Hi guys,
I have AE CS5 and installed the whole thing in German (because I am German^^) but now I realize that for tutorials and so on it would be much easier in Englisch. So is there a way to change the language without reinstalling? I had a look for some answers, but the "Languages"-folder isn't located at
"C:\Program Files\Adobe\After Effects CS5"
I use the 64-bit-Version ![]()
I hope someone can help me,
Greets, GFXer
Create a file called ae_force_english.txt in your user home directory's Documents sub-folder.
Mylenium
This is as easy as it gets. Sorry to disappoint, but you rather be glad it is actually there and it's not like in other programs where you cannot switch languages at all. For all intents and purposes, this is not meant to provide an all out solution for flexible language switching, it is merely a fallback measure when the user needs to use prefab projects from the web or follow tutorials as wel las providing a compatibility fix for some plug-ins and scripts thatr do weird things in foreign language environments. Your program is still tied to the serial number you bought it with and that ultimately dictates any language settings. This also means that you cannot enforce other languages other than English. Would be pointless, anyways - you would have to have the proper Asian installer in the first place to even get the specific language files on your system. Same for otehr languages - a US/ North America installer will never give you Italian or German, just US English, Canadian French and possibly Spanish.
Mylenium
On Mac OS, you just have to show the app info (cmd-i) and switch the language.
On a general note, Adobe restricted the language available in all it's app since CS3 (and since CS4 for AE), you only have 2 options: run AE in the language you bought it (your localised version) and in internationnal english.
As a side note, and Todd will correct me if I'm wrong, the ability to switch to english is here thanks to the expressions not being always compatible from a language to another (like the slider controls for exemple). If it was not the case, I guess we'll all be stuck with our localised versions (and that would be extremely bad by the way).
In Snow Leopard 10.6 just drag English to the top of the list in the Language & Text tab in the System Preferences. Once you relaunch AE (or any other localized program) it will launch in English. Once it is launched you can switch it back to your language or everything else will start to switch to english :-)
-Lloyd
hi lloydalvarez,
what you are describing is a standard procedure for OS X 10.6, but it doesn't work for After Effects CS5. I even tried to remove completely Italian from Language & Text panel (and logged out...) but AE CS5 seems to run always in the language chosen during the installation.
I was able to force the app launching in English only in this way:
1) right click on "Adobe After Effects CS5.app"
2) click on "Show package contents"
3) navigate to "Contents/Resources/AMTLanguages"
4) delete or move the file "it_IT.txt"
5) launch the application and work with English interface
For switching back to Italian I just move back the deleted file in its original place. Even if this workaround is working, I was wondering if there was a better way to manage the switch between my local language and English.
thanks for any advice.
Not sure why it is not working for you. I switch back and forth all the time while I am authoring scripts to test the localization. It is one of the nicest new features in 10.6 in my opinion. You don't even need to log out, just drag the language to the top of the list and restart AE.
-Lloyd
I just tried it out and voilá: the solution for Snow Leopard is the one described by Mylenium.
Simply create an empty "ae_force_english.txt" in your user's "~/Documents" folder, ie "/Users/[username]/Documents"
"ps_force_english.txt" didn't work though
I wonder, if there's a way to start Photoshop (and all the other applications) in English, too.
@Llyod
I've tried several other times with different installations on different Macs, testing before and after activation, but I never managed to get the language switch working in your way. I've used OS X 10.6.3 and 10.6.4, After Effects downloadable trial and final version, with English, English US and English UK in languages, but it didn't work in any case. I always get it in Italian, unless I go for other tricks. Did you install it in English and then switched to local languages or the opposite? Thanks
@jackgoldfinch
thank you very much for sharing it, I finally got it working with the txt file. Good to know that the solution for Win is usable on OS X as well.
ps
In Photoshop you can go to "preferences" > "interface" > "UI text options" > "UI language" and choose from the drop-down menu language items, but I'm afraid that it could work only for multivolume/multilanguage lincenses...
look i just figured out how to do it... i read everyone else's but they didn't work... all i did was:
1) simply go to C:\Program Files\Adobe\Adobe After Effects CS5\Support Files\AMTLanguages
2) create a text and type en_US "or whatever language you're trying to change it to", then save and title it the same thing (en_US) "or whater language you're trying to change it to."
3) finally erase the orther languages then you'll be fine.
good luck.
I noticed that changing the method of txt language, disable help menu items support.
That's you can get help browser windows only from the native language installation.
I had a look into "C:\Program Files (x86)\Common Files\Adobe\HelpCfg"
where i found different path for each language, but i have not found any trick at the moment
