I recently upgraded to Adobe PS CS5 Extended and when I try to use the
Repousse Feature it is greyed out. I've updated my drivers, and done everything I've found in my
hours of research. I've even tried turning on the OpenGL Drawing but when I do it it says that the Graphics Hardware Acceleration is unavalible.
I'm not sure why this is either.
I came across this file someone posted than can trick it into running on something else to get it to work or something.
I'm really not sure as to what exactly it is or does.
Anyone know how I can get the repousse feature to work?
When I try and use it it says that it's currently unavailable.
ANY HELP AT ALL WOULD BE MUCH APPRECIATED
Thanks.
I'm not sure how I would go about doing this.
My graphics card specs are:
GeForce 6150SE nForce 430
Memory clock: 100 MHz (200 MHz data rate)
Memory Interface: 32 bit
Dedicated Video Memory 64 mb
Video BIOS version: 5.61.32.20.01
IRQ: 21
Bus: FPCI
I'm running on Windows 7 Ultimate.
I know those aren't the best specs but I haven't had a problem until CS5.
Check the website for your particular card and see if it's capable of graphics support for Shader Model 3.0 and OpenGL 2.0
Try this: http://kb2.adobe.com/cps/831/cpsid_83117.html
It says:
Motherboard GPU Features and Benefits for:
Microsoft® DirectX® 9.0 Shader Model 3.0 Support
Ensures top-notch compatibility and performance for all DirectX 9.0 applications, including Shader Model 3.0 titles.
NVIDIA® CineFX™ 3.0 Engine
Powers the next generation of cinematic realism. Full support for Microsoft DirectX 9.0 Shader Model 3.0 enables stunning and complex special effects. Next-generation shader architecture delivers faster and smoother gameplay.
NVIDIA® Intellisample™ 3.0 Technology**
The industry's fastest antialiasing delivers ultra-realistic visuals, with no jagged edges, at lightning-fast speeds. Visual quality is taken to new heights through a new rotated grid sampling pattern.
NVIDIA® nView™ Multi-Display Technology
Advanced technology provides the ultimate in viewing flexibility and control for multiple monitors.
Full-Speed 32-Bit Color Precision
Delivers increased image quality with no performance compromise.
NVIDIA® Digital Vibrance Control™ 3.0 Technology
Allows the user to adjust color controls digitally to compensate for the lighting conditions of their workspace, in order to achieve accurate, bright colors in all conditions.
OpenGL® 1.5 Optimizations and Support
Ensures top-notch compatibility and performance for all OpenGL applications.
300 MHz RAMDAC
Blazing-fast RAMDAC supports display with high, ergonomic refresh rates up to and including 1920x1440@75Hz.
SDVO Interface
NVIDIA RAID and MediaShield™ technology
Provides a simple point and click wizard-based interface for creating and managing multi-disk storage configurations. Allows multi-disk designs to be set up for maximum performance (RAID 0), for data protection (RAID 1), and for select models a combination of both performance and protection (RAID 0+1 and RAID 5). Also allows RAID volumes to be converted from one configuration to another with a single operation. Uniquely allows users to assign an extra disk to any RAID volume so that should a disk failure occur, NVIDIA RAID will automatically remove the failed disk and replace it with the spare.
SATA 3Gb/s
Take advantage of the latest SATA 3Gb/s hard disk drives, which double bus bandwidth and provides blazingly high disk performance. This technology provides easy-to-install, high-performance but low-powered hard drives.
NVIDIA nForce Networking
NVIDIA nForce Networking solution enables Internet connectivity through industry standard 10/100 Mb/s Ethernet connection.
NVIDIA Native Gigabit Ethernet
The industry's fastest Gigabit Ethernet performance eliminates network bottlenecks and improves overall system efficiency and performance.
Feature only available for GeForce 6150 SE/ nForce 430, and GeForce 6100/ nForce 430.
High Definition Audio (HDA)
High definition audio brings consumer electronics quality sound to the PC delivering high quality sound from multiple channels. Using HDA, systems can deliver 192 kHz/32-bit quality for eight channels, supporting new audio formats.
USB Ports
A standard plug-and-play interface that provides easy-to-use connectivity for USB devices. Supports 8 USB 1.1 / 2.0 ports.
OpenGL 2.0 Optimizations and Support
Ensures top-notch compatibility and performance for OpenGL applications.THIS ONE ISN"T IN THE LIST THOUGH. 1.5 is for what I have and 2.0 is for another. So i guess i need a new one?
What should I get?
http://kb2.adobe.com/cps/831/cpsid_83117.html gives you a list of supported cards. I guess you can take your pick. ![]()
