Hello,
I need some help setting up Dreamweaver CS5 to work with my blog (it runs on wordpress).
I am getting this errror message:
"Dynamically-related files could not be resolved because the site definition is not correct for this server."
What settings do I need to change to manage my blog from withing Dr CS5?
I will appreciate any help.
I'm having the same issue - even on pages without any php code. And on sites where the discovery actually works (still can't figure out what makes it work on the one site that it is working), it makes weird files that don't even exist. For example with a simple include like:
<?php include('C:\wamp\www\soundrezn\assets\media\test.php') ?>.
on a page named "about.php"
it includes the file successfully, but then also adds a file 'about-n1m5d1qljl.php'
I'm running Windows 7 64 bit.
You need to set up a testing server. Instructions for CS5 are here: http://www.adobe.com/devnet/dreamweaver/articles/setup_php.html.
It sounds as though it's including a temporary file. Without knowing more about your setup, it's impossible to judge.
By the way, this thread should be in the Dreamweaver Application Development forum, so I'm moving it there.
David,
My setup is Windows 7 64 bit with Wamp 2.0. I also have multiple Virtual Hosts setup. Each site has a virtual host associated with it so that, for example, a file in my Sound Rezn site which is located at C:\wamp\www\soundrezn opens in the browser at http://soundrezn.localhost/local/mockups/home.php
The example from my previous post is from the one site where site discovery doesn't completely fail. All the other sites I have setup result in the 'Dynamically-related files could not be resolved'' error even though I've inputted the settings in the same way as with the site that works. I'll have to duplicate the semi-working site and start making changes one-by-one to see where the issue is.
-matt
That setup should be fine. When you click the Discover link, Dreamweaver displays the following warning (unless you have selected the option to turn it off):
What this means is that Dreamweaver can find only those files that would normally be executed when the page is viewed in a browser. For example, if you include a file in a conditional statement, Dreamweaver will discover it only if the statement equates to TRUE. I have files that are included only when a form is submitted, so $_POST is not TRUE when Dreamweaver searches for them. As a result, they're not listed. If your script generates a temporary file, that's what Dreamweaver will find.
You might find it more useful to set up Site-Specific Code Hints.
marer1976 wrote:
Can I use the live server to work online instead of installing XAMP on my machine?
I haven't tested it on a remote server, because it's generally not recommended. However, you can set up the Testing Server definition the same way using FTP. Set the Root directory to your FTP root folder, and Web URL to the URL you would use to access the site.
You can also just paste the URL of the remote site into the Address field of the Browser Navigation Bar in Live View. As I understand it, you can download the files for editing as long as you have set up the FTP details in the Site Setup dialog box. After editing them locally, you upload them again.
Hello David,![]()
I already have wordpress site installed and running on localhost. But I am not knowing how to create it in Dreamweaver, always appears the phrase "dynamically-related files could not be resolved because the site definition is not correct for this server. Retry | Setup" When I enter the site.
If I click on "live code" address appears: "http://localhost/requinte/index.php. But if I change to "http://localhost/requinte/" the site shown to me.
Would create a step-by-step images (or film)![]()
I have MAMP running on a Mac, and a fully function Drupal site, but just like Ellu, I get the error saying "dynamically-related files could not be resolved because the site definition is not correct for this server. Retry | Setup," as soon as I remove the file name from the address bar and leaving "localhost" i see the site.
Testing out the new Dreamweaver CS5 as well and seeing this issue. I was able to get the page to render when I loaded a server on my local machine, but I cannot get this error message to go away no matter which server I am pointed at. This is on Mac OS X 01.6.3. Latest testing is using MAMP 1.9 with Joomla 1.5.17 site.
I'm having the same problem trying to get a Drupal site installed. I'm using Drupal's multisite capability and i'm using Virtual hosts.
Here is my example site structure:
My local folder and the testing server are the same.
local: /Users/name/Sites/sites/local.example.com
My remote setup is as follows:
Server folder: /var/www/sites/site.example.com
I've tried accessing the remote server as SFTP and Local/Network and still get the error.
I've tried setting the server folder as /var/www/drupal with no success (drupal multisites point to the same folder and drupal does the negotiation to the correct folder based on the url).
Has anyone created a whitepaper on the setup process for each of the CMS's this is supposed to work on? I've seen the Lynda.com videos a few times and even those don't show the site setup process. They just show a site that has already been setup that magically works.
I really don't think that it's an issue of setting things up right - I think it's just a bug that Adobe needs to fix. I actually was able to get the discovery working successfully on a couple of sites, but not consistently. I would literally copy the exact specs from a site where discovery was working, and then change only the necessary fields and it would fail. Considering that this is one of the major new features in DW CS5, you'd think they would have beta-tested this better. Or maybe Steve Jobs is right about the quality of their products...
I've already uninstalled my trial of CS5 until Adobe gets their act together.
I'm assuming there were beta testors for each of the supported CMS's. In other words, I'm assuming the support for these CMS's is a real, tested feature and not just a bunch of sales bullet items. Could someone please just post an example of a working server setup? I don't need (nor want!) a 7 page tutorial. Just an example of how to correctly setup the sever settings for a typical Drupal install. Wasn't there an example provided for testers?
As Promised a Youtube Tutorial Hopefully I explain everything well and not too quick I am assuming you know creating sites well I don't go I'm selected the root folder kind of thing but then again I want all to benefit so it is slow and like a 6 min video http://www.youtube.com/watch?v=oxxy3NsDspo
Hmmm, this sort of works for me using Drupal 6 and multisite. Sort of...
I am able to not get errors with my local testing server, however, for multisite,
1. there doesn't seem to be a way to separate the individual sites, i.e. the local folder is the drupal folder and one must navigate through the sites folder for each site (as opposed to having the individual site's folder as the root folder) Make sense? Are you seeing the same?
2. I'm able to edit existing CSS rules, but I can't seem to create new rules unless I do so in the CSS file itself. In other words, I can't click on a tag in the navigator and select New CSS Rule (and thus have the selector automatically generated).
Are you seeing the same behavior?
Answer to number One Yes I am however your activated theme or whatever drupal calls it in drupal before open you index.php and discover the dynamically-related files is the theme you are editing. if you really need multiple root folders have multiple wordpress or drupal installations
Answer to number two click on you style.css don't have index.php selected so basically when you see your style.css code add a new style say and select this document and it will work. ![]()
@Samb0123 Thanks very much for your efforts. I was able to successfully set up a Drupal 6 multisite install. However, there are issues, one of the biggest seems to be that Dreamweaver doesn't seem to recognize symbolic links. Have you noticed this too? I keep my sites and files folder out of my Drupal folder and symlink them so updates are easier.
Thanks, OK. I think I see where this is going. Basically, with Drupal multisite I point all of my sites to the same drupal folder and the differentiator is the local/remote URL. The problem with this is there is no way (maybe I'm missing something) to use the site management features of Dreamweaver (unless one is getting paid by the hour
). If, for instance I want to sync a site with a remote server, it will check my entire drupal install as well as all of my other sites, even though the site may only consist of a single css and php file. This is a problem.
I'm also having issues with symbolic links. They don't seem to be recognized either locally on OSX or remotely on Ubuntu.
Edit: And another issue is what is happening when the files are uploaded to the live/remote server. It creates a folder on the live server with the local server's URL. This is not desired as I use local.site.com for local and www.site.com for live.
Yet another issue, the edit live view page in new tab feature does not seem to work either. It keeps looking for the page as an existing .php page and as anyone who works with Drupal knows, pages are nodes in a DB. This means that all related files are only applicable and editable for the Home page which is completely useless (unless one only needs to edit the Home page)
This really isn't ready for primetime yet. It does not work with a typical Drupal install other than in the most superficial sense of the word "work". If it does, Adobe needs to spend some time on documentation. Looks like we've got another 18 month wait for another update. Back to Coda and CSSEdit.
I followed the instructions from the video and was able to get a fresh Joomla site to work. A copy of my working site, fails I had better luck doing it the way I thought was the method from the Dreamweaver help documents. I wonder what it would cause it not to like one site and be fine with another.
Yes I think the set-up process for this is stupid I think it should be navigate to your theme or your site as the root folder and the wordpress install as your server folder. I usually do use Cyberduck for my FTP anyway as I never really liked the dreamweaver one.
Symbolic links is a term I have never heard of before so I am not going to comment as I may look like a huge idiot.
Looks like Wordpress or Joomla seem to have the best support however I was working on a theme the other day all going great I come to make the functions.php file I only wanted one function for the new menus in the V3 beta 2 then I tested the menus it all works fine I close my dreamweaver had a little break.
I come back to open from where I left off and I get an error or it just shows me wp-header-blog.php or something like that couldn't see anything in live view inspect live code well live code only head <body><head></head></body> I don't think it even had the opening and closing html tags.
It all worked again once I reinstalled everything ect.. got rid of functions file and I confirmed it was functions file as I retraced my steps. (functions file in the default theme works fine wired I know)
Adobe will fix this bugs we have to remember we still have patches to come from Adobe. This is the first version of Dreamweaver CS5 Adobe will probably know of some of this bugs and are working on them as we speak they probably also have people who regularly scout all these forums probably especially their own. We would like to think we receive software and its a breeze and just works but for anyone who has done programming its not easy debugging or troubleshooting your script when an issue occurs. I do like to think big software suppliers have this piece of software to edit their script that updates as a person changes something in script and they have like 5-10 people working on the one file/function. and finding problems in the script so they get the debugging process done quicker.
@ Samb0123
Thank you very much! I had been setting up sites and servers so many times I lost count ... and it just would not work! I kept getting the "Dynamically-related files could not be resolved .." message.
Now thanks to your video I saw where I went wrong. Got it working now and I must say I am very impressed with this new feature. I will write a detailed review (in Dutch) on my blog and also link to your video.
Thanx again Samb0123!
grtz and happy testing!
dazz
@ Samb0123
Thank you very, very much!! I am now able to see MOST of the related files using Joomla, however I am now seeing all and I still get that error message. The Live View is functioning well.
The only thing I don't understand is how to get a Remote Server and Testing Server set up the the Site Definition box.
Erwin
I'm also trying to preview using live server, and get the same error message.
Since my site is already set up in a subfolder for testing, I checked my current server as both "remore" and "testing". My settings are as follows:
Root Directory: mydomain.com/wordpress/
Web URL: http://mydomain.com/wordpress/
No luck so far. Any suggestions?
I personally installed wordpress severals times locally as i could only make the dynamic discover feature work maybe once or twice each time i installed, then I would get this error. After trying several different server setups i almost gave up. Today I was working with wordpress outside of dreamweaver and was looking for a way to change permalinks to have a php extension. After looking for a while I noticed people kept talking about making differnet servers like xamp able to handle permalinks. Then the light came on for me and I realized each time I installed wordpress I would eventually change the default permalink to day and name. So I turned it back to default in wordpress and bingo I could now discover the files. Tried this several times to make sure this was the issue. Yippe!!
Michael
Michael![]()
Michaeltm I could kiss you!
I have been having this problem again and again. Today I have a site that I have to get to alpha by tomorrow and I'm tearing my hair out! I read your post and have changed the permalinks in wordpress back to the default and it all works fine in Dreamweaver.
To all who are having problems despite your wordpress site working fine in a browser - try resetting the permalinks to the default!!
What I want to find out now is how I can work with my site in the future, given that my client certainly won't want their permalinks at the default setting for SEO reasons..... Maybe by changing the permalinks in the admin screen before setting the site up in Dreamweaver for the first time?
