This discussion is for changes to the scripting DOM which can affect legacy scripts.
Please use this discussion for discussing new scripting features in CS5.
Please keep in mind that all changes are specific to version 7 DOM. InDesign supports versioning, so you should be able to use legacy scripts in CS5 without issues. Versioning can be done in two ways:
1) Place the script in a folder named: "Version 6.0 Scripts" (or 5.0, 4.0, 3.0). The folder must be named exactly as specified.
2) Set the script version preferences at the start of your script. (i.e. app.scriptPreferences.version = 6), but it's highly recommended to reset the scripting version at the end of the script, and even to enclose the script in a try/catch/finally block to ensure that the script preferences are reset correctly.
Here's quick links to issues brought up in this thread:
Harbs
Here's the first two (and probably the most significant) of the changes:
1) PageItem.parent: In previous versions, the parent of top-level page items were the Page that the PaeItem resided on. In CS5, this was changed (for increased performance), and the parent is now the PageItem's Spread. Together with this change, a new property "PageItem.parentPage" was added which returns the page that the PageItem is drawn on. parentPage works for nested PageItems as well, so this new property will do away with the need for a lot of the "findPage" functions that we've all been using!
2) PageItems.itemByName(): With the new layers panel comes a name property for PageItems. In previous versions PageItems.itemByName() would return the page item with the specified label in CS5, it will return the page item with the specified name (which can be set in the Layers Panel). There is no longer a quick-and-easy way to get page items by their label using the 7.0 scripting DOM.
Harbs
Does this affect only JS scripts, or all scripting? I do Applescripting and we have A LOT of workflow that depends on item labels. Will this change for Applescripting?
Chris
I'm not so sure that the .parentPage property does away with the need for findPage. I was just working on it right now and came to the conclusion that for a general function, it just changes it a bit:
function findPage(theObj) {
if (theObj.hasOwnProperty("baseline")) {
theObj = theObj.parentTextFrames[0];
while (theObj != null) {
if (theObj.hasOwnProperty ("parentPage")) return theObj.parentPage;
var whatIsIt = theObj.constructor;
switch (whatIsIt) {
case Page : return theObj;
case Character : theObj = theObj.parentTextFrames[0]; break;
case Footnote :; // drop through
case Cell : theObj = theObj.insertionPoints[0].parentTextFrames[0]; break;
case Note : theObj = theObj.storyOffset; break;
case Application : return null;
if (theObj == null) return null;
theObj = theObj.parent;
return theObj
} // end findPage
I believe that this function will work with any version of InDesign because it will behave the same as before in versions that don't support the parentPage property.
Of course, if you know you're dealing with an object that has a parentPage property in CS5, you can just go straight for the property.
Dave
Chris,
I expect that AppleScript users can still take advantage of whose clauses to get at the label (provided they can master the syntax).
In JavaScript, the news is worse than I feared because you can't even use versioning to get around this. All scripts that use item("label") to get at stuff will have to be rewritten.
Dave
I think it won't because of this line:
In CS1 it's ParentTextFrame - one item - not array/collection.
robin
www.adobescripts.co.uk
Yes. To refer by item, you should use something like:
item 1 of all page items whose label is "whatever"
A lot of people have been using this sort of construction anyway, to deal with the possibility of grouping, so they should be largely unaffected.
The other thing to keep in mind is that versioning solves the problem for AppleScript.
Shane Stanley <sstanley@myriad-com.com.au>
Dave,
Aren't you ignoring items on the pasteboard there?
Harbs,
I think I must be wrong about this because to my immense surprise your code works -- my surprise is caused by the certainty that that's just what I tried when I concluded it didn't work. I just did this:
1. I created a new document in CS5.
2. I dragged out a text frame and labeled it "Fred".
3. I duped that twice.
4. I ran this script:
var myDoc = app.documents[0];
var myTFs = myDoc.textFrames.item("Fred");
alert(myTFs == null);
app.scriptPreferences.version = "6.0"
var myTFs = myDoc.textFrames.item("Fred").getElements();
app.scriptPreferences.version = "7.0"
alert(myTFs.length);
There's a caveat here. The end result is an array and not a collection. But presumably the getElements() part is optional. Let me try another experiment. Aha! No it's not optional. This might well explain my confusion. This works:
alert(myTFs.toSource());
app.scriptPreferences.version = "7.0";
But this doesn't:
So, if you create an object reference while working within the CS4 versioning engine it won't work when you move back into the CS5 engine. So, by converting to an array--by using getElements()--which is a core feature, you can pass objects effectively from one engine to the other.
So, if you were converting your collection to an array anyway, then this makes converting the script a whole lot easier than I had feared. On the other hand, if you were using the reference as a collection, then you need to stay within the CS4 versioning engine for it to work. I wonder if you can move in and out of versions ... Yes!
// some code so that something happens while we're in this engine
for (var j = 0; myDoc.textFrames.length > j; j++) {
myDoc.textFrames[j].fillColor = myDoc.swatches[-1];
Well, this isn't as bad as I feared, but I can see me having to add a lot of versioning statements to scripts I convert from CS4 to CS5
Thanks for pointing me in the right direction Harbs.
Dave
Hi Dave,
Glad it worked. I really would have been surprised if it didn't!
This is the good old referencing problem. Besides giving you and array, getElements() resolves the specifier to the object, so until you use getElements(), the specifier is equivalent to ".item()" which has a different meaning in the 7.0 DOM. After using getElements(), the specifier(s) is (are) resolved to the equivalent of ".itemByID()", which will always give you the correct object(s).
Harbs
I am not a great scripting hero but i just have one question.
I have a Indesign file wich has a bunch of pages.
On each page there is a textframe wich is labelled "textcode".
When i run the script, Indesign exports each page to a pdf giving the name what's in the labelled textframe.
f = File (myFolder + "/" + p[i].textFrames.item ('textcode').contents + ".pdf");
Wich contains textFrames.item.
Does anybody knows what i have to change to let it work in CS5?
Already thanks for everyone who wants to help,
Bert
Holland
Update: Sorry guys, wasn't reading good. So the problem is solved!
FWIW,
Here's a general purpose function which gives pre-CS5 behavior for getting items by label using Dave's versioning method:
function GetItemFromCollection(label,collection){
var scriptVersion = app.scriptPreferences.version;
if( parseFloat(scriptVersion) > 6){app.scriptPreferences.version = 6}
var items = collection.item(label).getElements();
app.scriptPreferences.version = scriptVersion;
if(items.length==0){return null}
if(items.length==1){return items[0]}
return items;
To use it you'd do something like this:
items = GetItemFromCollection("test",app.documents[0].pageItems);
If you prefer prototype methods, you can use a function like this:
PageItems.prototype.itemByLabel = function(label){
var items = this.item(label).getElements();
return items;
However keep in mind that you'd need to do this for each type of collection, and you cannot create prototype functions on collections until you initialize the collection. To do that you'd need to insert a line like this (assuming there's a document open):
You could then write:
items = doc.pageItems.itemByLabel("test");
Harbs
Some (most) of the text properties which used to return Numbers can now return Strings. This can be a problem if you have a script which adjusts these values.
For example: myText.pointSize = myText.pointSize+1.
In CS4, this would take 12 point text and make it 13 points. In CS5, it'll take the same 12 point text and make it 121 points. This is becase it uses the String "+" operator rather than the Number one. This can catch you really off guard the first time it happens...
The fix is to cast the String as a Number like so: myText.pointSize = Number(myText.pointSize)+1.
Harbs
No. I don't think so.
One of the pain area for XML works in ID. ![]()
sudar1983_14 <forums@adobe.com>
07/03/10 02:41 PM
Please respond to
clearspace-721659546-639966-2-2945664@mail.forums.adobe.com
To
Pankaj Chaturvedi <pankaj.c@thomsondigital.com>
cc
Subject
Re: With CS5, some things have changed Re: With CS5, some things have changed
Footnote will allow the xml tags in CS5?
Arivu..
Hey Dave,
you forgot to handle placed XML Elements in your findPage function and made a mistake about the Cell case.
With a selected Cell your switch statement selected the parentTextFrame and breaked the switch. After the break it would run into line
theObj = theObj.parent;The parent of pageItem gives you the Spread in InDesign CS5. I've found it wondering why my xml additon does not worked.
I hope i've not introduced new Bugs ![]()
switch (whatIsIt) {
case Note : theObj = theObj.storyOffset.parentTextFrames[0]; break;
case XMLElement : if (theObj.insertionPoints[0] != null) { theObj = theObj.insertionPoints[0].parentTextFrames[0]; break; }
default: theObj = theObj.parent;
return theObj
} // end findPage
regards,
gregor
UPDATE: made an addition to the Note case ...
As Jongware points out here, PointType.LINE_TYPE is now PointType.PLAIN.
As pointed out here, there is no longer a property PasteBoardPreferences.minimumSpaceAboveAndBelow.
Use PasteBoardPreference.pasteboardMargins instead.
Harbs
I am using a javascript to export a pdf with settings. The script works fine in CS3 and CS4, but not CS5. I get an error from the following line of code for PDF preferences. I am exporting the PDF with OPI. What is the new syntax in CS5 for this setting?
contentToEmbed = PDFContentToEmbed.linkAll;
Thanks Peter,
so here is the "traduction" of the code in VB to access a TextFrame with the label :
Public Sub GetItemFromCollection(ByVal label As String, ByRef collection As InDesign.TextFrames, ByRef oTextFrame As InDesign.TextFrame)
scriptVersion = oInd.ScriptPreferences.Version
If scriptVersion > 6 Then oInd.ScriptPreferences.Version = 6
Set oTextFrame = collection.Item(label)
oInd.ScriptPreferences.Version = scriptVersion
End Sub
and to call it :
Call GetItemFromCollection("bTexte", oPage.TextFrames, oTexteFrame)
but it was easier before...
Philippe
I cant my progress bar working in CS5, it works if i dont trigger it from the menu.
Does anyone have a working script like this?
Here is the script that i made that adds a menu and when you fire the submenu a progress bar should start working in a window, but nothing is happening except when i add an alert, then it fires.
#targetengine "session"
// Create menu item
var test_menu = app.menus.item('$ID/Main').submenus.add('Test menu');
// Create sub menu action
var test_sub_menu = app.scriptMenuActions.add('Run progressbar');
// Set on invoke action
test_sub_menu.eventListeners.add('onInvoke', function() {
// Create a simple window
var win = new Window(
"window { \
progressbar: Progressbar { size: [400, 10] } \
// Center and show the window
win.center();
win.show();
// Set max value for the progressbar
win.progressbar.maxvalue = 5;
// Make a simple loop from 0 to 4
for(var i = 0; i < 5; i++) {
// This should happen every second
win.progressbar.value = i;
// Sleep for a second
$.sleep(1000);
// Remove the test menus actions
app.scriptMenuActions.item('Run progressbar').remove();
app.menus.item('$ID/Main').submenus.item('Test menu').remove();
// Add the sub menu action
test_menu.menuItems.add(test_sub_menu);
I just found a difference in the results from allPageItems, in CS5, which I have to code some kind of exception / condition for, in my scripts before upgrading them to CS5:
allPageItems now includes "contained" objects (images and other linked objects, that reside inside rectangles and such) in CS5.
As a simple test, placing an EPS on an empty page in a new document, I run the following code in CS4 and CS5 respectively:
CS5:
app.activeDocument.pages[0].allPageItems
Result: [object Rectangle],[object EPS]
CS4:
As you can see, we get the container rectangle only, in CS4, while CS5 is returning the object contained as well.
In a larger result set I get the following objects included in the allPageItems in CS5 (not present in the same call in CS4):
[object Image]
[object EPS]
[object Polygon]
[object PDF]
-- Andreas
[object Image]
[object EPS]
[object Polygon]
[object PDF]
New "feature", ehh ...
But this time - one thing could be good:
[container]
[content]
I think it could be usefull ... there is no way for [content] to be without preceding [container] ...
robin
I know this is an ancient post but just wondering if you got an answer on how to talk to boxs that have labels in CS5 I am just returning to the workforce and the last scripts I worked on were CS2 and my new company uses CS5. I'll repost my question below if you have any insights that would be great since we seem to have been in the same boat!
I wrote an Applescript at home on my laptop where I only have Adobe CS2 and want to use the same thing at work to show my boss what is possible with Applescript and it is failing at work cause we have Adobe CS5. Specifically placing a picture in InDesign.
This works in CS2 where I am talking to a named picture box
set picToPlace to "ARTWORK:Close Ups:05-02-04:CUA2222.tif" as alias
tell application "Adobe InDesign CS2"
activate
tell document 1
place picToPlace on rectangle "photo1"
fit rectangle "photo1" given proportionally
end tell
end tell
But at work when it gets to the {place picToPlace on rectangle "photo1"} line it stops and says something about "cannot get alias" (and gives the whole path to the file I am trying to place.)
Have they changed the wording for placing a pic in a rectangle? in CS5?
