To all,
We have not been able to figure out a way to bypass the Select Email Client window, but we were able to figure out how to reset an option if one had chosen Internet Email by mistake and checked Don't show again. To reset this so that the window will reappear and let the user select Desktop Email Application instead, do the following:
If the user has Adobe Acrobat Pro, the steps should be identical. This seems to work for us thus far.
Best of luck.
I just want to be sure about this. So even if you have the Reader Extensions product, users will still need to open up some sort of e-mail client and then attach the PDF to send by e-mail.
I was told that pressing the submit button would just send the form data to the server and then the server would process the data and send out the PDF attachment to the destination.
Usually the PDF submit by email button when used in Reader will ask whether they want to send it via an email client or save it to use with webmail e.g. Hotmail. The first selection will automatically open the default client on the computer (Outlook, Windows Mail etc) and launch a new message automatically populated with the email address to send to, subject and PDF attachment, as specified by the form author, ready for the user to press send. The webmail option allows the user to just save the PDF form on the desktop and manually log into their webmail account, create a new message, enter the email address to send to and attach the PDF previously saved.
The process isn't ideal and causes email submit to be either unreliable or generates questions from the user who are unsure how to proceed. We have a server-side system that eliminates this standard process and allows the a submit button to be placed on the form that uses http submission to our server, which then automatically dispatches the completed form to your email address as a PDF attachment. Its quick and simple, all the user does is complete the form, press send and then press OK to the thank you pop-up and moments later you get the email.
It was initially intended to be used privately for our own clients however a few weeks ago I started offering it to anybody that needs this facility, it doesn't cost much and I can let you try it out on your form upfront. Just go to www.pdf2email.co.uk for more information. A while ago it took me hours upon hours of research to find a solution and it took quite an investment in time and money to set it up but it has most deffinately been worth it.
Ben
Hi Vir Mulloo,
If you dont want the citizen to send the form as an email, you can submit the form to a backend server. Since you have already purchased LiveCycle Reader Extensions, you can use LiveCycle to grab the form data and process it for further use.
Vamsi Vutukuru
Product Manager
LiveCycle ES
