Home/Support/
Forums
185 Views 1 Reply Latest reply: Jun 13, 2010 1:54 PM by Flex harUI RSS
sascha/hdrs Calculating status... 11 posts since
Dec 9, 2005
Jun 13, 2010 12:32 AM
Compile-time error: Unexpected multiname type: 16 ...
I'm getting an oddball of a compile-time error which I cannot make head or tails of. Maybe somebody knows more about this? ...
This is the full error I'm getting:
       D:\Work\Dev\Eclipse\com.hexagonstar.hexagon\swc\hexagonlib_flash.swc( com.hexagonstar.util:VectorUtil)
       Error: Type was not found or was not a compile-time constant: .
I have a static util class named VectorUtil in a class library compiled as a SWC which i'm using in another project. A method I'm using from that class is the following one which generates a String-typed Vector from a provided Array ...
         * Creates a Vector of type String that is populated with strings from
         * the specified array.
         * @param array An array with string values.
         * @param sort true if the vector should be sorted.
         * @return A vector with strings.
        public static function createStringVector(array:Array,
            sort:Boolean = false):Vector.<String>
            var v:Vector.<String> = new Vector.<String>();
            for each (var i:String in array)
                v.push(i);
            return sort ? v.sort(sortStrings) : v;
         * sortStrings
         * @private
        private static function sortStrings(x:String, y:String):Number
            if (x < y) return -1;
            else if (x > y) return 1;
            else return 0;
... this seems to be all allright but  in the other project is a class which uses the createStringVector() method like this:
         * Parses a string made of IDs into a String Vector.
         * The IDs in the string must be separated by commata.
         * @private
         * @param string The string to parse ID values from.
         * @return A Vector with string values.
        protected static function parseIDString(string:String):Vector.<String>
            if (string == null || string.length == 0) return null;
            string = string.split(" ").join("");
            return VectorUtil.createStringVector(string.split(","));
... The strange things is that if I compile not the swc but add the sources of my code lib to the compiler arguments it works! But if I specify the SWC to compile I get the above error.
Legend
  • Correct Answers - 10 points
  • Helpful Answers - 5 points
