I recently installed workbench 8.2 succesfully on my laptop and am able to work with the forms created on our LiveCycle 8.2 installation. However, on another machine I have repeatedly been unable to get the installation to work... when I attept to open a form I receive a "LiveCycle Designer Not Installed" error stating that designer isn't installed and that I should re-install... Can somebody tell me why this is happening? i.e. why it isn't being installed - repeated attempts to re-install have not worked and I have no idea why the install process is deciding not to install designer.
Total Likes
That would happen if you already have Designer installed (which also comes with Acrobat). Check to see if you have Acrobat
installed on your machine and do you already have designer installed on your machine?
Total Likes
I thought that might be the problem so I checked to see whether Designer
was present via the add/remove programs screen - it isn't; only
Workbench shows up. Before attempting to re-install I also took the step
of manually deleting the C:\Program Files\Adobe\LiveCycle ES folder (the
uninstall didn't remove it)... is there some other step I should take to
remove designer (or to see if its installed)?
Jeff Rowell
Senior Technical Consultant
CGI Services to BCE
125 Commerce Valley Drive West 3rd Floor
Markam, Ontario
L3T 7W4
PH: (905) 282-3485 (Creekbank)
CONFIDENTIALITY NOTICE: Proprietary/Confidential Information belonging
to CGI Group Inc. and its affiliates may be contained in this message.
If you are not a recipient indicated or intended in this message (or
responsible for delivery of this message to such person), or you think
for any reason that this message may have been addressed to you in
error, you may not use or copy or deliver this message to anyone else.
In such case, you should destroy this message and are asked to notify
the sender by reply email.
Total Likes
Sounds like an irritating problem. Hope you got it fixed
James
Total Likes
