8 core Mac renders slower than dual core iMac ! ????
Jun 25, 2010 10:51 AM
I have a 3.6 gig core duo iMac witgh 8 gigs..
Also an 8 core Mac Pro with 12 gigs of ram.
I have an AE comp with some particles, motion, etc.
Watching the render in the queue the iMac renders a frame per second.
Watching the render on the Mac Pro, the render is about 1 frame in 4 seconds.
We've changed the settings in the Multi-processing prefs, but the most we can get
is one frame in 1 second using multi-core. Why is the iMac as fast as the Mac Pro?
I don't get it.
    Jun 25, 2010 11:20 AM   in reply to rickmorton
    Please specify, are you using CS5 64-bit or CS4 32-bit?  If it's the latter, the most RAM that After Effects will use is 4GB.
    Jun 25, 2010 2:09 PM   in reply to rickmorton
    markerline is mistaken about the use of memory in After Effects CS4.
    Each instance of After Effects CS4 can only see and use 4GB of RAM, but the Render Multiple Frames Simultaneously multiprocessing feature starts multiple instances of the application to render frames in the background. Each can see and use 4GB. (The difference between CS4 and CS5 is that each instance of After Effects can see and use more RAM.)
    Please read the documents linked to from here and then report back, giving your exact settings, especially the Memory & Multiprocessing settings.
    Jun 25, 2010 2:46 PM   in reply to Todd_Kopriva
    Thanks for clarifying Mr. Kopriva.  I was wondering why CS4 said 4GB RAM on the splash screen.  Now I know I can run multiple instances on my multicore PC.
    Jun 25, 2010 2:48 PM   in reply to rickmorton
    Rick, it's not a matter of "special" settings. Rather, the settings can be optimized for various scenarios. It may just so happen that the defaults align better with the configuration for one computer than with the other.
    Jun 25, 2010 3:56 PM   in reply to rickmorton
    Did you read the documents that I pointed to?
    Jun 25, 2010 4:00 PM   in reply to rickmorton
    Are you using footage that is being accesed over a network? Are you rendering locally or to a network or peripheral drive?
    Jun 25, 2010 4:18 PM   in reply to rickmorton
    > I guess I was hoping someone could just say, "Ohhhh.....  here's what you have to do.... "
    That someone is me.
    And since I answer this question a _lot_, I wrote up the general documents that I pointed you to. If you aren't able to make use of those, I can help you further, but I didn't want to waste my time retyping something that I already typed once.
    I need to get something else done right now, but I'll come back to this thread soon.
