Today, all of a sudden, two of my most used functions—holding down the space bar to move the image around and holding down CMD-space bar to zoom—just up and quit on me (I do like the "Scrubby" but it took a little getting used to. It's very touch screen-esque).
I did all of the normal trouble shooting such as deleting the prefs, relaunching, restarting, etc. Nothing. The functions work fine in the other CS5 programs.
Anybody else come across this? I checked through all of the prefs thinking that perhaps I accidentally changed something but I couldn't find anything. If all else fails, I'll do an uninstall/reinstall but only as a last resort.
I did notice that Adobe finally fixed the Distort (in Full Screen Mode) bug that was killing me in CS4.
Thanks for any help.
Well, 5 minutes ago, both functions started working again out of the blue. I have no idea why and I did not change any prefs. I have been switching between PS, Flash, and Illustrator. When I started this morning, they were working in Flash and Illustrator but not PS. After several hours, boom!, they are working in PS. Obviously, there is a bug somewhere. But now I can not use Acrobat 9 Pro because it says that I need to activate the Suite, which I have done. I am probably going to have to call Adobe on this one.
Are there other variables involved? My Space Bar Hand is working again (though I expect it to go any minute) and so I tried your thought but I could not replicate the problem. For me, it is either some other issue, or something other variable along with opening from Bridge.
In PS CS4, my Distort transform would always go wonky on me when I was in Full Screen mode. I would have to switch out of Full Screen and back in and then Distort would work again, usually for only 1 or 2 images. If I were working on, say 12 images, I would have to repeat this process 3-5 times. I figure that there has to be something like this that is affecting the Space Bar Hand. I was really hoping that your Bridge bug was the answer.
BTW, it should be noted that I am running CS5 Design Premium on Snow Leopard while drinking a Bud Light. Perhaps the issue lies with the OS or the beverage of choice.
We're trying to track this down. Next time it happens to you, please do the following to help us debug:
1. Take a screen shot of your entire Photoshop workspace (so we can see what panels are showing when this happens)
2. Take a screen shot of Activity Monitor (so we can see every other program and process that is running) (Applications>Utilities>Activity Monitor)
3. Then quit each other application that is running one by one and check see if the problem goes away after quitting each app
4. If you quit all other applications and it still occurs, try resetting your workspace WIndow>Workspace>Essentials and then select Window>Workspace>Reset Essentials
Thanks.
I just started using CS5 today and ran into the same issue. Every CS5 program I have open is all of a sudden disabled in terms of being able to use the space bar / cmd / option keys to get the hand tool, and magnification tool.
It happened in Photoshop and Illustrator simultaneously.
I have gone through this thread and disabled spotlight shortcuts and other keyboard modifiers used by os x by default and it is still broken. I restarted both Photoshop and Illustrator and it still does not work.
I am going to attempt re-booting my machine but if this is going to be the norm it is going to seriously impact my workflow since those are keyboard commands I use all the time.
Thanks DrunkCyclist. Be sure to try my debugging steps above ( http://forums.adobe.com/message/2846310#2846310 ) to see if there is another process that is conflicting.
I've had the same problem and i can confirm that quitting the webbrowser brings back the hand-tool in Photoshop. Adobe - I hope this information helps you to fix this bug quick. I also hope for an Photoshop-Update that fixes the "slow scrolling" problem (off topic).
Apart from that Photoshop CS5 seems to run smoother and faster on my MacBook Pro than CS4 did, seems you guys did a good job! =)
Matthias,
It helps. We haven't reproduced the problem in house for the Hand/Spacebar issue but we have some good clues.
Which Web Browser do you use? Do you remember what content/URLs were active/visible? What version of Flash Player do you have?
Slow scrolling - Yes, we're aware of the issue. I was looking at a fix for it yesterday. Which mouse (brand/model) do you use?
Jeffrey -
I use Firefox 3.6.3. I don't remember all the websites that were visible, but I think I had www.spiegel.de as a tab open and in another tab i was logged into an account of http://basecamphq.com/. is it possible, that there is a conflict, when a javascript/JQuery/lightbox on a website responds to keyboard-commands?
my flash player is version 10,1,52,15
and the scrolling problem appears with this new "apple magic mouse" as well as with the old "mighty mouse" (wired version)
Hi guys,
I've just had the same problem in InDesign CS4 - you don't realise how much you use this command until it stops working!! First time it's happened to me since installing the CS4 suite some 3 months ago.
Anyway, having read the thread, I did what Jeffrey Tranberry suggested and quit my web browser, which fixed the problem straight away (was running Firefox 3.6.3 if that's of any help).
Cheers
I don't believe it but I think that I finally found the culprit: hulu (the desktop app, not through a browser).
To make sure, I rebooted, launched PS, Flash, and InDesign, and then fired up every app that I could think of, one by one, testing each time, leaving hulu for last. Sure enough, it was not until I got to hulu that the space bar hand/zpom stopped working. And then I went one by one, quitting each app, testing each time, again leaving hulu till the last. Sure enough again, the space bar continued not working until I quit hulu, the very last app that I had running (aside from CS5 and system processes).
Please, please do not tell me that there is a conflict between CS5 and hulu's utilization of Flash! That would just make Mad Dog Jobs' a happy camper. (I am a big supporter of Flash on the iPad).
What a relief. Except how am I now going to watch my TV shows while working???
In regards to browser conflicts, I have had none with Safari, Firefox, or Chrome.
Adobe, I hope that this information helps. Let me know if you need any info screen capped.
I haven't got Hulu loaded on my Mac, so that's definitely not the culprit in my case.
Either way, it's damn annoying. Hasn't happened again to me since relaunching Firefox however, and, as I said in my earlier message, it had never happened before - and I use Firefox on a daily basis at work... so it may have actually just been a coincidence that it started working again then.
I'll follow this thread with interest...
When it started happening for me, it was very, VERY random but I can't remember if I was launching and quitting hulu. Honestly, I expect this to be a fluke. Sure... today it is linked to hulu but tomorrow may not be the case. I'll just have to keep an eye on it. And I agree that it is very frustrating. Those are two huge functions for me and having to hit the "H" or "Z" key to perform the function, and then hit the key to toggle back to the previous tool is extremely disruptive.
Flash Player 10,1,52,15
Firefox 3.6.3
Just to keep you up to date, as long as I don't have Hulu Desktop running (0.9.8.2), all is well with CS5. As soon as I fire it up, the space bar hand/zoom goes away.
rudy pospisil / ny, ny
http://rudypospisil.com/
http://anothernormal.com/
For me its not HULU - I don't have it installed.
For me, Since I quite Dreamweaver and discovered that solved the problem. I have had PS and DW open at the same time and was working with it last night, Space Bar Hand worked perfectly.
I put the Mac to sleep last night, woke this morning. Woke it up and PS hand space not working anymore. Saw this update about Firefox (3.6.3), so I quite Firefox to test that and didn't make a difference, I closed Dreamweaver and it works fine again.
Thought Im on to something here - restart Dreamweaver though it still works.
At this point, i suspect it's related to Flash (as others have pointed out). Hulu desktop is an AIR app running the flash player. Dreamweaver probably runs some form of flash when loaded, triggering the same bug. Using the Hulu desktop gives us a reproducible case, so we can have a developer look at it and figure out what's going on. Thanks.
yep it's definitely a Firefox thing. My spacebar wasn't working in ID CS5 all of a sudden. Closed Firefox (without even restarting ID) and it's working again fine. I'll let everyone know when it' stops working and will take a screenshot of the Firefox windows open. I'm in Firefox v 3.6.3 and OS X v 10.6.3
This happened to me again today in Photoshop, (only the 2nd time its happened to me). I had Flash and Photoshop open at the same time, but no Firefox or any other apps at the time it happened.
Not only did the spacebar tool stop working, after clicking around a few times in Photoshop, the program just froze up and I had to force-quit and restart Photoshop, at which time the keyboard commands came back.
Don't know if it is the same issue, but I was locked out of the keyboard commands before Photoshop finally choked completely.
