I was used to the firewire, mini-dv tape capture process, but have been confused about how to import my video footage from an AVCHD camcorder into Premiere Pro CS5.
The capture window doesn't work with the camcoder connected by USB or with the memory card from the camera in a USB card reader.
How can I preview the video footage and select which clips to import?
Thanks for any advice.
My Canon Vixia HFS100 creates AVCHD (MTS) files on a memory card
Since the REALLY CRAPPY Canon software doesn't like Win7 64bit, and Win7 by itself doesn't "see" the camera (I might be able to fix this, but I just don't care to mess around with settings) I bought a USB adapter (link below) and just take the memory card out of the camera and then use Windows Explorer to copy the MTS files to my computer
According to my testing, there is no directory structure I need to copy... just the individual MTS files
NOTE that I have CS5 on order so won't know until it arrives if the individual MTS files are all I need (think so... they all seem to be self-contained and play just fine)
Thanks. So there is no way to preview anything before importing?
When I use Final Cut Pro it has a log and transfer option that opens a window where all of the clips from the camcorder or the memory card are shown and you can preview the clips and even set in/out points on the clips before deciding which ones to import and how much of each clip to import.
That was the way that the capture worked with firewire also, and I'm surprised that this functionality is not available with avchd files.
I don't see why not? I've never tried it here, but if your operating system sees the media card as an accessible drive, then the Media Browser in Pr should be able to show you the files in-place on the card.
-Jeff
EDIT: You'll be able to decide which clips you don't want to import at all in order to save space, but for the clips you do import, you'll have to import the entire clip, not just the in/out segment.
Hi John, I'm not sure if this is at all related to the problem you're experiencing with your Canon, but when I first attempted to read directly from my Canon HF S10, my Windows 7 x64 computer wouldn't recognize it either. After digging around a bit, I discovered that it has to do with using a Hub USB port as opposed to a non-Hub USB port. I was connecting my Canon to the front USB ports: no go. After reading this thread (post 24 specifically), I plugged the USB cable into the back, no problems since then.
Matt
Interesting about Hub -vs- non-Hub... but as my SD card to reader to USB to hard drive works, I'll stick with that
Besides which, all of the USB ports on the back (built in to the motherboard) are in use for various devices, so all I have available are on the front... the ones that are connected to the motherboard via cable to the mid-tower case
My order of CS5 is due tomorrow, so I plan to do some MTS testing this weekend... some small clips to timeline to Encore to DVD to see how a DVD created from AVCHD source looks on my TV
Bottom line is that it's bogus that some Canons have this problem. All of my USB ports in the back
were used as well. I just had to transfer one to the front USB connection, and all was well. As you said for yourself
, there's no need as you have the reader.
I look forward to seeing your results with MTS and CS5.
Matt
http://forums.adobe.com/thread/652694?tstart=0 and http://forums.adobe.com/thread/653789?tstart=0
>What am i missing here?
Detailed information so someone can do more than guess
You really don't provide enough information for anyone to help
How to ask a question http://forums.adobe.com/thread/416679
Plus read http://forums.adobe.com/thread/459220?tstart=0
A link with many ideas about computer setup http://forums.adobe.com/thread/436215?tstart=0
And even more hardware discussion http://forums.adobe.com/community/premiere/hardware_forum
Including this post about 3 possible builds http://forums.adobe.com/thread/598040?tstart=0
Work through all of the steps (ideas) listed at http://ppro.wikia.com/wiki/Troubleshooting
If your problem isn't fixed after you follow all of the steps, report back with ALL OF THE DETAILS asked for in the FINALLY section, the questions at the end of the troubleshooting link... most especially the codec used... see Question 1
My problem stemmed with me downloading the trial because we haven't received the full version yet. Since I have to get these videos edited and this is my first time working with this file type, I thought it might work until I could put in the serial number when we got the software. However, the trial does not allow me to edit the file type I am working with (AVCHD [.MTS]), which is stated after I searched more here: http://kb2.adobe.com/cps/407/kb407938.html ![]()
Premeire CS3 does not recognize the file type. Premiere Elements 7 was able to start editing the files but it kept crashing on me until I wanted to pull out my hair and scream at the top of my lungs.
Thanks anyway all.
Yes, the trial has been a tripping point for many.
At least with CS5, one can convert from trial to full-paid (in most cases), without the previous versions' "flaming hoops."
One aside, and it can be version dependent, but PrE Project files (PREL), can Import or Open in equal versions of PrPro. For instance, and so long as I do not add things like Instant Movie, or Themes, I can Open PrE 4 Projects in PrPro 2.0. However, I cannot Open PrE 7, or 8 Projects in my PrPro 2.0. I would assume that CS5 can handle most PrE versions' PREL's - again, so long as one does not use certain PrE-only features.
Good luck,
Hunt
