resolveNodes doesn't find all nodes
Avatar
Level 4
Hi there,
I would like to find all text fields with a specific name in my form (and do things with them...).
Funny thing is: I sometimes get only one hit or no hits at all. I never managed to get the correct whole list of fields. Am I doing something wrong?
My code is (here in the form-ready event):
var arrayFields = xfa.resolveNodes("myField[*]");
if (arrayFields == null) {
    xfa.host.messageBox("nothing found");
else {
    xfa.host.messageBox(String("Number of Fields found: " + arrayFields.length));
    for (var iFieldCounter = 0; iFieldCounter < arrayFields.length; iFieldCounter++) {
        xfa.host.messageBox( arrayFields.item(iFieldCounter).somExpression);
    } // for iFieldCounter
} // else some result
PS. I have a little sample form ready. Yet I don't find a way to upload it to the forum.
Uli
Avatar
Level 4
e-mail the form to me and I'll take a look: alex.kloft@gmail.com
Avatar
Level 4
As I cannot mail my form
to everybody who reads this, I sketch my example form. The hierarchy is:
form
     masterpage
     myPage
          mySubform1
               myField
          mySubform2
               myField
With an expression like
var arrayFields = resolveNodes("xfa.form..myField[*]");
I don't get but the first "myField". Yet I expect to find both "myField" in arrayFields.
Avatar
Former Community Member
The documentation for resolveNodes comes with the following reservation:
Note: The search could return unexpected results if the form contains several objects that use the same
name. It returns the value of the first object that it finds.
As resolveNodes has an issue with returning objects located in subforms below $template.#subform.#subform[*], you're left with traversing the dom tree yourself.
A recursive iteration over Tree.nodes.item(i) is a good place to start.
Avatar
Level 4
Thanks for that information. Saved me from trying things for ever.
I wrote this function "resolveNodesFixed()" instead. Whoever has the same problem in the future may try it this way:
var arrayFields = resolveNodesFixed("myField");
else {
        xfa.host.messageBox( arrayFields[iFieldCounter].somExpression);
function resolveNodesFixed(sObjectName) {
    // Finds all objects by the name of sObjectName starting from the top.
    // Parameters:
    //        sObjectName: Name of the searched for object
    // Result:
    //         returns an array of found objects. It may be empty.
    arrayHits = new Array();
    traverseForm(xfa.form, arrayHits, sObjectName);
    return arrayHits;
} // function resolveNodesFixed()
function traverseForm(oFormNode, arrayHits, sObjectName) {
    // runs thru all nodes of the form and adds every node with the name "sObjectName" to arrayHits
    // Parameters:
    //        oFormNode:   starting node. From this node downwards this function searches for nodes.
    //        arrayHits:   array to add the found nodes to
    // Result:
    //         returns true if everything is all right
    try {
        //xfa.host.messageBox(oFormNode.somExpression + " - " + oFormNode.nodes.length);
        for (var iIndexChildObject = 0; iIndexChildObject < oFormNode.nodes.length; ++iIndexChildObject) {
            var oChild = oFormNode.nodes.item(iIndexChildObject);
            if (oChild.name == sObjectName) {
                arrayHits.push(oChild);
            }  // if oChild.className == sObjectName
            if (oChild.isContainer) {
                // this node appears to be a subform. Recursivly we check this subform's sub nodes.
                traverseForm(oChild, arrayHits, sObjectName); // if the node contains subnodes make a recursive call to the function
            } // if oChild.isContainer
        } // for iIndexChildObject
    } // try
    catch (e) {
      console.println("Error: " + e);
      return false;
    } // catch
    return true;
} // function traverseForm()
Avatar
Here's a more direct approach (blazingly fast, about 6 ms on my machine, since we're avoiding recursion by using internal methods instead):
function ResolveAll(str) {
var nn = [];
for (var p = 0; p < xfa.layout.pageCount(); p++) {
  var ss = xfa.layout.pageContent(0);
  for (var i = 0; i < ss.length; i++) {
   if (ss.item(i).name == str) nn.push(ss.item(i));
return nn;
var p = ResolveAll("fieldname");
Keep in mind that it doesn't search items inherited from master pages.
Avatar
Here's a slightly slower, recursive version (about 30 ms on my machine), operating on xfa.form. Note that it skips exclGroups and area objects.
var getAll = function() {
var needle;
var nn = [];
return {
  token: function(token) {
   needle = token;
   this.traverse(xfa.form);
   return nn;
  traverse: function(haystack) {
   for (var i = 0; i < haystack.nodes.length; i++) {
    var n = haystack.nodes.item(i);
    if (n.name == needle) nn.push(n);
    if (n.className == "subform") {
     this.traverse(n);
getAll.token(str).length;
