Dive into Adobe Summit 2024! Explore curated list of AEM sessions & labs, register, connect with experts, ask questions, engage, and share insights. Don't miss the excitement.
SOLVED
Workspace URL without port number?
Avatar
Former Community Member
Hello,
Is there a way to config the Workspace URL to not use the port number for LCES with Webpshere 6.1 environment (e.g." http://localhost:/workspace/" instead of "http://localhost:9080/workspace/") due to the firewall configuration?
Han Dao
1 Accepted Solution
Avatar
Correct answer by
Level 7
1) Change the WC_defaulthost port of the appserver instance from 9080 to 80
2) Make sure "80" is listed as a "Host alias" for the "default_host" virtual host or another virtual host you have created exclusively for LiveCycle
3) Re-start the appserver instance
4) Check the SystemOut.log and verify that all LiveCycle web modules now bind to port 80, among others (like 5060, 5061 etc).
5) Try http://localhost/workspace and it should work.
Avatar
Correct answer by
Level 7
Avatar
Thanks Jayan, you are always helpful. It works PERFECT!
Thanks again,
Han Dao
Avatar
Hi Jayan,
Can your instruction above work for the wc_defaulthost_secure that has SSL e.g. https://localhost/workspace ? I tried but it does not work without the port. Can you please advise.
Han Dao
Avatar
Many THANKS to you, Yayan. It WORKS great!
Thanks again,
Han Dao
Avatar
Level 4
Hi Jagan,
how can we have a different URL path cofigured for workspace running on Webshpere.
For example,
http://hostname/ashok instead of http://hostname/workspace.
Avatar
To change the URL, I think you will need to change your Application Name (the ear file that you deployed with ashok name) in WebSphere Admin console.
