muhmu
How to use LrShutdownPlugin
Jun 20, 2010 1:56 AM
My plugin spawns a background process, which needs to be shutdown when Lightroom is exited or the plugin is disabled.
SDK manual states that in Info.lua, I can specify a function using LrShutdownPlugin key.  I am a bit confused with this - Info.lua does not allow require/import, so I can't really do anything useful with this?  Ideally, I'd like to be able to make a HTTP request when Lightroom is exiting.
Same goes for LrEnablePlugin/LrDisablePlugin functions, I don't even know how to print a line into log so I don't know if these actually were called or not...
    Jun 22, 2010 1:38 AM   in reply to muhmu
    I see your point. Say, I wonder if its a documentation error - did you try specifying a lua filename string instead, like LrInitPlugin?
    Jun 22, 2010 12:40 PM   in reply to muhmu
    I think we need Chet Drarvik to straighten this out (Eric Scouten's replacement).
    Jun 26, 2010 1:07 AM   in reply to muhmu
    Muhmu,
    Thanks for the update. So for the shutdown, you specify a lua file (like for LrInitPlugin), not a function (like it says in the sdk3 guide document) - right?  If so, I think a bug-report against the document is in order.
    I'm looking forward to the release of your plugin...
    PS - Have you tried my latest (DevAdjust)?
    Rob
