Jun 10, 2010 12:42 AM
LR3 Not releasing memory
Like (0)
Hi all,
I am running the LR3 64 bits test version under windows Vista64. I have a problem with the RAM memory allocation. When I start working, mainly checking the new imported photos in the library module and marking some as rejected, the allocated memory is 2GB. As I work the allocated memory raises constantly in a straight line until the 8GB available are used. Then I need to restart LR because it is impossible to work. When I restart the program the allocated memory drops back inmmediately to 2GB again and the same issue starts over. Has anybody seen a similar behaviour?
BR
Angel
I just did a test and I see the same behavior. Memory usage increases with each new image that is accessed, and the memory is not released. I will have to do more extensive testing later, when I have time. Win 7, 64-bit, i-7, 8gb ram, 90k image library.
Same here. Don't think LR3 should have been released. Poor QA control.
Same over here.
Win7 Ultimate 64 Bit
8 GB Ram
When i access a folder with DNGs (converted from Nikon D3 RAW Files), i can pick/reject 40 - 44 photos (reproduceable) and then from one photo to the next everything (thumbnails and imagearea) is grey and i need to restart Lightroom. This never happened in Beta 2.
PLEASE ADOBE.. fix this fast
Not since I optimized my catalog (before that I did).
Rob
Rob
Hey! That works! Memory usage is in the normal and expected range after optimizing the catalog. Who'd of thunk it. Crisis averted. Let's move on.
Thanks, Rob.
Michael,
I shared that tidbit a bit when the beta's were leaking - some people it fixes the problem, some not so lucky...
Glad it worked for you
Rob
I consistently saw this behaviour during beta, and sometimes when LR was closed (for reasons given) the UI would completely disappear but Windows task manager would still show LR under "processes" (not "Applications") for up to a minute or more before the memory is released.
At first I thought LR may be "loosely" holding onto the memory with a willingness to let it go to other applications if needed, however I found it ground the whole system to a halt.
Disappointed this is still occurring in the released version.
Windows 7 (64) / Core i7 / 8GB Ram.
What's your screen resolution?
There we reports about memory usage with large 30" displays. http://forums.adobe.com/message/2880270#2880270
Thanks for the quick answers! I will try to optimize tonight and see if there is any change.
I am using a 24" and a 22" displays.
BR
Angel
I am seeing LR quickly jump up to 1,200,000 K of memory usage and holds there between that and 1,700,000. Definately a memory hog. My catalog is set to optimize after every close. Still LR uses TOO much memory.
System:
Win 7 64 Pro
8 GB Ram
i5 processor
8600 gts video
2x-24" lcd's
You must have never worked with SQL Server, then.
Many programs that
use a db (and that's all your catalog is, a db file, using SQLLite) grab
as much memory as they can, to keep db operations in memory, for speed
reasons.
Also, LR likes to read the whole image file into memory to process it - the larger images your camera takes, the more memory LR will grab. LR will reuse memory, though.
Actually I have worked extensively with SQL, but more from the developer side and less on admin. Didn't even think about their database being SQL based. What you said really makes sense now.
Well, I have tried it again after optimzing the catallog and there is basically no difference. It is still eating up all the memory I need to restart it constantly. Does anybody have any other suggestions?
I have the same experience. It becomes slower and slower when I edit images. After editing some images even the smallest change in eg. brightness is stuttering. After restart of LR it is responding very quick again.
Memory is used up to 100% and cpu is very often up to 100%.
I have a Q6600 ,4GB mem and GTX 275 card.
- Terje
If you try optimizing your catalog, can you save off a copy of your .lrcat
file BEFORE you optimize, and if it works send me the original catalog?
(compress up the original and send it to me at mgaul at adobe dot com
through either email or a file transfer service like YouSendIt.)
-melissa
I have been having the same problem...posted about it last night in a thread discussing "Why LR3 is so slow?". I have a Dell Precision 690, dual Xeon Quad Cores 8gb RAM and am running Win7 64x..or is it x64? My image catalog is 190,000 and growing.
I never saw my memory usage jump above 40%. Last night I noticed the RAM use was up to 87%. CPU use had never topped 40%, last night it was hitting high 60%. I backup and optimize catalog every night when I shut down. I too found that exiting LR3 solved the memory bog, and watched as each new file opened/edited pushed the RAM usage cumulatively higher.
I have to correct a bit here. I had another login on my computer running a program causing the memory to be used at 100%, almost not using cpu. After stopping that and restarting my computer I am still using 2.5 up to 3.6 GB memory ( got 4GB) when using LR. Cpu is the same (up to 100%) and it is stuttering after a while.
But memory is not up to 100% as I said. I will not make this sound worse than it is ![]()
- Terje
deleted.
sent as email to you.
Hi all,
One update. I have deleted all the previews and regenerated them with LR3. Now it seems to be working correctly.
BR
Angel
I've had this problme too.
Window 7 64 bit, 4gb ram.
I tried rebuilding all the preivews, optimising the catalogue and checking it for error, and some combination of that seems to have worked for now...
I have deleted all the preview files and rendered about 10,000 images of my catalog with ne 1:1 previews.
I still have the problem with the memory.
How much physical memory do you really have? What does Help -> System Info... report when you think Lr is using a lot of memory? What modules (Library, Develop, Web &c.) have you enabled/clicked on when this happens?
Same Problem with Vista64 and 6 GB ram. After a few minutes working, all Ram is used and I have to restart Lightroom. No Fun. The Database is optimized and all Previews are created with LR 3.
Copyright © 2011 Adobe Systems Incorporated. All rights reserved.
Use of this website signifies your agreement to the Terms of Use and Online Privacy Policy (updated 07-14-2009).
