I am trying to find an inexpensive way to make my pdf files look good...
I wanted the documents to have the "page flip" capabilities.
someone suggested:
You could place PDF files in InDesign and export to a page-turnable SWF file. If you don't have InDesign, grab the fully functional 30-day trial to do the conversion from PDF to SWF
I am using InDesign CS2, and when I export, I do not see a SWF file option? -- the closest I see is SVG?
is there something that is not activated in my version?
any suggestions?
Thanks, Katah
I found this service online: Convert PDF Documents to SWF. Can't vouch for it but it seems to be free.
I use Page Flip http://page-flip.com/
I load my PDF into the program. It does pretty much the rest itself. Easy to use and setup. When I first bought it I had my PDF in pageflip awesomeness in under 2 hours (experimenting with). Now i get it done in about 20 minutes.
Handy little program to have.
I have a related question about page flip. I've seen swf files where there is a wire spiral in the center. That's an effect I would like as I do a lot of wire coil books and it would be cool if the swf file matched the actual book. Is there a plug in or app that will generate a book with page flip and wire coil in the center.
You mean like this:
http://dl.dropbox.com/u/133381/wiredFolder/index.html
Resolution of wire is a bit lousy, but I couldn´t find better for this demo.
That is made from InDesign CS4 (CS5 will do as well). The trick is to use single pages, not facing pages... and place the wire at the middle of the page. If SWF is exported as single pages, page transition will fold the page at horizontal half point... and it looks like page is folding by using same line where the wire is....
