wasabeenut
After Effects does not recognize correct system resources
Jun 29, 2010 7:05 PM
On my computer at work, I have After Effects CS4 and After Effects CS3. The computer is a 2x2.66 GHz Quad Core Intel Xeon with 8 gigs of ram running OSX 10.5.6.
Both versions of After Effects can only see/use 1.7 gigs of ram. My understanding is that After Effects should see as available 3 gigs of ram. (On the identical computer at home I can in fact see 3 gigs of ram.)
I need the maximum resources when working since I need to do longer HD ram previews. In addition at this low memory setting the software does not run right, with multiple memory crashes that should not be happening -- the kind of things that happen when you have insufficient system resources to run a program. I'm an advanced user who has been using this software for over 15 years -- it's not operator error.
I'm hoping someone has some suggestions of things I can do to alleviate this bug.
[As an additional note, the multiprocessing option is also telling me I have 16 processors, when I have only 8.]
    Jun 29, 2010 7:45 PM   in reply to wasabeenut
    This is the easy question, so I'll deal with it first.
    This a borderline bug. After Effects CS4 isn't able to take advantage of hyperthreading (which turns 8 physical processor cores into 16 virtual processor cores). However, it can _see_ the virtual cores, and it reports them as being there. Yeah, it's misleading. We fixed it in After Effects CS5---and we fixed it in the good way, by making After Effects CS5 capable of using the virtual cores provided by hyperthreading.
    OK. Now for the harder question:
    ram.
    Please be very specific about what you mean by "see". Exactly what are your settings in the Memory & Multiprocessing preferences? (A screenshot would remove all ambiguity.)
    Have a look at this page: "FAQ: Why doesn't After Effects see and use all of my RAM?"
    Also, see this page, especially the first comment on the bottom.
    Jun 29, 2010 7:47 PM   in reply to Todd_Kopriva
    By the way, make sure that you've updated to After Effects CS4 (9.0.2). That update fixed a lot of things, including some crashes.
