Hi all,
I am running the LR3 64 bits test version under windows Vista64. I have a problem with the RAM memory allocation. When I start working, mainly checking the new imported photos in the library module and marking some as rejected, the allocated memory is 2GB. As I work the allocated memory raises constantly in a straight line until the 8GB available are used. Then I need to restart LR because it is impossible to work. When I restart the program the allocated memory drops back inmmediately to 2GB again and the same issue starts over. Has anybody seen a similar behaviour?
BR
Angel
Same over here.
Win7 Ultimate 64 Bit
8 GB Ram
When i access a folder with DNGs (converted from Nikon D3 RAW Files), i can pick/reject 40 - 44 photos (reproduceable) and then from one photo to the next everything (thumbnails and imagearea) is grey and i need to restart Lightroom. This never happened in Beta 2.
PLEASE ADOBE.. fix this fast
I consistently saw this behaviour during beta, and sometimes when LR was closed (for reasons given) the UI would completely disappear but Windows task manager would still show LR under "processes" (not "Applications") for up to a minute or more before the memory is released.
At first I thought LR may be "loosely" holding onto the memory with a willingness to let it go to other applications if needed, however I found it ground the whole system to a halt.
Disappointed this is still occurring in the released version.
Windows 7 (64) / Core i7 / 8GB Ram.
What's your screen resolution?
There we reports about memory usage with large 30" displays. http://forums.adobe.com/message/2880270#2880270
I am seeing LR quickly jump up to 1,200,000 K of memory usage and holds there between that and 1,700,000. Definately a memory hog.
You must have never worked with SQL Server, then.
Many programs that
use a db (and that's all your catalog is, a db file, using SQLLite) grab
as much memory as they can, to keep db operations in memory, for speed
reasons.
I have the same experience. It becomes slower and slower when I edit images. After editing some images even the smallest change in eg. brightness is stuttering. After restart of LR it is responding very quick again.
Memory is used up to 100% and cpu is very often up to 100%.
I have a Q6600 ,4GB mem and GTX 275 card.
- Terje
I have been having the same problem...posted about it last night in a thread discussing "Why LR3 is so slow?". I have a Dell Precision 690, dual Xeon Quad Cores 8gb RAM and am running Win7 64x..or is it x64? My image catalog is 190,000 and growing.
I never saw my memory usage jump above 40%. Last night I noticed the RAM use was up to 87%. CPU use had never topped 40%, last night it was hitting high 60%. I backup and optimize catalog every night when I shut down. I too found that exiting LR3 solved the memory bog, and watched as each new file opened/edited pushed the RAM usage cumulatively higher.
I have to correct a bit here. I had another login on my computer running a program causing the memory to be used at 100%, almost not using cpu. After stopping that and restarting my computer I am still using 2.5 up to 3.6 GB memory ( got 4GB) when using LR. Cpu is the same (up to 100%) and it is stuttering after a while.
But memory is not up to 100% as I said. I will not make this sound worse than it is ![]()
- Terje
Copyright © 2012 Adobe Systems Incorporated. All rights reserved.
Use of this website signifies your agreement to the Terms of Use and Online Privacy Policy (updated 07-14-2009).
