Mark J M Wilson
Performance in LR3 library
Jun 9, 2010 5:17 AM
Anyone else having problems stepping through files in the LR3 Library module?
Develop seems to work fine, its just library giving me problems.  I can step through 15-20 18mp RAW files in loupe view and then Lightroom seems to slow right down or stop for a few seconds.  If I leave it for a while, it goes back to normal.  I
I have to really speed through 50 or so 8mp files to get similar problems.
Further investigation reveals that the drives are thrashing when LR3 'stops'.
By watching a combination of LR's system info and windows resource monitoring, it seems that LR3 uses about 20% of total RAM and then stops and hits the drives...but neither virtual or physical RAM use seems to increase any further.  I have to wait for the RAM to be released and then all seems OK until it hits the 'ceiling' again.
My system:
Win 7 pro 64bit.
Intel i7 965 extreme
6gb RAM
nVidia GTX 260 (driver version 197.45)
Relevant internal drives (all with space, 7200rpm):
disk 1: windows + apps (no windows swap)
disk 2: document data + CR cache (set to 100gb)
disk 3: catalogs, previews + photo files
disk 4: windows swap
Interestingly, the windows disk seems to be under load when it slows down, although I can't see why based on my config.
I have tried new catalogs, upgraded catalogs, purging previews, purging CR cache, 1:1 previews, putting previews on a 5th internal disk...
Anyone any ideas?
    Community Member
    Jun 9, 2010 6:13 AM
    purging previews
    Have you tried building previews?
    Community Member
    Jun 9, 2010 5:39 PM
    I had exaclty the same problem, couldn't work in Library and it was fine in Develop.  I reduced the resolution of my monitor and everything was fine.  On my computer must have something to do with the older prosessor and the screen resolution.
    Community Member
    Jun 10, 2010 2:03 AM
    I hit the 'memory ceiling' and the disk starts thrashing after 20 images or so (RAM usage peeks at about 1.2gb).
    How can it hit the memory ceiling at 1.2 GB on a 6GB machine running 64-bit windows? You're running 64-bit Lightroom, right?
    Community Member
    Jun 13, 2010 9:30 AM
    I'm having some of the same issues. The import dialog is running super slow for me. I'm running 64 bit Vista, dual 2.6 processor with 8 gb of RAM, with an ATI 4570 HD video card. And the LR3 is running worse than 2.7 did for me. When I scroll through the images to choose which images to import, LR3 eventually freezes up. I read this thread and reduced the window size of LR3 when working on my 24" moniotr and that seems to help. But over time it seems to get slower and slower as i scroll through the images, eventually slowing to a painful crawl. So much so that it takes about 30-45 seconds to scroll to the next image. Ouch. Then when I finally import the files, the process completely takes over my machine. So much so that I cannot do anything else in LR or anything on my PC for that matter. I was importing and a few minutes ago. See my stats below. It was the only prgram running on my PC at the time.
    I was very excited about LR3 but there seems to be some definite performance issues now that weren't present in 2.7. Am I doing something wrong? Is there something I should tweak in the settings of LR?
    Even after the import is done, it appears my RAM stays pegged now while LR3 is open.
    Also I am getting blurry thumbs in the import dialog. It's completely unusable. Is anybody else seeing this?
    _H_,
    Community Member
    Jun 19, 2010 4:31 AM
    Same here, get to around 100 images and the library starts to stall and get shaky to the point it hangs. Give it a moment to think and we are ok for a while but then its not long before we start to stall again.
    Quad core windows vista pc with 4GB of ram. I cant see why I should be having issues with this........
Legend
  • Correct Answers - 10 points
  • Helpful Answers - 5 points
