Hi we recently updated Reader9.3.1 to Reader9.3.2
(Reader9.3.1 worked just fine)
This new issue pops up saying
"(Security block) Acrobat does not allow connection to:
http://www.webpage.gov/link/filename.pdf " <------------as an example, not a real address
The way we got to 9.3.2:
We used the working Reader9.3.1 and slipstreamed that with the new UpdateFile9.3.2.msp
running command: msixec /a reader9.3.1.msi /p UpdateFile9.3.2.msp
bob
Got the same issue here. We deploy via group policy using the customisation wizard to a few thousand desktops, so configuring by individual client obviously isn't an option. I'm not seeing how to configure the internet access options in the customisation wizard, only the trusted source options. Anyone know how to define a list of target URLs, (preferably wildcarded domains) that reader will allow users to click links to using the wizard?
Any registry setting can be configured via the Wizard or GPO. To figure out how to configure the registry for what you want (or almost anything else), download AIM.
Here's the standard blurb:
There are new and updated resources that might help. A new Enterprise resource portal exists at http://kb2.adobe.com/cps/837/cpsid_83709.html . From there you can find the main enterprise libraries and tools. It links to an Enterprise Admin Guide (in its nascent stages but it's rapidly evolving) and the Administrator's Information Manager (AIM). AIM is an AIR application that contains several documents as well as a Preference Reference which documents a growing list of registry keys.
Ben
Perhaps not quite as simple as one might hope. The documentation gives the path for iUnknownURLPerms and tHostPerms as HKCU\Software\Adobe\(product name)\(version)\TrustManager, whereas (finding that didn't work and looking on a non-managed machine) the actual path is HKCU\Software\Adobe\(product name)\(version)\TrustManager\cDefaultLaunchURLPerms.
The bit I can't get at the moment, and doesn't seem to be covered by the docs, is how to set a wild card, i.e. to allow access to all URLs in example.com. Just adding something like *example.com doesn't seem to work. Any ideas?
Phil
Hi Phil,
You're right. The doc is both incomplete and incorrect. It will be fixed in a few days. Here is some additional information:
Also note that while you can use * for Enhanced Security > Privileged locations, that is only for cross domain access and won't help you with simple URL access.
Ben
Phil,
This took care of it for me: http://forums.adobe.com/message/2785579 and http://forums.adobe.com/thread/617561?tstart=0
Greg
I found a second issue preventing the web page to load:
After I did changed my Trust Manager Settings, the problem persisted.
I opened to PDF in Adobe LifeCycle Designer and noticed that the URLs were mal formed. Any link that I created as http://www.backofficethinking.com. was converted to http:www.backofficethinking.com (the // were removed). I added them back, opened the file in acrobat pro and clicked on the Extend features link which made the form fillable and the // were removed again. I then went back to Designer and changed the link to www.backofficethinking.com (no http://) , opened the file in acrobat pro and the links were correct.
I assume this is a bug in acobat pro?
I'm using adobe acobat pro 9.2
I fixed this "Security Block" issue. Sort of.
In registry editor: Current user\software\adobe\acrobatreader\"version"\Trustmanager\cdefaultlaun chURLperms, The name is thostperms. I deleted it and closed regeditor. Then went to the pdf and tried the link again. In perferences, under trust manager, It's now not greyed out but no matter which option I choose it always asks the first time I click a new link.
