Hi
I just upgraded from lightroom 2.7 to lightroom 3. I then proceeded to import my old catalog. this all went fine but lightroom is so slow, the thumbnail previews take forever to load if I manage to have the patience to wait for them.
is there a quick solution?? How can it be sped up?
thanks
Laurence
Message title was edited by: Brett N
It is slow loading thumbnails in the grid view of the library.
I am running windows 7 home premium on an ASUS N61Vn with intel core 2 duo 2.53GHz, 4GB of ram and an nvidia geforce gt 220m 1GB graphics card.
there are 16661 images in my catalog.mainly JPEGs.
I open the program and see grey boxes ( some other colours where they have had a label in Lr 2.7) where the images should be in the grid view, I click one and a bunch appear, but when I go to click on some more blanks, the program does nothing but show me the images number in the catalog. This does change for a long time.
I attached an image so you can see what it looks like. (use a 16in monitor and a 14in)
Hope this helps.
Okay, try this. Open the application and just wait for all the thumbs to load and all hard drive activity to stop. This could take a while in some cases (minutes). Once that happens, exit the application and re-load it. My guess is that it will be spectacularly faster on the second attempt.
If so, close all your folders using alt-click which will close the folder and all of its subfolders. Select a source that doesn't have any images and exit. Reboot and relaunch. Once the app is open, try selecting a source with some images and let me know what happens.
kobajaszi777 wrote:
speed test:
winxp 3,25gb L2.7 raw --> jpg 85% 100 photos =time 5,30 min
win7 x64 8gb L3.0 raw --> jpg 85% 100 photos = 6,16 min
hardware is the same phenom x4 9750 (100 the same photos)
why slower... !!??
That's rendering. Completely separate issue. The new, improved rendering algorithms also require more processing cycles to complete. It's the price you pay for improved image quality.
Wow....my RAM useage has gone through the roof w/ LR3. I
just checked my CPU meter and I was at 79% constant RAM use, with
peaks in the mid 80s. Never saw that number over 40%
before. I have 8gb now, looks like it is time for more!
I exited LR3 and then reopened and the RAM use is down at 37%. It will be interesting to see how and when it starts peaking.
Ok, so I exaggerate a little. it's actually 2Gb.
nothing wrong with a little dramatic license...
http://www.adobe.com/products/photoshoplightroom/systemreqs/
But still twice the PS5 requirements. That makes it a proper gas guzzler in my book.
OTOH, wassa point of having 8gigs if you never use it?
You can't get away with squat on this forum - gotta check your exagerrations before hittin' the "Submit" button
I would guess Lightroom would "never" use more than about 1.5GB of RAM, when its functioning correctly, and if it ever tops 2GB - you got a leak... Somebody correct me if I'm full of hooey...
The other Gigs are for keeping another dozen programs open... Not too many programs even know how take advantage of massive quantities of ram when they're available - or at least that's been my experience so far.
Rob
You're probably right. Still, if you're running a 40k+ image library and are possessed with the need to simultaneously run two multi-tabbed browsers (who, me?) you'll quickly run into problems.
I've noticed this over the course of three versions of LR and two new computers: the best upgrade you can hope for is a memory upgrade.
Seriously, I traded up my hardware in anticipation of LR3's reported performance hikes.
I would think if any of the programs your'e running are ram starved, then more ram helps, but if all of your programs have as much as they can possibly use, then more ram would not help.
But yeah, programs are getting hungrier and hungrier (couldn't find a "hungry" emoticon).
PS - Sometimes people mistake memory leakage for memory hunger.
Enjoy Lightroom,
Rob
Keep in mind that if you're using a 32-bit Windows OS including Windows 7, the OS can only use about 3 GB or maybe 3.5 GB of RAM, no matter how much you load onto the PC. So if LR3 is slow on your system with 2 GB of RAM,and that wouldn't be a huge surprise especially if you have a large catalog and a 2+ year old PC, it may not be much better even if you upgrade your RAM to 8 GB, unless you also do a reformat and reinstall to a 64-bit Windows OS. Doing that may cause other issues with other software. For example, I also use Adobe Audition, and comments on the Adobe support forum for those who have tried Audition with 64-bit Win7 seem divided between those who run it fine and those who can't run it well at all. Your hardware drivers also may or may not support 64-bit Windows.A 64-bit OS is great with hardware and software that can run it, likely including LR3 and PS CS5, but YMMV with your other apps and your gear.
bob frost wrote:
I've seen LR use over 5GB of my 12GB of ram, but I'd like to see it use more.
Be careful what you wish for
(consider you may have a memory leak).
Mac or Win?
PS - I'm pretty sure on Win7/64 if I added more memory Lightroom wouldn't use a bit of it - there's free memory right now that it doesn't use. I mean it "used" it when I had a memory leak, but ever since I optimized my catalog it doesn't use it. Well, occasionally it "uses" it, but its generally a precursor to a slow down followed by a crash...
Rob
clvrmnky wrote:
It probably depends on your platform. If a single app asks for 8Gb of memory on my Mac, it will get it, either as real or virtual memory.
Yeah, I was going to post sthg like that but didn't want to sound like a mac fanboy ![]()
however..
..a lot of these slow performance reports seem to originate from win7 x64 users, very well-specced systems at that. I'm tempted to point a shaky finger at things like openGL optimisation / hardware integration, rather than outright RAM & processor muscle, as the source of the difference, and GPU rather than CPU performance in general. Mel's post above is the sort of thing I'm on about.
Any thoughts? Have macs still got the edge for graphics/rendering work or not?
For mac users, it's maybe of interest to note the next mac OS release will address 3rd party app openGL issues as a priority item: http://www.appleinsider.com/articles/10/05/06/mac_os_x_10_6_4_to_tackl e_issues_with_opengl_iphoto_dvd_player.html
Hi!
My images are taking 10 seconds to load going from one image to the next in Develop mode. I'm using LR3 with the existing reviews from Beta2, which was much faster. Macbook Pro 2.16 GHz 2GB 667MHz, running OSX 5.8.
Should I delete the preview cache and Re-render, or is my computer just too slow for LR3?
Cheers!
I haven't loaded LR3 onto my macbook (same spec as yours) yet but if LR2 was anything to go by, and you're talking about 1:1 rendering in Develop, 10 seconds probably is a bit slow but not horrendously so.
I'm still not sure what aspect of the i5 iMac makes it so much quicker (quad-core/4Gb notwithstanding) but it is... consensus here seems to be that more RAM helps, but it's not the end of the story. Are you running it in 64-bit mode? I believe RAM needs to be a little beefier than 2gigs to make the most of 64bit, but it might help.
I do remember getting better macbook performance with LR on its own, ie quitting other stuff (esp browsers) that can be RAM-hungry.
IME delete the preview cache and it will take a looong time to rebuild a decent sized catalog for no discernible improvement.
You could try optimising the catalog (in the file menu) - takes less time, no harm in trying.
Brian Noppe wrote:
Hi!
Cheers!
Switching from one (non-cached) Nikon D700 NEF image to another takes about 3 seconds on my MacPro:
Model Identifier: MacPro1,1
Processor Name: Dual-Core Intel Xeon
Processor Speed: 2.66 GHz
Number Of Processors: 2
Total Number Of Cores: 4
L2 Cache (per processor): 4 MB
Memory: 5 GB
Bus Speed: 1.33 GHz
Switching from one (non-cached) Nikon D300 NEF (same size images as the D700) image to another takes about 5 seconds on my MacBook Pro:
All I can say is.. I am not having any issues at all with the new release. I am using WIN7 64 and I can use iTunes, DxO AND Lightroom3 all at the same time without any problems. All the features work as advertised and I am one happy Windows7 camper.
Has anyone considered that an AntiVirus program might be the cause? I use Microsoft Security Essentials.
... my two cents, thanks.
EDIT: I don't know why my system doesn't show up on my posts, but here it is:
Win7 64-bit; HP Pavilion Elite Intel Core 2 Quad Q8200, 8gig RAM, Radeon HD4350; Lightroom 3; EOS 7D
I have also been experiencing slow processing with Lightroom 3.0 compared to Lightroom 2.7.
Here is a comparative table of observation in memory process usage:
Description LR 2.7 LR 3.0 Remarks
Start-up
No processing
Browsing only 300-320 MB 300 -320 MB Basically the same
Develop Export
to Jpeg Quality
100 450-570 MB 1.74 to 1.94 GB LR 3.0 uses double the memory compared to LR 2.7
Time to process
same 7 RAW files
of an EOS 40D 30.42 seconds 1 minute & 3.13 seconds LR 3.0 almost takes double the time to process same files in the same machine
(using a digital stopwatch)
At Rest-Idle no
processing
being done 448-532 MB 1.786 - 1.85 GB LR 3.0 uses more than double the memory even in idle or rest.
Both versions are in the same Mac, so I think the configuration should not matter but I wrote it anyway. In fact, my LR 2.7 has 4,182 images on the catalog that I tested and the LR 3.0 only has 691 images on its catalog. I noticed LR 3's sluggishness when I was processing the images so I measured the processing time using a digital stopwatch in order to mathematically express the slow processing that I have observed. Both versions and catalogs were optimized and have the same preferences.
iMac 2.4 GHz Duo Core 4GB (667 MHz)
I hope an Adobe Engineer would read this. Your prompt response and solution is needed and greatly appreciated.
Actually, there is at https://bugs.adobe.com/
.. but the LR team obviously does not participate.
I've found LR3 to be brutally slow at pretty much everything. I'm running WinXP with some pretty decent hardware. I upgraded from LR1.4. I thought LR1.4 was pretty snappy but find LR3 to be a major step backward in speed. Manipulating sliders (like Recovery, for example) is painfully awkward and slow, with major lag. Tools like red eye reduction and brushes are even worse. This is slowing down my workflow tremendously. I love LR, but what is going on here?!? I'm sure hoping this is a bug that can be fixed and not a permanent issue.
Same here. I am a big fan of LR, but this version is enormous slow in almost anything. Just experienced a crash because of trying to change too often to another pic while it was rendering (?). ANd thaat of pic straight out of the camera with basic processing. No local adjustments, no graduated filters. Pics look great, but the time involved isn't really billable anymore.
I am on Win XP32, prof, 3 Gb, extended physical address, Xeon 3Ghz.
I would like to know if it is just windows users or are Mac users also experiencing these slowdowns?
OK!
I was dismayed... I love Lightroom; it is the most valuable part of my image workflow. Lightroom 3 was giving me the dreaded mac beachballs of death, external hard drives mysteriously being "not properly ejected", crazy load times, slow sliders, etc. etc.
Much better now!
I "exported as catalog" the images that I was working on (about 700 flagged images). Closed Lightroom. Trashed all plists (LR2. LR3Beta2, LR3).
Created a new Catalog. Imported from the catalog of images I had been working on to the new working catalog.
Voila! LR3 is not instantaneous, but definitely workable....and I've not had to restart so far.
Thanks, Victoria Bampton (especially) and others that got me to my present much happier place. :-D (and yeah, I'm knocking on wood)
Have you other folks experiencing problems done these steps?
Cheers!
Brian
So at this point I will wait to upgrade until we know what % of Win7-64 bit users (my OS) experience these very slow processes. I, too, built a way bigger system to work on images in PS and LR. Well - the old one was way out of date, so the new build was overdue but I was looking forward to a satisfied grin at blazing speed on this app.
The memory comments are interesting: most of you don't think that memory past 4-6 GIG will do anything for LR directly. In PS it has always been described as beneficial. I have 6GIG and was wondering about going to 12.
System:
i7 920 not yet overclocked
6GIG RAM
Gigabyte motherboard with a couple of large-capacity internal SATA 6 Barracuda XT hard drives
GTS250 video card 1GIG video RAM
I use two monitors. I saw a comment in another thread that speculated that people using two monitors were seeing more slowdowns than those using one.
jonathan7007
Rob,
Wouldn't Photoshop be happier with the higher RAM count? I will start shooting with a Canon full-frame camera now and it has a 21MP sensor - larger raw files, etc. When I last looked it was 170$ to go the extra 6GIG so I am considering it. (My system has banks of three ram slots so jumps by 3's -- 9GIG offers little benefit for about the same $$ and causes a mis-matched sets of ram modules... usually a bad idea.)
There's always something to spend on...
thanks for the idea on the trial. Good idea, too.
jonathan7007
