This discussion is archived
JCKirkpatrick
ACR 6.1 (Mac) Update fails
May 18, 2010 6:29 PM
When I try to install the ACR 6.1 using the Adobe Patch tool supplied in the disk image, the install fails with this message:
Adobe Application Manager
Some updates failed to install.
The following updates were unable to install. If you wish to install these updates, please fix the problems below and retry:
Photoshop Camera Raw 6.1 Update
Installation failed
Contact Customer Support for further assistance.
There appears to be no way to determine why the install failed unless there are log files somewhere. Contacting Customer Support results in another download of Adobe Support Advisor. Running it produces this somewhat confusing message:
Found issues generated after 05/11/2010 00:00:00:
The module found no issues to report for the selected log file. If you continue to have difficulties with the application, please contact Adobe Support.
After reading other install issues, I have tried the install after a reboot with same results.
iMac 9,1
8Gb ram
OSX 10.6.3
Jim Kirkpatrick
    May 20, 2010 3:02 PM   in reply to JCKirkpatrick
    I have exactly the same problem with trying to install ACR 6.1 on an iMac under OSX 10.6.3.
    So I rebooted and tried again - no go.
    Uninstalled CS5 and also used the Adobe clean script at http://www.adobe.com/support/contact/cs5clean.html .
    Reinstalled CS5.
    Tried again - get the same error:
    Installation failed
    Any advice appreciated. Or maybe I just wait for the final release.
    Jun 4, 2010 9:41 AM   in reply to JCKirkpatrick
    The error log seems to point to ERROR: 1 Unable to get permissions of "/Applications/Adobe/AdobePatchFiles"
    I checked my Application folder and I had an old text file called "Adobe"
    I deleted and create a new empty folder "Adobe"
    I tried the updater again and at this point it was able to use this new folder
    and complete the update both for ACR 6.1 and Bridge 4.0.2
    Yohoo!
    Done!
    Mic
    Jun 4, 2010 3:58 PM   in reply to wwpny
    Thank you!
    That solution worked for me as well.
    .. Neil
    Jun 9, 2010 4:40 AM   in reply to JCKirkpatrick
    That fix worked for me too, thanks very much for posting. The offending 'Adobe' file in the Applications folder dated back to 2005! Adobe should add this to their knowledgebase, I spent a long time going round in circles with that before looking here.
    Michael
    Jun 18, 2010 3:42 AM   in reply to mwwc
    Same for me, problem solved aad thanks for posting!
    Still wondering however why Adobe has chosen to create a folder called 'Adobe' inside the Applications folder, that doesn't contain any application, but only files that an average user shouldn't ever touch. This folder should reside in some library folder, not in the Application folder. Bad, bad installer.
    Also wondering why Adobe is still remaining silent on this issue. Would be nice if they al least just would acknowledge it.
    Goos
    Jun 27, 2010 7:56 PM   in reply to JCKirkpatrick
    First of all, thanks for the info.  The fix described fixed my problem also.
    The sad thing is I spent about an hour trying 2 different knowledgebase fixes that did not work.  I am not sure why Adobe could not put this fix in their knowledgebase so that the customers did not have to eat up hours trying bogus fixes.
    Aug 31, 2010 5:54 PM   in reply to wwpny
    Same exact problem with update to 6.2 ACR
    "Photoshop Camera Raw 6.2 Update   Installation failed"
    Follow Mic's directions and delete the file /Applications/Adobe, then rerun the update.
