I have a 3.6 gig core duo iMac witgh 8 gigs..
Also an 8 core Mac Pro with 12 gigs of ram.
I have an AE comp with some particles, motion, etc.
Watching the render in the queue the iMac renders a frame per second.
Watching the render on the Mac Pro, the render is about 1 frame in 4 seconds.
We've changed the settings in the Multi-processing prefs, but the most we can get
is one frame in 1 second using multi-core. Why is the iMac as fast as the Mac Pro?
I don't get it.
markerline is mistaken about the use of memory in After Effects CS4.
Each instance of After Effects CS4 can only see and use 4GB of RAM, but the Render Multiple Frames Simultaneously multiprocessing feature starts multiple instances of the application to render frames in the background. Each can see and use 4GB. (The difference between CS4 and CS5 is that each instance of After Effects can see and use more RAM.)
Please read the documents linked to from here and then report back, giving your exact settings, especially the Memory & Multiprocessing settings.
I read the docs... just a bit confusing. Guess I'm not very good at this.
No.. no network. All local and rendering to an internal drive.
As I mentioned, I DID try changing settings of processors and ram, etc. and the best I could
seem to get was the same as the iMac. I did manage to get some SLOWER renders, but the
fastest I could get was the same.
I guess I was hoping someone could just say, "Ohhhh..... here's what you have to do.... "
That someone is me.
And since I answer this question a _lot_, I wrote up the general documents that I pointed you to. If you aren't able to make use of those, I can help you further, but I didn't want to waste my time retyping something that I already typed once.
I need to get something else done right now, but I'll come back to this thread soon.
