Disappearing Timeline Panel
Jun 28, 2010 5:51 AM
Hi.
I have a problem where every time i close flash normally (it's not crashing) and fire it up again, my timeline panel is missing. I have to press ctrl+alt+t or window>timeline to bring it up again and reposition it. What's going on here?
Thanks.
  • kglad
    Jul 21, 2002
    Jun 28, 2010 6:54 AM   in reply to MattBru
    click window/workspace and select a panel setup that's to your liking (or create a custom one and save it).  close your application and reopen.  any problem?
  • kglad
    Jul 21, 2002
    Jun 28, 2010 7:12 AM   in reply to MattBru
    after clicking myworkspace right click the title bar of your flash application (or right click the icon at the upper left) and click close.  reopen.  any problem?
    Jun 28, 2010 8:34 AM   in reply to MattBru
    I encounter a similar problem about 50% of the time. I have to “reset” my workspace to get the timeline to display.
    Jun 28, 2010 3:16 PM   in reply to MattBru
    Sounds like something may have gotten messed up in a revision of the workspace you're working with. I wonder if you switch to a separate default workspace that doesn't have this problem (ie: one that you do not need to reset), and then modify that to your needs. Then restart Flash and see if the timeline remains.
    Jun 29, 2010 4:27 AM   in reply to jdehaan
    I have tried that. I tried using several of the default workspaces and by adding all panels manually (many times). I was not able to note any difference.
    Jun 29, 2010 10:38 AM   in reply to brooksrv
    Could you save a version of your workspace when the Timeline is gone, and attach that and one of your other workspaces  (one where you reset and it then appears)?  Thanks
