Does anyone know how to set up the ADDT form validation so that a person will have to enter a date greater than {NOW} but less than 14 days from now? I tried searching here but the search on this site stinks. And, I found some "similar" things on the interakt site but nothing worked for me. I am using PHP and my database format is YYYY-MM-DD. Any help is greatly appreciated!
Thank you
John
So I been messing a little with your idea in ADDT, and while I don't have a complete solution there is a way if your good with regular expression and PHP.
Here is a basic form validation that ADDT offers (code view) using regex.
The field name is regDate which is then using a regular expression to make sure the dates fall between 1-1-1900 - 31-12-2099.
Given this doesnt work with your NOW to 14days future date but this is just an idea/example.
// Start trigger
$formValidation = new tNG_FormValidation();
$formValidation->addField("regDate", true, "regexp", "(^((((0[1-9])|([1-2][0-9])|(3[0-1]))|([1-9]))\-(((0[1-9])|(1[0-2]))| ([1-9]))\- (([0-9]{2})|(((19)|([2]([0]{1})))([0-9]{2}))))$)", "", "", "");
$tNGs->prepareValidation($formValidation);
// End trigger
Now if we took this concept and created a script that would read todays date then calculated the 14days+ then writes a variable that contained the regular expression for just those 14days. Then you can add something like this...
//My Regular Expression Variable created from script.
$myregexvalue = '(\b10\-\b10-\b2009\)|(\b10\-\b24\-\b2009\)'
// Start trigger
$formValidation->addField("regDate", true, "regexp", $myregexvalue, "", "", "");
// End trigger
The key would obviously be to create a script that would find the dates needed then created a tight regex for those specific dates.
Well that's my 2 cents on the matter.
Happy Coding, if you come up with a solution I would love to hear about it.
