Published F4v video and html plays locally but not online...
Jun 16, 2010 11:53 AM
I am running Windows 7/64 and Master Collection. I've created a clip of DV NTSC footage to test F4V publishing. Done this many times with CS3 and flv files but this has me stumped. I can successfully view the video and web page locally in IE and Netscape but on upload to my server I have the menu and placement right but no video appears. I created the clip in Premiere Pro CS5 and exported to F4V/FLV best quality. Opened an Actionscript Media DV NTSC template in Flash Pro CS5 and imported the video which I had pre-placed in my root web folder locally. I then exported the swf and saved the fla. All files were then in my root folder and the scrpts in the scripts folder. In Live View in Dreamweaver CS5 all looked fine. In each browser locally the video played as expected. Once all files were uploaded the video was not visible.
The file is located here...
http://www.goodmangraphic.com/2010vid.htm
in the root directory are... Sequence 01_1.f4v, minimaflatcustomcolorall.swf, 2010movie.swf, 2010movie.fla and in the scripts folder, expressinstall.swf and swfobject_modified.js.
Thanks in advance for any guidance on what I may be doing wrong.
John
    Jun 16, 2010 12:03 PM   in reply to johnrg
    Did you insert the movie to the Stage before or after you saved the file?
    What I see happen a lot is that people open a brand new Flash file, insert a video, then save the file.  It works perfect locally, but not on the server.  This is because, when inserting a video into an unsaved document, Flash automatically creates an absolute path to the video on the computer.  Since that path is not available on the server, the video doesn't load.
    To remedy - open the FLA, select the video object on the stage and go to the "Parameters" panel.  Here you will see a list of attributes for the video.  In the "source" attribute, you will see a path to a location on your computer ("C:/Documents and Settings/..../video.f4v" or "D:/My_Files/project/video.f4v" or some such).  Change this to be a relative path (just "Sequence 01_1.f4v"), re-export and re-upload the SWF.
    For future reference, you can avoid this by saving the FLA before importing a video.  If the file is saved, Flash will use a path relative to the location of the FLA on your computer, rather than the absolute path it needs to work with an unsaved project.
    Jun 17, 2010 5:02 AM   in reply to johnrg
    It sounds like the server isn't set up to serve up F4V files.  Check that the MIME-TYPE is there (or have your server administrator do so).
    Jun 17, 2010 8:01 AM   in reply to johnrg
    Yeah, those pesky MIME-TYPES can be a pain in the rear. Glad I could help.
