Can I record sound using a microphone and then upload it to server?
Jun 29, 2010 5:47 PM
Hello guys I thank you in advance for reading this. What I want to know is if it is possible to record a sound clip using a microphone and then upload it to the server using a swf applet in a webpage. Im an experienced java/javascript programmer but just starting out with flash/action script. What technologies will I need to do this? Can I do this simply using simply an swf file and an apache/php or jsp page? Again, thanks alot for your help.
-BeWilled
    Jun 30, 2010 5:08 AM   in reply to bewilled
    I do not deal with web pages, only E-learning. With Flash, you can can place sound inside a SWF, or have it outside the SWF but inside the same folder on the server. You will need the Mic and probably sound editing software.
    Jul 1, 2010 8:38 AM   in reply to bewilled
    You can Microphone class in Flash to record the sound and it will directly upload to FMS server .
    Use the Microphone class to capture audio from a microphone attached to a computer . Use the Microphone class to monitor the audio locally. Use the NetConnection and NetStream classes to transmit the audio to Flash Media Server. Flash Media Server can send the audio to other servers and broadcast it to other clients running Swf files .
    Below link might help you in doing this : http://www.adobe.com/devnet/air/flex/articles/using_mic_api.html
