6B6ABB-7EF0-3CD8-97D2-9B4534D0056C> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/ATS.framework/Versions/A/Resources/libFontParser.dylib
0x7fff80a3f000 - 0x7fff80a43ff7 libmathCommon.A.dylib 315.0.0 (compatibility 1.0.0) <95718673-FEEE-B6ED-B127-BCDBDB60D4E5> /usr/lib/system/libmathCommon.A.dylib
0x7fff80a44000 - 0x7fff80e87fef libLAPACK.dylib 219.0.0 (compatibility 1.0.0) <0CC61C98-FF51-67B3-F3D8-C5E430C201A9> /System/Library/Frameworks/Accelerate.framework/Versions/A/Frameworks/vecLib.framework/Versions/A/libLAPACK.dylib
0x7fff80e88000 - 0x7fff810f1ff7 com.apple.QuartzComposer 4.1 (156.13) <0A7E8CDB-77DB-F96F-9CA4-867E9D45EB69> /System/Library/Frameworks/Quartz.framework/Versions/A/Frameworks/QuartzComposer.framework/Versions/A/QuartzComposer
0x7fff810f2000 - 0x7fff81377fef com.apple.security 6.1.1 (37594) <ED08CC62-42E2-E97F-E807-C09EB1CF950D> /System/Library/Frameworks/Security.framework/Versions/A/Security
0x7fff81378000 - 0x7fff81378ff7 com.apple.ApplicationServices 38 (38) <10A0B9E9-4988-03D4-FC56-DDE231A02C63> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/ApplicationServices
0x7fff81379000 - 0x7fff81444fe7 ColorSyncDeprecated.dylib 4.6.0 (compatibility 1.0.0) <C85548CF-DED1-4672-0167-3F32A6DD0D55> /System/Library/Frameworks/ApplicationServices.framework/Frameworks/ColorSync.framework/Versions/A/Resources/ColorSyncDeprecated.dylib
0x7fff81445000 - 0x7fff81445ff7 com.apple.quartzframework 1.5 (1.5) <B182B579-BCCE-81BF-8DA2-9E0B7BDF8516> /System/Library/Frameworks/Quartz.framework/Versions/A/Quartz
0x7fff814fc000 - 0x7fff81737fef com.apple.imageKit 2.0.3 (1.0) <9F7CBDFB-EBDC-5B86-ED43-5195F4AE9D52> /System/Library/Frameworks/Quartz.framework/Versions/A/Frameworks/ImageKit.framework/Versions/A/ImageKit
0x7fff81738000 - 0x7fff81738ff7 com.apple.CoreServices 44 (44) <210A4C56-BECB-E3E4-B6EE-7EC53E02265D> /System/Library/Frameworks/CoreServices.framework/Versions/A/CoreServices
0x7fff81739000 - 0x7fff81776ff7 libFontRegistry.dylib ??? (???) <12FDAEB9-01F7-5562-DBC6-7B2374CCAEA1> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/ATS.framework/Versions/A/Resources/libFontRegistry.dylib
0x7fff81777000 - 0x7fff817dffff com.apple.MeshKitRuntime 1.1 (49.2) <1F4C9AB5-9D3F-F91D-DB91-B78610562ECC> /System/Library/PrivateFrameworks/MeshKit.framework/Versions/A/Frameworks/MeshKitRuntime.framework/Versions/A/MeshKitRuntime
0x7fff817e0000 - 0x7fff821d5fe7 com.apple.AppKit 6.6.5 (1038.29) <AC1ED9CC-6149-36EE-AA57-15BA4F05EAAA> /System/Library/Frameworks/AppKit.framework/Versions/C/AppKit
0x7fff821d6000 - 0x7fff821e1ff7 com.apple.HelpData 2.0.4 (34) <B44D2E2A-BC1E-CD63-F8A1-C9465491693A> /System/Library/PrivateFrameworks/HelpData.framework/Versions/A/HelpData
0x7fff82226000 - 0x7fff8225fff7 com.apple.MeshKit 1.1 (49.2) <3795F201-4A5F-3D40-57E0-87AD6B714239> /System/Library/PrivateFrameworks/MeshKit.framework/Versions/A/MeshKit
0x7fff823cf000 - 0x7fff824e6fef libxml2.2.dylib 10.3.0 (compatibility 10.0.0) <EE067D7E-15B3-F043-6FBD-10BA31FE76C7> /usr/lib/libxml2.2.dylib
0x7fff824e7000 - 0x7fff824f6ff7 com.apple.opengl 1.6.7 (1.6.7) <63D8F554-2488-4811-EEC7-672FCFAF731B> /System/Library/Frameworks/OpenGL.framework/Versions/A/OpenGL
0x7fff824f7000 - 0x7fff82778fe7 com.apple.Foundation 6.6.2 (751.21) <49BEB8B8-BC1F-B4E4-3D90-A141AC764A8D> /System/Library/Frameworks/Foundation.framework/Versions/C/Foundation
0x7fff82779000 - 0x7fff82779ff7 com.apple.Accelerate.vecLib 3.6 (vecLib 3.6) <DA9BFF01-40DF-EBD5-ABB7-787DAF2D77CF> /System/Library/Frameworks/Accelerate.framework/Versions/A/Frameworks/vecLib.framework/Versions/A/vecLib
0x7fff8277a000 - 0x7fff828effef com.apple.CoreFoundation 6.6.1 (550.19) <1051BA2C-DCD7-787C-907C-A50D12AA6049> /System/Library/Frameworks/CoreFoundation.framework/Versions/A/CoreFoundation
0x7fff8292d000 - 0x7fff82995fff com.apple.AppleVAFramework 4.8.11 (4.8.11) <14AE8878-A7A6-D024-3DD4-BBFB5E7FC008> /System/Library/PrivateFrameworks/AppleVA.framework/Versions/A/AppleVA
0x7fff82996000 - 0x7fff82a4cfff libobjc.A.dylib 227.0.0 (compatibility 1.0.0) <F206BE6D-8777-AE6C-B367-7BEA76C14241> /usr/lib/libobjc.A.dylib
0x7fff82a4d000 - 0x7fff82acffff com.apple.QuickLookUIFramework 2.2 (327.4) <C35D9F62-73D0-262C-B0CE-BFF64E230588> /System/Library/Frameworks/Quartz.framework/Versions/A/Frameworks/QuickLookUI.framework/Versions/A/QuickLookUI
0x7fff82e03000 - 0x7fff82e15fe7 libsasl2.2.dylib 3.15.0 (compatibility 3.0.0) <76B83C8D-8EFE-4467-0F75-275648AFED97> /usr/lib/libsasl2.2.dylib
0x7fff83156000 - 0x7fff831a7fe7 com.apple.HIServices 1.8.0 (???) <1ABA7802-C1E4-06A0-9035-2792CC915BF6> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/HIServices.framework/Versions/A/HIServices
0x7fff831a8000 - 0x7fff831ddff7 libcups.2.dylib 2.8.0 (compatibility 2.0.0) <0C865212-6427-5DE4-40C4-B5739491B691> /usr/lib/libcups.2.dylib
0x7fff831de000 - 0x7fff8339cfff libicucore.A.dylib 40.0.0 (compatibility 1.0.0) <1B6C3785-BE99-EAD5-69AB-B28C40466A82> /usr/lib/libicucore.A.dylib
0x7fff8339d000 - 0x7fff836d0fef com.apple.CoreServices.CarbonCore 861.6 (861.6) <652B1704-460F-F0D1-B917-B08698E0EF7F> /System/Library/Frameworks/CoreServices.framework/Versions/A/Frameworks/CarbonCore.framework/Versions/A/CarbonCore
0x7fff83721000 - 0x7fff83750ff7 com.apple.quartzfilters 1.6.0 (1.6.0) <9CECB4FC-1CCF-B8A2-B935-5888B21CBEEF> /System/Library/Frameworks/Quartz.framework/Versions/A/Frameworks/QuartzFilters.framework/Versions/A/QuartzFilters
0x7fff83871000 - 0x7fff839e1fef com.apple.MediaToolbox 0.484.5 (484.5) <DA4772AD-9430-024F-39FF-8B9D4B52DCD2> /System/Library/PrivateFrameworks/MediaToolbox.framework/Versions/A/MediaToolbox
0x7fff839e2000 - 0x7fff83a9bfff libsqlite3.dylib 9.6.0 (compatibility 9.0.0) <5A15E12A-AE8F-1A36-BBC7-564E7D7AD0FB> /usr/lib/libsqlite3.dylib
0x7fff83b36000 - 0x7fff83b3cff7 IOSurface ??? (???) <F998C45A-CCCF-2306-F37A-389EE0054CB3> /System/Library/Frameworks/IOSurface.framework/Versions/A/IOSurface
0x7fff83b3d000 - 0x7fff83bc9fef SecurityFoundation 36840.0.0 (compatibility 1.0.0) <B69E2FF9-A698-4923-BC8B-180224B6EF75> /System/Library/Frameworks/SecurityFoundation.framework/Versions/A/SecurityFoundation
0x7fff83bca000 - 0x7fff83be0fef libbsm.0.dylib ??? (???) <42D3023A-A1F7-4121-6417-FCC6B51B3E90> /usr/lib/libbsm.0.dylib
0x7fff83be1000 - 0x7fff83c30ff7 com.apple.DirectoryService.PasswordServerFramework 6.0 (6.0) <14FD0978-4BE0-336B-A19E-F388694583EB> /System/Library/PrivateFrameworks/PasswordServer.framework/Versions/A/PasswordServer
0x7fff83c74000 - 0x7fff83db2fff com.apple.CoreData 102.1 (251) <32233D4D-00B7-CE14-C881-6BF19FD05A03> /System/Library/Frameworks/CoreData.framework/Versions/A/CoreData
0x7fff83dbf000 - 0x7fff83ee4fef com.apple.audio.toolbox.AudioToolbox 1.6.3 (1.6.3) <4DCCD01F-7516-4240-09DC-EE553317D345> /System/Library/Frameworks/AudioToolbox.framework/Versions/A/AudioToolbox
0x7fff83ee5000 - 0x7fff83ee6fff com.apple.MonitorPanelFramework 1.3.0 (1.3.0) <5062DACE-FCE7-8E41-F5F6-58821778629C> /System/Library/PrivateFrameworks/MonitorPanel.framework/Versions/A/MonitorPanel
0x7fff83ee7000 - 0x7fff8427ffe7 com.apple.QuartzCore 1.6.1 (227.18) <ADB9E286-C5AB-3505-35D2-849E1F560A2A> /System/Library/Frameworks/QuartzCore.framework/Versions/A/QuartzCore
0x7fff84280000 - 0x7fff84463fef libType1Scaler.dylib ??? (???) <98F6C486-4DA0-0903-CDC6-67C85ED206B2> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/ATS.framework/Versions/A/Resources/libType1Scaler.dylib
0x7fff84464000 - 0x7fff84468ff7 libCGXType.A.dylib 543.33.0 (compatibility 64.0.0) <27FF96BC-1F15-A52D-3339-4BFC49D6810E> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/CoreGraphics.framework/Versions/A/Resources/libCGXType.A.dylib
0x7fff84469000 - 0x7fff84476fe7 libCSync.A.dylib 543.33.0 (compatibility 64.0.0) <540820E4-75E3-B2A0-5EF2-222304250CD8> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/CoreGraphics.framework/Versions/A/Resources/libCSync.A.dylib
0x7fff84477000 - 0x7fff8448dff7 com.apple.MultitouchSupport.framework 204.12.1 (204.12.1) <38D0D705-FD15-38AE-A8B9-F9970508D1BD> /System/Library/PrivateFrameworks/MultitouchSupport.framework/Versions/A/MultitouchSupport
0x7fff8448e000 - 0x7fff8478cfef com.apple.HIToolbox 1.6.2 (???) <759E1C39-58EB-C434-3E33-416C04AFE6DC> /System/Library/Frameworks/Carbon.framework/Versions/A/Frameworks/HIToolbox.framework/Versions/A/HIToolbox
0x7fff8478d000 - 0x7fff84867ff7 com.apple.vImage 4.0 (4.0) <354F34BF-B221-A3C9-2CA7-9BE5E14AD5AD> /System/Library/Frameworks/Accelerate.framework/Versions/A/Frameworks/vImage.framework/Versions/A/vImage
0x7fff84868000 - 0x7fff84877fff com.apple.NetFS 3.2.1 (3.2.1) <FF21DB1E-F425-1005-FB70-BC19CAF4006E> /System/Library/Frameworks/NetFS.framework/Versions/A/NetFS
0x7fff84878000 - 0x7fff84948fff com.apple.CFNetwork 454.9.4 (454.9.4) <33395EDD-D653-6EAD-57A6-9C718D69D2DA> /System/Library/Frameworks/CoreServices.framework/Versions/A/Frameworks/CFNetwork.framework/Versions/A/CFNetwork
0x7fff84949000 - 0x7fff8494aff7 com.apple.audio.units.AudioUnit 1.6.3 (1.6.3) <D4183AC4-8A65-8368-A9AF-E2A13D18519C> /System/Library/Frameworks/AudioUnit.framework/Versions/A/AudioUnit
0x7fff84a4c000 - 0x7fff84a8fff7 libRIP.A.dylib 543.33.0 (compatibility 64.0.0) <677BA546-F215-C5C8-9C65-305E43633FDA> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/CoreGraphics.framework/Versions/A/Resources/libRIP.A.dylib
0x7fff84a90000 - 0x7fff84c4fff7 libSystem.B.dylib 125.0.1 (compatibility 1.0.0) <CB9A4929-61AF-DE71-5635-133E9EC95783> /usr/lib/libSystem.B.dylib
0x7fff84c62000 - 0x7fff84d71fe7 libcrypto.0.9.8.dylib 0.9.8 (compatibility 0.9.8) <826C2437-F760-E049-1719-9C69A3BAA4B0> /usr/lib/libcrypto.0.9.8.dylib
0x7fff84d72000 - 0x7fff84dbaff7 libvDSP.dylib 268.0.1 (compatibility 1.0.0) <170DE04F-89AB-E295-0880-D69CAFBD7979> /System/Library/Frameworks/Accelerate.framework/Versions/A/Frameworks/vecLib.framework/Versions/A/libvDSP.dylib
0x7fff84dbb000 - 0x7fff84dfefff libtidy.A.dylib ??? (???) <8AF4DB3A-7BDB-7AF7-0E9C-413BBBD0E380> /usr/lib/libtidy.A.dylib
0x7fff84dff000 - 0x7fff84e02fff com.apple.help 1.3.1 (41) <54B79BA2-B71B-268E-8752-5C8EE00E49E4> /System/Library/Frameworks/Carbon.framework/Versions/A/Frameworks/Help.framework/Versions/A/Help
0x7fff84e03000 - 0x7fff84e4aff7 com.apple.coreui 2 (114) <D7645B59-0431-6283-7322-957D944DAB21> /System/Library/PrivateFrameworks/CoreUI.framework/Versions/A/CoreUI
0x7fff84e5a000 - 0x7fff851d0fe7 com.apple.RawCamera.bundle 3.0.2 (527) <E70071D3-CC39-4B14-2AA3-EAC42BC84AD4> /System/Library/CoreServices/RawCamera.bundle/Contents/MacOS/RawCamera
0x7fff851d1000 - 0x7fff856dafe7 com.apple.VideoToolbox 0.484.5 (484.5) <174EF984-21FE-071C-4AB4-DE345BF87791> /System/Library/PrivateFrameworks/VideoToolbox.framework/Versions/A/VideoToolbox
0x7fff856db000 - 0x7fff8571cfff com.apple.SystemConfiguration 1.10.2 (1.10.2) <7DADC459-6E38-084A-B333-8332B28C244E> /System/Library/Frameworks/SystemConfiguration.framework/Versions/A/SystemConfiguration
0x7fff85949000 - 0x7fff859b3fe7 libvMisc.dylib 268.0.1 (compatibility 1.0.0) <75A8D840-4ACE-6560-0889-2AFB6BE08E59> /System/Library/Frameworks/Accelerate.framework/Versions/A/Frameworks/vecLib.framework/Versions/A/libvMisc.dylib
0x7fff859b7000 - 0x7fff859c8ff7 libz.1.dylib 1.2.3 (compatibility 1.0.0) <C1154E2E-B1CB-1FAD-77ED-B139BA1AB073> /usr/lib/libz.1.dylib
0x7fff859c9000 - 0x7fff85a15fff libauto.dylib ??? (???) <072804DF-36AD-2DBE-7EF8-639CFB79077F> /usr/lib/libauto.dylib
0x7fff85a6f000 - 0x7fff85a71fff com.apple.print.framework.Print 6.1 (237.1) <4513DB2F-737C-B43C-2D0E-23CD6E838014> /System/Library/Frameworks/Carbon.framework/Versions/A/Frameworks/Print.framework/Versions/A/Print
0x7fff85a72000 - 0x7fff8627cfe7 libBLAS.dylib 219.0.0 (compatibility 1.0.0) <FC941ECB-71D0-FAE3-DCBF-C5A619E594B8> /System/Library/Frameworks/Accelerate.framework/Versions/A/Frameworks/vecLib.framework/Versions/A/libBLAS.dylib
0x7fff862b3000 - 0x7fff869b0037 com.apple.CoreGraphics 1.543.33 (???) <359B3BC6-0152-94D2-3CAA-D8C24C0B9E65> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/CoreGraphics.framework/Versions/A/CoreGraphics
0x7fff869b1000 - 0x7fff86a30fff com.apple.audio.CoreAudio 3.2.2 (3.2.2) <2633DFAC-F6A6-489D-8DF0-F12639CCD8C4> /System/Library/Frameworks/CoreAudio.framework/Versions/A/CoreAudio
0x7fff86a31000 - 0x7fff86a76fff com.apple.CoreMediaIOServices 130.0 (1035) <6D6834F6-4DB5-03E9-3962-480BBEE176EB> /System/Library/PrivateFrameworks/CoreMediaIOServices.framework/Versions/A/CoreMediaIOServices
0x7fff86ad8000 - 0x7fff86ae9fff com.apple.DSObjCWrappers.Framework 10.6 (134) <3C08225D-517E-2822-6152-F6EB13A4ADF9> /System/Library/PrivateFrameworks/DSObjCWrappers.framework/Versions/A/DSObjCWrappers
0x7fff86b0d000 - 0x7fff86b92fff com.apple.print.framework.PrintCore 6.2 (312.5) <E736F6DC-2E69-A14D-6BCF-69D14232F8B8> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/PrintCore.framework/Versions/A/PrintCore
0x7fff86b93000 - 0x7fff86b98fff libGIF.dylib ??? (???) <0E58DF99-B3DF-6FF9-E810-CCEC0853C8B0> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/ImageIO.framework/Versions/A/Resources/libGIF.dylib
0x7fff86b99000 - 0x7fff86d1ffe7 com.apple.JavaScriptCore 6531.22 (6531.22.5) <E33572F9-95E3-85D1-5B5E-2B240E3BF2B1> /System/Library/Frameworks/JavaScriptCore.framework/Versions/A/JavaScriptCore
0x7fff86d9e000 - 0x7fff86ea8ff7 com.apple.MeshKitIO 1.1 (49.2) <F296E151-80AE-7764-B969-C2050DF26BFE> /System/Library/PrivateFrameworks/MeshKit.framework/Versions/A/Frameworks/MeshKitIO.framework/Versions/A/MeshKitIO
0x7fff86ea9000 - 0x7fff86eabfff libRadiance.dylib ??? (???) <73CE39EA-E38B-4320-8A7D-11C1A08A8A7A> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/ImageIO.framework/Versions/A/Resources/libRadiance.dylib
0x7fff86eac000 - 0x7fff86ecafff libPng.dylib ??? (???) <D0512FBF-911C-A9EC-465D-48A411509D6C> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/ImageIO.framework/Versions/A/Resources/libPng.dylib
0x7fff86ed7000 - 0x7fff86f21ff7 com.apple.Metadata 10.6.3 (507.8) <A850E5A6-69D8-EBC1-B005-43F72B58EA36> /System/Library/Frameworks/CoreServices.framework/Versions/A/Frameworks/Metadata.framework/Versions/A/Metadata
0x7fff86fa9000 - 0x7fff86fbdfff libGL.dylib ??? (???) <A85982AB-6395-DE2B-2023-F735093E663D> /System/Library/Frameworks/OpenGL.framework/Versions/A/Libraries/libGL.dylib
0x7fff86fbe000 - 0x7fff8703cfff com.apple.CoreText 3.1.0 (???) <B740DA1D-EFD0-CCBF-F893-E3004FE58A98> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/CoreText.framework/Versions/A/CoreText
0x7fff8703d000 - 0x7fff870f2fe7 com.apple.ColorSync 4.6.3 (4.6.3) <0522B33D-F78A-9A46-1CB2-9073E4F8EFD8> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/ColorSync.framework/Versions/A/ColorSync
0x7fff870f3000 - 0x7fff8711bfff com.apple.DictionaryServices 1.1.1 (1.1.1) <9FD709FC-23F0-F270-EAC1-C590CD516A36> /System/Library/Frameworks/CoreServices.framework/Versions/A/Frameworks/DictionaryServices.framework/Versions/A/DictionaryServices
0x7fff8711c000 - 0x7fff871cbfff edu.mit.Kerberos 6.5.9 (6.5.9) <42364D54-C647-14DE-2B1C-D94DAA03F092> /System/Library/Frameworks/Kerberos.framework/Versions/A/Kerberos
0x7fff871cc000 - 0x7fff871cfff7 com.apple.securityhi 4.0 (36638) <77F40B57-2D97-7AE5-1331-8945C71DFB57> /System/Library/Frameworks/Carbon.framework/Versions/A/Frameworks/SecurityHI.framework/Versions/A/SecurityHI
0x7fff87245000 - 0x7fff873fffff com.apple.ImageIO.framework 3.0.2 (3.0.1) <911FA1A5-7063-6A19-73D3-95B78A265524> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/ImageIO.framework/Versions/A/ImageIO
0x7fff87400000 - 0x7fff87400ff7 com.apple.Accelerate 1.6 (Accelerate 1.6) <2BB7D669-4B40-6A52-ADBD-DA4DB3BC0B1B> /System/Library/Frameworks/Accelerate.framework/Versions/A/Accelerate
0x7fff87440000 - 0x7fff874acfe7 com.apple.CorePDF 1.1 (1.1) <D47B2366-5D1B-147B-B1FA-C9FE36C4EFFF> /System/Library/PrivateFrameworks/CorePDF.framework/Versions/A/CorePDF
0x7fff874ad000 - 0x7fff874f6ff7 com.apple.securityinterface 4.0.1 (37214) <F8F2D8F4-861F-6694-58F6-3DC55C9DBF50> /System/Library/Frameworks/SecurityInterface.framework/Versions/A/SecurityInterface
0x7fff8750b000 - 0x7fff8754dfef com.apple.CoreMedia 0.484.5 (484.5) <FF8F87CB-7087-A46F-D633-6A93054BDBA2> /System/Library/PrivateFrameworks/CoreMedia.framework/Versions/A/CoreMedia
0x7fff8754e000 - 0x7fff87553ff7 com.apple.CommonPanels 1.2.4 (91) <4D84803B-BD06-D80E-15AE-EFBE43F93605> /System/Library/Frameworks/Carbon.framework/Versions/A/Frameworks/CommonPanels.framework/Versions/A/CommonPanels
0x7fff87f9d000 - 0x7fff87fabff7 libkxld.dylib ??? (???) <E685E658-C908-95B9-8D16-8153C1CE05D7> /usr/lib/system/libkxld.dylib
0x7fff88001000 - 0x7fff88022fff libresolv.9.dylib 40.0.0 (compatibility 1.0.0) <1AE68BBB-6536-125C-DE2A-13CA916D0EC4> /usr/lib/libresolv.9.dylib
0x7fff88023000 - 0x7fff88192ff7 com.apple.QTKit 7.6.6 (1729) <CEDDAEA5-82F9-FF5D-B9AF-C68ACC1E3225> /System/Library/Frameworks/QTKit.framework/Versions/A/QTKit
0x7fff88193000 - 0x7fff8828bff7 libiconv.2.dylib 7.0.0 (compatibility 7.0.0) <7E4ADB5A-CC77-DCFD-3E54-2F35A2C8D95A> /usr/lib/libiconv.2.dylib
0x7fff88459000 - 0x7fff8845efff libGFXShared.dylib ??? (???) <A2C80199-6076-3CBE-E418-E0AD0A3053DE> /System/Library/Frameworks/OpenGL.framework/Versions/A/Libraries/libGFXShared.dylib
0x7fff8845f000 - 0x7fff88490fff libGLImage.dylib ??? (???) <7E8A6ED2-B093-0714-F65A-64ECC41187C4> /System/Library/Frameworks/OpenGL.framework/Versions/A/Libraries/libGLImage.dylib
0x7fff888c0000 - 0x7fff888dbff7 com.apple.openscripting 1.3.1 (???) <FD46A0FE-AC79-3EF7-AB4F-396D376DDE71> /System/Library/Frameworks/Carbon.framework/Versions/A/Frameworks/OpenScripting.framework/Versions/A/OpenScripting
0x7fff88937000 - 0x7fff88999fe7 com.apple.datadetectorscore 2.0 (80.7) <F9D2332D-0890-2ED2-1AC8-F85CB89D8BD4> /System/Library/PrivateFrameworks/DataDetectorsCore.framework/Versions/A/DataDetectorsCore
0x7fff8899a000 - 0x7fff88a17fef libstdc++.6.dylib 7.9.0 (compatibility 7.0.0) <35ECA411-2C08-FD7D-11B1-1B7A04921A5C> /usr/lib/libstdc++.6.dylib
0x7fff88a18000 - 0x7fff88a49fef libTrueTypeScaler.dylib ??? (???) <C15B0761-5136-BD0C-20F7-C8F8A95AF367> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/ATS.framework/Versions/A/Resources/libTrueTypeScaler.dylib
0x7fff88a4a000 - 0x7fff88ae4fff com.apple.ApplicationServices.ATS 4.2 (???) <E31469D3-A97D-63BB-FB00-05ACB2CEC561> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/ATS.framework/Versions/A/ATS
0x7fff88ae5000 - 0x7fff88afaff7 com.apple.LangAnalysis 1.6.6 (1.6.6) <E83DAF4F-F284-BE0B-3D9D-D573023098B4> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/LangAnalysis.framework/Versions/A/LangAnalysis
0x7fff88b77000 - 0x7fff88b9cfe7 com.apple.CoreVideo 1.6.1 (45.4) <B1516554-88BC-CF1E-5409-BFF27A73D1AF> /System/Library/Frameworks/CoreVideo.framework/Versions/A/CoreVideo
0x7fff88b9d000 - 0x7fff88c2cfff com.apple.PDFKit 2.5.1 (2.5.1) <7B8A187A-F0BB-44E7-FBD4-9E1C5F9D5E85> /System/Library/Frameworks/Quartz.framework/Versions/A/Frameworks/PDFKit.framework/Versions/A/PDFKit
0x7fff88c2d000 - 0x7fff88c53fe7 libJPEG.dylib ??? (???) <85902BC7-43AE-E202-0EEE-3C9996D00971> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/ImageIO.framework/Versions/A/Resources/libJPEG.dylib
0x7fff88c54000 - 0x7fff88c6dfff com.apple.CFOpenDirectory 10.6 (10.6) <0F46E102-8B8E-0995-BA85-3D9608F0A30C> /System/Library/Frameworks/OpenDirectory.framework/Versions/A/Frameworks/CFOpenDirectory.framework/Versions/A/CFOpenDirectory
0x7fff88c6e000 - 0x7fff88c8eff7 com.apple.DirectoryService.Framework 3.6 (621.3) <EDCAF7ED-36E1-121F-D294-5CEBC1C34C5A> /System/Library/Frameworks/DirectoryService.framework/Versions/A/DirectoryService
0x7fffffe00000 - 0x7fffffe01fff libSystem.B.dylib ??? (???) <CB9A4929-61AF-DE71-5635-133E9EC95783> /usr/lib/libSystem.B.dylib
Model: MacBookPro3,1, BootROM MBP31.0070.B07, 2 processors, Intel Core 2 Duo, 2.2 GHz, 4 GB, SMC 1.16f11
Graphics: NVIDIA GeForce 8600M GT, GeForce 8600M GT, PCIe, 128 MB
Memory Module: global_name
AirPort: spairport_wireless_card_type_airport_extreme (0x168C, 0x87), Atheros 5416: 2.0.19.10
Bluetooth: Version 2.3.1f4, 2 service, 19 devices, 1 incoming serial ports
Network Service: AirPort, AirPort, en1
PCI Card: pci168c,24, sppci_othernetwork, PCI Slot 5
Serial ATA Device: FUJITSU MHW2160BHPL, 149.05 GB
Parallel ATA Device: HL-DT-ST DVDRW GSA-S10N
USB Device: Bluetooth USB Host Controller, 0x05ac (Apple Inc.), 0x8205, 0x1a100000
USB Device: Built-in iSight, 0x05ac (Apple Inc.), 0x8502, 0xfd400000
USB Device: Apple Internal Keyboard / Trackpad, 0x05ac (Apple Inc.), 0x021a, 0x5d200000
USB Device: IR Receiver, 0x05ac (Apple Inc.), 0x8242, 0x5d100000
Service Manager crash on quit -- seems to be caused by a permissions problem (according to the service manager team), and we know that sometimes the installer has problems assigning the correct permissions.
The Service Manager team is supposed to be working on a way to patch permissions, and a fix to their code.
This seems lame but sorry to say I'm having a problem finding how to address the 'permissions' problem.
Is there a link to a fixit or just plain "here's how it works" site on that?
Thank you.
hi, i changed the permissions with the finder but it didn't work on all the nested files for some reason..i fixed it with batchmod.app which you can find on versiontracker or macupdate (i'll assume i shouldn't post a link). i fixed the user/library/permissions folder and the user/application support folder
Got it running.
Work around:
- uninstall Photoshop CS5 using Uninstaller
- create new user account with admin privs (temp account to install Photoshop)
- log on to new account, install Photoshop CS5
- run Photoshop CS5 to test if there are any issues (none in my case)
- log off temp account, log on to original account, delete new user account
- test, done.
I tried the Uninstall/Install Temp Account User method, but it did not work for me. CS5 Photoshop still crashes/hangs on quit. Any other suggestions?
Thank you,
-Doren
No more suggestions right now. Folder permissions is the one cause we know about.
I'm still looking at all the crash reports for more clues.
I've managed to reproduce one other crash on quit myself - but it's one that very few people have reported.
But we've got several people looking into these issues.
I am getting this also
macpro 2x2.8 quad core 14gb memory osx10.6.3
Last Adobe employee note here was written on May 4. This is May 10 and seems to be very little to help those of us who have bought this upgrade. Where do we file for a refund?
it looks like adding myself to the sharing/permission and giving read/write permission for
fixed the problem
Like everyone else on here, I'm getting the same error and crashes with PS CS5 on Mac Pro with 32Gig of RAM. Please send us a fix ASAP. As of right now it is useless software we have paid for.
Please read the existing answers before posting.
You didn't even tell us WHICH error or crash you're seeing.
I've read every answer before responding. Why the hostile response?
PS CS5 says my Nvidia GTX 285 card doesn't meet minimum standard and
will not do Open GL/CL, yet It is listed as meeting standards on the
Adobe requirements.
It says it cannot save my preferences and Open GL is grated out. It
then crashes and says it can't save my preferences. I'm just trying
to get my $2500 investment in CS5 Master Collection to work.
I appreciate any help you can provide but don't be hostile to those
seeking solutions.
Dave
Adobe requirements.
seeking solutions.
Dave
don't take it personally videobuddy, this release has had alot of issues, some trade offs, and one brilliantly stupid installation flaw which is kind of embarrassing and has made alot of people rather angry. by all accounts chris is a good guy just trying to gather all the data he can to get this fixed, but i imagine things are a bit fraught in the bunker right now!
I believe here are a whole lot of permissions problems occuring here, and I agree with others that this is not acceptable for software product like this.
In any case I have solved the permission problem of CS5 not being able to save your preferences on exit. You need to add read/write permissions to
/users/<your username>/library/preferences/adobe.
To change permissions of a folder, right-click on that folder, select Get Info, then click the lock on the bottom, enter your password.
Then select a + to add yourself with read/write permissions if you don't have them.
Unfortunatly I believe there are other permission problems at play here as well, that also need to be fixed.
You should NOT have to add yourself to any permissions in the ~/library folder. This is a system folder.
/Library is a system folder
~/Library is inside your user directory, as indicated by the ~ character (which resolves to your user's home directory).
