How does one upload a file from flex to a cfc? Can you do the file upload via remote object? I usually do uploads cia cfm but prefer the asnc capabilities of remote object calls.
The issue here is myFile. For flex we need to pass this name as paramenter becuase it's not html form item like:
<cfcomponent>
<cffunction name="uploadFile" access="remote" output="false" returntype="void">
<cfargument name="file" required="Yes" type="any">
<cffile action="upload" filefield="#arguments.file#" destination="C:\temp\" nameconflict="makeunique">
</cffunction>
</cfcomponent>
From flex I'm getting the file using fileReference like:
private function browseAndUpload():vo
...Copy link to clipboard
HI,
I'm tryin to do this now, did you figure this out?
thanks
Johnny
nope
Will something like this not work:
<cfcomponent>
<cffile action="upload" filefield="myFile" destination="C:\temp\" nameconflict="makeunique">
</cffunction>
</cfcomponent>
(where myFile is the name of the formfield containing the uploaded file's name).
This works fine from an HTML-originated POST, so I would assume it would work from a Flash-originated POST too: the CF server won't care (or even know).
Also, I'm intrigued by what you mean by the "asnc capabilities of remote object calls" comment. Just that I don't understand what you mean, I mean. I'm not questioning it.
Adam
<cfcomponent>
</cffunction>
</cfcomponent>
private function browseAndUpload():void
fileReference = new FileReference();
fileReference.addEventListener(Event.SELECT,fileReference_Select);
fileReference.addEventListener(Event.CANCEL,fileReference_Cancel);
fileReference.browse();
private function fileReference_Select(event:Event):void
fileReference.addEventListener(ProgressEvent.PROGRESS,fileReference_Progress);
fileReference.addEventListener(Event.COMPLETE,fileReference_Complete);
fileReference.addEventListener(IOErrorEvent.IO_ERROR,onLoadError);
//fileReference.upload(request);
fileName = fileReference.name;
myFile.htmlText = fileReference.name;
SM_RO.importNSA();
filerReference have an upload method to upload the file but I can't use that becuase I need to process my upload with my cfc.
I'm getting an error:
Failed to import the file. The cffile action="upload" requires forms to use enctype="multipart/form-data". Please also make sure the file is not open.
I can't find the way to setup the enctype becuase again i can have html form items in flex, or I can?
Johnny
I'm making this up as I go along a bit, but I would not worry so much about the CF error message saying the form needs to have that enctype. What it means is the HTTP request needs to have a content-type of multipart/form-data. It doesn't matter how it gets to be sent like that... a form-tag attribute, or just setting the header via some other mechanism: neither the web server nor CF will know/care how it goes done.
A case in point is that one doesn't need to post to that CFC method via a form... one could just as much post if via <cfhttp>. There's no forms involved in doing it that way; just CF creating an HTTP request.
Now... I don't know Flash from... err... Adam, but I'm "certain" that if CF received the request in the correct format (so the corrent content-type, and a field with a file in it), the CF side of things would work fine.
It's just a matter of coercing Flex to do that for you with Flash. Which might be a question for a Flex forum, not a CF one..? The question, I think, is more "how do I upload a file using Flex" rather than "... to a CF server".
Adam
Got it, I try flex forum but no help.
It works fine if I use a cfm file like this example:
http://askjayvir.blogspot.com/2008/07/sample-flex-file-upload-application.html
But like I said before, i want to use the cfc.
Johnny
Hi All,
I discover my issue here.
Every time I use filereference, it's using a new session and I lost my login. In my application I'm using application.cfc with cflogin.
I hope it's a way to keep my session using fileReference.
Regards
Johnny
Hi all
Is it possible to upload a file with a cfc from flex, if some can some one please post some code.
Thanks Asen
