_GFXer_
Change language in After Effects CS5
Jun 10, 2010 8:44 AM
Hi guys,
I have AE CS5 and installed the whole thing in German (because I am German^^) but now I realize that for tutorials and so on it would be much easier in Englisch. So is there a way to change the language without reinstalling? I had a look for some answers, but the "Languages"-folder isn't located at
"C:\Program Files\Adobe\After Effects CS5"
I use the 64-bit-Version
I hope someone can help me,
Greets, GFXer
    Jun 10, 2010 9:52 AM   in reply to _GFXer_
    Create a file called ae_force_english.txt in your user home directory's Documents sub-folder.
    Mylenium
    Jun 10, 2010 11:42 AM   in reply to _GFXer_
    As I wrote, it needs to be in the Documents (Dokumente) sub-folder, not the root of the user home dir.
    Mylenium
    Jun 10, 2010 5:37 PM   in reply to _GFXer_
    Will this work for two-byte versions?  I've always been interested in  seeing Adobe products in Japanese.
    Jun 10, 2010 5:46 PM   in reply to Mylenium
    is there a similar solution on Mac?
    Calculating status...
    Jun 10, 2010 7:01 PM   in reply to Pigumon
    At least in Win 7 Ultimate you can run AE CS5 in Japanese by changing the OS region/language settings to Japanese.
    It would be great if someone knows an easier way like the ae_force_english trick though
    Jun 10, 2010 11:46 PM   in reply to jspence2
    This is as easy as it gets. Sorry to disappoint, but you rather be glad it is actually there and  it's not like in other programs where you cannot switch languages at all. For all intents and purposes, this is not meant to provide an all out solution for flexible language switching, it is merely a fallback measure when the user needs to use prefab projects from the web or follow tutorials as wel las providing a compatibility fix for some plug-ins and scripts thatr do weird things in foreign language environments. Your program is still tied to the serial number you bought it with and that ultimately dictates any language settings. This also means that you cannot enforce other languages other than English. Would be pointless, anyways - you would have to have the proper Asian installer in the first place to even get the specific language files on your system. Same for otehr languages - a US/ North America installer will never give you Italian or German, just US English, Canadian French and possibly Spanish.
    Mylenium
    Jun 11, 2010 12:31 AM   in reply to Mylenium
    On Mac OS, you just have to show the app info (cmd-i) and switch the language.
    On a general note, Adobe restricted the language available in all it's app since CS3 (and since CS4 for AE), you only have 2 options: run AE in the language you bought it (your localised version) and in internationnal english.
    As a side note, and Todd will correct me if I'm wrong, the ability to switch to english is here thanks to the expressions not being always compatible from a language to another (like the slider controls for exemple). If it was not the case, I guess we'll all be stuck with our localised versions (and that would be extremely bad by the way).
    Jun 11, 2010 4:25 AM   in reply to Sébastien Périer
    well, yes, cmd + I is quite handy on Mac Os 10.5 and previous versions, but it's not an option for Snow Leopard ( OS X 10.6 ). Is there any solution that doesn't require to show package content and manually edit inside aftereffects.app ?  thanks
    Jun 11, 2010 4:27 AM   in reply to GAntico
    Jun 11, 2010 1:55 PM   in reply to GAntico
    In Snow Leopard 10.6 just drag English to the top of the list in the Language & Text tab in the System Preferences. Once you relaunch AE (or any other localized program) it will launch in English.  Once it is launched you can switch it back to your language or everything else will start to switch to english :-)
    -Lloyd
    Jun 12, 2010 5:05 PM   in reply to lloydalvarez
    hi lloydalvarez,
    what you are describing is a standard procedure for OS X 10.6, but it doesn't work for After Effects CS5. I even tried to remove completely Italian from Language & Text panel (and logged out...) but AE CS5 seems to run always in the language chosen during the installation.
    I was able to force the app launching in English only in this way:
    1) right click on "Adobe After Effects CS5.app"
    2) click on "Show package contents"
    3) navigate to "Contents/Resources/AMTLanguages"
    4) delete or move the file "it_IT.txt"
    5) launch the application and work with English interface
    For switching back to Italian I just move back the deleted file in its original place. Even if this workaround is working, I was wondering if there was a better way to manage the switch between my local language and English.
    thanks for any advice.
    Jun 13, 2010 6:19 AM   in reply to GAntico
    Not sure why it is not working for you.  I switch back and forth all the time while I am authoring scripts to test the localization.  It is one of the nicest new features in 10.6 in my opinion.  You don't even need to log out, just drag the language to the top of the list and restart AE.
    -Lloyd
    Jun 18, 2010 2:17 AM   in reply to GAntico
    I just tried it out and voilá: the solution for Snow Leopard is the one described by Mylenium.
    Simply create an empty "ae_force_english.txt" in your user's "~/Documents" folder, ie "/Users/[username]/Documents"
    "ps_force_english.txt" didn't work though I wonder, if there's a way to start Photoshop (and all the other applications) in English, too.
    Jun 21, 2010 6:05 AM   in reply to lloydalvarez
    @Llyod
    I've tried several other times with different installations on different Macs, testing before and after activation, but I never managed to get the language switch working in your way. I've used  OS X 10.6.3 and 10.6.4, After Effects downloadable trial and final version, with English, English US and English UK in languages, but it didn't work in any case. I always get it in Italian, unless I go for other tricks.  Did you install it in English and then switched to local languages or the opposite? Thanks
    Jun 21, 2010 6:27 AM   in reply to jackgoldfinch
    @jackgoldfinch
    thank you very much for sharing it, I finally got it working with the txt file. Good to know that the solution for Win is usable on OS X as well.
    ps
    In Photoshop you can go to "preferences" > "interface" > "UI text options" > "UI language" and choose from the drop-down menu language items, but I'm afraid that it could work only for multivolume/multilanguage lincenses...
    Jul 12, 2010 8:03 PM   in reply to _GFXer_
    Hi Millenium.
    I´ve tried this solution for Spanish but it doesn´t work.
    Have you got any workaround or recommendation for me to success?
    I´m on Windows 7, 64 bit,
    C/Usuarios/"MyName"/Mis documentos     (C/Users/"MyName"/My documents)
    Will appreciate any further help.
    Juan. Colombia.
    Apr 11, 2011 10:41 PM   in reply to _GFXer_
    look i just figured out how to do it... i read everyone else's but they didn't work... all i did was:
    1) simply go to C:\Program Files\Adobe\Adobe After Effects CS5\Support Files\AMTLanguages
    2) create a text and type en_US "or whatever language you're trying to change it to", then save and title it the same thing (en_US) "or whater language you're trying to change it to."
    3) finally erase the orther languages then you'll be fine.
    good luck.
    Aug 19, 2012 12:40 AM   in reply to Dinard05
    I noticed that changing the method of txt language, disable help menu items support.
    That's you can get help browser windows only from the native language installation.
    I had a look into "C:\Program Files (x86)\Common Files\Adobe\HelpCfg"
    where i found different path for each language, but i have not found any trick at the moment
    Sep 6, 2012 2:20 PM   in reply to _GFXer_
    Oh this was very helpful, its working so far... I dont know who would use after effects in anything other than english, since all the good tutorials are in english and its a mess to try to follow them in another language. Thanks.
