Aaronius9er9er
Air executing JRE installer - works in Eclipse, not as exe
Jun 16, 2010 9:40 AM
Hi guys.  I'm making an AIR app that, in Windows, determines if the user has Java installed and, if not, installs it by executing the JRE "online" installer (jre-6u20-windows-i586-iftw-rv.exe - downloadable from here: http://www.java.com/en/download/manual.jsp).  Here's my code:
package
     import flash.desktop.NativeProcess;
     import flash.desktop.NativeProcessStartupInfo;
     import flash.events.Event;
     import flash.events.IOErrorEvent;
     import flash.events.NativeProcessExitEvent;
     import flash.events.ProgressEvent;
     import flash.filesystem.File;
     import mx.controls.Alert;
     public class JavaUpgrade
          protected var nativeProcess:NativeProcess;
          public function upgrade(installerPath:String):void
               var info:NativeProcessStartupInfo = new NativeProcessStartupInfo();
               info.executable = File.applicationDirectory.resolvePath(installerPath);
               Alert.show('upgrade called: ' + info.executable.nativePath);
               info.workingDirectory = File.applicationDirectory;
               nativeProcess = new NativeProcess();
               addListeners(nativeProcess);
               nativeProcess.start(info);
          protected function addListeners(nativeProcess:NativeProcess):void
               if (nativeProcess)
                    nativeProcess.addEventListener(ProgressEvent.STANDARD_OUTPUT_DATA, outputDataHandler);
                    nativeProcess.addEventListener(ProgressEvent.STANDARD_ERROR_DATA, errorHandler);
                    nativeProcess.addEventListener(IOErrorEvent.STANDARD_INPUT_IO_ERROR, errorHandler);
                    nativeProcess.addEventListener(IOErrorEvent.STANDARD_OUTPUT_IO_ERROR, errorHandler);
                    nativeProcess.addEventListener(NativeProcessExitEvent.EXIT, exitHandler);
          protected function outputDataHandler(event:ProgressEvent):void
               var output:String = nativeProcess.standardOutput.readUTFBytes(
                         nativeProcess.standardOutput.bytesAvailable);
               Alert.show(output);
          protected function errorHandler(event:Event):void
               Alert.show(event.toString());
          protected function exitHandler(event:NativeProcessExitEvent):void
My code works exactly as expected when I'm debugging the app from Eclipse, but when I create a native installer, install the air app, and then run it, the JRE installer never appears.  I do get the alert that says, "upgrade called: C:\Program Files\JavaInstaller\jre-6u20-windows-i586-iftw-rv.exe" and that exe does exist at that location but it just never shows up.  Nor does any additional process show up in my task manager.  Ideas?  It's baffling.
    Community Member
    Jun 16, 2010 11:29 AM
    Actually - that is a great trick to know. There have been other requests by folks to allow some kind of auto-elevation of privs on windows when launching something with NativeProcess - but this is a great workaround.
    Chris Thilgen
    AIR Engineering
Legend
  • Correct Answers - 10 points
  • Helpful Answers - 5 points
