Flex/Zend channel connect failed error...
Jul 6, 2010 2:23 PM
Hi guys.
    I am using Flex and php to develop my project. Everything works great in my local machine. However, when I upload my files to my server (godaddy.com). I got the error when loading my flex application.
The pop-up error message is
send failed
channel.connect.failed.error
Netconnection.call.Badversion: url:
http://mydomail/folder/gateway.php
I have upload my ZendFramewrok folder into my server and amf_config.ini has been configured. (webroot =http://mydomain)
I am not sure what's going on here. Please help. Thanks.
Update: my gateway.php
<?php
ini_set
("display_errors", 1);
$dir
= dirname(__FILE__);
$webroot
= $_SERVER['DOCUMENT_ROOT'];
$configfile
= "$dir/amf_config.ini";
//default zend install directory
$zenddir
= $webroot. '/ZendFramework/library'; //I did upload the ZendFramwork folder
//Load ini file and locate zend directory
if(file_exists($configfile)) {
$arr
=parse_ini_file($configfile,true);
if(isset($arr['zend']['webroot'])){
  $webroot
= $arr['zend']['webroot'];
  $zenddir
if(isset($arr['zend']['zend_path'])){
  $zenddir
= $arr['zend']['zend_path'];
// Setup include path
//add zend directory to include path
set_include_path
(get_include_path().PATH_SEPARATOR.$zenddir);
// Initialize Zend Framework loader
require_once
'Zend/Loader/Autoloader.php';
Zend_Loader_Autoloader::getInstance();
// Load configuration
$default_config
= new Zend_Config(array("production" => false), true);
$default_config
->merge(new Zend_Config_Ini($configfile, 'zendamf'));
$default_config
->setReadOnly();
$amf
= $default_config->amf;
// Store configuration in the registry
Zend_Registry::set("amf-config", $amf);
// Initialize AMF Server
$server
= new Zend_Amf_Server();
$server
->setProduction($amf->production);
if(isset($amf->directories)) {
$dirs
= $amf->directories->toArray();
foreach($dirs as $dir) {
// get the first character of the path.
// If it does not start with slash then it implies that the path is relative to webroot. Else it will be treated as absolute path
     $length
= strlen($dir);
     $firstChar
= $dir;
if($length >= 1)
      $firstChar
= $dir[0];
if($firstChar != "/"){
// if the directory is ./ path then we add the webroot only.
if($dir == "./"){
       $server
->addDirectory($webroot);
}else{
       $tempPath
= $webroot . "/" . $dir;
    $server
->addDirectory($tempPath);
}else{
      $server
->addDirectory($dir);
// Initialize introspector for non-production
if(!$amf->production) {
$server
->setClass('Zend_Amf_Adobe_Introspector', '', array("config" => $default_config, "server" => $server));
$server
->setClass('Zend_Amf_Adobe_DbInspector', '', array("config" => $default_config, "server" => $server));
// Handle request
echo $server
->handle();
Error from gateway.php if I call it directly.
Warning: require_once(Zend/Loader/Autoloader.php) [function.require-once]: failed to open stream: No such file or directory in /home/content/79/4687979/html/parkerList/gateway.php on line 27
Fatal error: require_once() [function.require]: Failed opening required 'Zend/Loader/Autoloader.php' (include_path='.:/usr/local/php5/lib/php:http://blackwheels.info//ZendFramework/library') in /home/content/79/4687979/html/parkerList/gateway.php on line 27
gateway.php is the rat. but I still can't figure out what's wrong. Zend/Loader/Autoloader.php is under the server root "ZendFramework/library" folder. I don't understand why my application can't find it. Thanks again!
    Jul 9, 2010 2:38 AM   in reply to jerry98225
    Hello,
    I had the same problem (I think). I've got a kind of solution : not a very good one, but at least it works (for me)...
    So, I put the ZendFramework directory into my application directory (that's why it's not a good solution...), and changed the directories configuration in amf_config.ini and gateway.php.
    (on my server : ......./myFlexApp/ZendFramework)
    new  amf_config.ini file :
    [zend]
    ;set the absolute location path of webroot directory, example:
    ;Windows: C:\apache\www
    ;MAC/UNIX: /user/apache/www
    webroot = .
    ;set the absolute location path of zend installation directory, example:
    ;Windows: C:\apache\PHPFrameworks\ZendFramework\library
    ;MAC/UNIX: /user/apache/PHPFrameworks/ZendFramework/library
    zend_path = ./ZendFramework/library
    [zendamf]
    amf.production = true
    amf.directories[]= ./services
    and the beginning of the gateway.php file :
    ini_set("display_errors", 1);
    $dir = '.';
    $webroot = $_SERVER['DOCUMENT_ROOT'];
    $configfile = "amf_config.ini";
    $zenddir = $webroot. '/ZendFramework/library';
    And for me that's OK.
    I'll try to fix the problem in a cleaner way later, with a ZendFramework directory separated from the application directory. Or maybe someone else can help ?... With a few "echoes" in the gateway.php file I wasn't able to understand what was wrong, I'm not familiar enough with php configuration.
    Hope this can help you !
    Calculating status...
    Nov 28, 2010 9:42 PM   in reply to jerry98225
    HI , I was reading ur problem and the answer given, and im trying to do the same in my hosting services but i cant seem to get it working have any of you gotten a better solution???
